Question about Roland Mc-909 Sampling Groove Box System
Mc909 work station problems
Hi i have a problem with Automatic voume levels in the part mixer on my Mc909Groove box they automaticly turn up and down is there any one?? who can tell me how to stop that from happening =)
    Sergeant:
    Champion:
  • 255 Answers
Problems with automatic volume sometimes is cause by leaky/corroded pushbuttons.the other impending defect of the circuit itself.i suggest you bring or have a tech check your unit just to be in the safe side.
Posted on May 28, 2009
Channel 4 stopped working. No other problems.
Hi Harold
TV may have simply lost the ch4 frequency from memory.
My TV did this 2 months ago and it blew me away as all other stations were fine.
Put it down to Cosmic Rays!
Simply run the Automatic Station Finder from the main settings menu. This will reload all receivable stations back into it's internal memory storage again.
Other than that.... is ch4 still on air.
Good Luck
Jan 03, 2016 | LG 24LN4510 24" 720p LED-LCD TV - 16:9 -...
How do I manually set my radio stations to my rcart2770 reciever
1. Connect the FM antenna and the AM loopantenna at the back of the unit. Rotate the AM loop for better reception.
2. Press AM/FM.
3. Tune a station by pressing TUNER+/-repeatedly until the desired station is found.Alternatively, you can press and hold thesame buttons down for about one second toactivate the automatic search function. Inthis mode the unit will automatically tunefrequencies until it finds a station.
4. Repeat step 3 to tune to another radio station.
5. Press AM/FMto select between FM and AM.Storing Radio Stations
The unit can store up to 40 radio stations (30 preset stations for FM and 10 preset stations for AM) in its memory. You can enter every single radio station yourself or the unit can store all available radio stations automatically in ascending order
Automatic Preset Programming
1. Press AM/FM to enter the AM/FM mode.
2. Press and hold AM/FM for two seconds to start automatic preset programming.
3. Radio frequencies will be browsed and radiostations stored automatically. When all the available radio stations are stored or all 40(30 preset stations for FM and 10 preset stations for AM) memory locations are full,the auto preset programming function will stop.
Manual Preset
1. Tune to a radio station (see "Manual tuning"for details).
2. Press MEMORY. While the Program Preset number is still flashing, input your desired preset number using the numeric buttons or press CH+/-, then press MEMORY to store it.
Retrieving Preset Stations
1. Press AM/FM to enter the Tuner mode.
2. Press CH +/- to search up or down for thepreset stations or directly press the numeric buttons.
Apr 30, 2014 | Cars & Trucks
Not step on the accelerator of vehicle automatic speed
Automatic vehicle at the beginning will automatically forward, but the speed is not too fast, because the automatic mechanism principle, high running loose throttle speed decreased than manual slow some, is a normal phenomenon. use gna 600 to diagnostic If the initial automatic acceleration, speed has a problem, the problem generally appear in the idle adjustment problems, such as: solar term door fault, the intake system leakage phenomenon, cause idle setting, you can go to your car repair station for inspection repair, in order to accurately determine fault.
Dec 09, 2013 | Ford Explorer Cars & Trucks
How to connect a vocal processor to a peavey6 mixer
Set the voice input level on the voicelive2 by following this guide from the live 2 manual... Step 4: Set Mic Level This step informs VoiceLive 2 how loud you plan to sing with your particular mic. We'll use VoiceLive 2's automatic MIC GAIN feature to quickly set the optimum level. 1. Press and hold the REVERB footswitch 2. If you need to activate phantom power for your condenser mic, adjust the onscreen PHANTOM parameter which will restart the level test 2. Sing for five seconds with peaks that are as loud as you plan to sing 3. Follow the prompts in the display to finalize mic level setting, cancel or redo the procedure During performance, if you see the CLIP indicator light in the HOME screen, you can return to the automatic
MIC GAIN feature to adjust the input level.
When input level is set on the voice live ;
on the mixer set
the gain control to 12 o'clock position and
individual channel volume level to 7 ....raise the master volume
slider to hear mic input at desired level and without feedback
Jan 15, 2012 | Peavey PV6 Mixer
Where is it on the transmision of a 85 golf 1.8 5 speed
im geussing you want to know how to check the oil level on an 1985 golf
if its an automatic open the bonnet look down in front of the autobox
you should see a small dipstick
if you have a manual stick shift the oil level plug is next to point where the drive shaft enters the gearbox the automatic box also has a level plug here but is for the oil level in the differential gear
Feb 22, 2011 | Volkswagen Golf Cars & Trucks
My automatic gearbox will not find reverse. All the other settings work, it's only reverse.
This tells you, that your automatic gear box is start to compromised. The reverse is always the first victim in automatic gear box problem. So please get it fixed soon, before the problem spreading to "D".
Regards, Jay
Jan 28, 2011 | Land Rover Freelander Cars & Trucks
On My CST berger 32X automatic level unable to hold vial bubble center as instrument is rotated 180 degrees - instructions say to use vial adjustment screws to correct this problem...this does not seem to...
take a topedo level and get the tripod base as level as possible. attach your level to the tripod. put all screws in the middle and level it. turn 180 degrees, level it. turn 180 and check. if withing the bubble, turn 90 degrees and level. turn 180 and so on and so forth. the adjustments should be slight from turn to turn. make sure the feet are secured firmly in the ground. If this does not level the automatic level, it needs sent in for calibration. I dont know the web address but I hope this helps
Dec 21, 2009 | RTO CST/Berger 55 - SLVP32N 32X SAL...
Stir/first level goes fullspeed and then turns off automatically
It shouldn't do that, and I really doubt there's anything you can do about it other than to have the defective part replaced. It sounds to me as though there's a problem with the control mechanism. If the machine is still under warranty, contact Kitchenaid to see about getting it repaired or replaced. If not, get the name of a local shop that repairs Kitchenaid mixers -- from your description of the problem, the mixer is nearly unless in its current state.
Jul 10, 2009 | KitchenAid Food Mixers
Automatic transmission problem
I have 1998 Maruti Esteem Automatic gear car - It works smoothly for 10-15 Kms and afterwards gear not shifting (may be getting heated inside somewhere?) - Recently I changed gear oil also. Any solution???
Jul 01, 2008 | 1997 Suzuki Esteem
Roland Mc-909 Sampling Groove Box System Logo
197 people viewed this question
Top Roland Audio Players & Recorders Experts
Electric Dime
Electric Dime
Vito Vacirca Jr.
Greg Cann
Greg Cann
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
