Question about HP PSC 2210 All-In-One InkJet Printer
Copier or scanner do not respond
It prints fine. But - it will not scan or copy anything. I have uninstalled & re-installed the software etc. This printer has never copied.
  • 68 Answers
Cheeck the connection inside. It is a white male connection.
Posted on May 28, 2009
My printer ,scanner &copier Mf4500 series is not responding to scanning
If you machine doesn't respond for printing, scanning and copying, you may have problem with software. In this case you need re-install software. you can download software link below.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/imageclass_series/imageclass_mf4570dn#DriversAndSoftware
Apr 26, 2014 | Canon Computers & Internet
How do i use Toshiba e Studio 163 Copier as a Scanner ?
how can i use Toshiba E studio 163 as a scanner?
can print.. But can't Scan Anything even can't see the scanning opition or even icon..
Sep 29, 2010 | Toshiba e-Studio163 Copier
My Hp Deskjet F4200 series printer will not scan anything to my computer, but it will copy just fine. How can I get it to scan? I have already uninstalled the printer driver & reinstalled it. It says...
Check to see that your Scanner drivers have been installed. Click on Start, then Printers and Faxes and see if a Scanner is listed. If not, you need to install the drivers.
Also, when you uninstall the printer drivers, you first need to disconnect the printer from the computer, and unplug the printer from the power source. Leave the printer unplugged for at least 15 minutes to clear the printer's cache memory.
Next, go to Add/Remove Programs in your Control Panel and uninstall the printer software. Then, turn off your computer.
Next, reboot your computer. Place the Deskjet cd in the drive and follow instructions for reinstalling the printer software and drivers.
CAUTION: DO NOT PLUG IN YOUR PRINTER CABLE TO YOUR COMPUTER UNTIL PROMPTED BY THE INSTALL DISK!!
Oct 08, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I hit scan on my machine and there is nothinbg responding on the computer screen. I am able to copy, print and fax. Help.
Your scanner is not properly installed. It is a separate part of the program. If you have (start - programs) the scanner as a program, bundled with your other printer proograms on screen, double (left) click on the scanner program, it should lead you to the install wizard. simply install the program. If not, try reinstalling your printer.software (use control panel - add/remove - uninstall all printer programs FIRST). Look at your software and make sure that the scanner software IS included.
Sep 01, 2009 | Brother MFC 210C All-In-One InkJet Printer
My all in one printer/scanner is not scanning. prints and copies fine, but does not scan
Form your issue that you are able to print and copy but unable to scan it is very clear that it is a software issue. Copy and scan fuctions work this way.
Copy - completely related to hardware.
Scan - related to software
uninstall and reinstall the full version software from Hp for the operation system of your computer.
Aug 23, 2009 | HP DeskJet F4280 All In One Printer InkJet
Kodak esp-3 unable to scan from home center,but able to print
If you are getting a 1-2036 error then there maybe an conflict between the Kodak TWAIN driver and another TWAIN device, most of the time it is with a flat bed scanner. If you have another All in One printer or scanner connected unplug it and uninstall its drivers. If the issue continues uninstall the Kodak software and unhook the kodak printer. Then download the kodak clear utility from HERE
After the utility runs and you restart your computer Re-install the Kodak Printer software and select WEB install to get the latest version.
Hopefully that will solve your Home Center scanning issue.
Jul 13, 2009 | Office Equipment & Supplies
HP 2410 prints & copies fine but won't scan.
Well if you are able to copy from your printer,it suggests that the hardware is perfectly fine.Its just an issue with the software.May be you are using an old software that is not compatible with the new operating system of your computer.If this is not the problem then try uninstalling and then reinstalling the software.And mind that when to uninstall the software do it completely from the registry,program files as well as add/remove programs.If you want any further support, an online technician from techbuddies can help you for free.For this log on to http://tinyurl.com/m7ghqz
Jun 18, 2009 | HP PSC 2410 All-In-One InkJet Printer
I have new Hp photosmart C4385 all in one scanner, printer, copies. The printer was initially onstalled. Working w/ wireless HP pavillion. It print & copies fine. Scan does not work. When I enter...
I had a similar problem recently... You have to actually install the scanner software. You probably only installed the print drivers, but not the scanner software. If you don't have the CD handy, go to www.hp.com/#Support. In step one select "Download drivers and software (and firmware)". In step 2 enter your model number (photosmart C4385) and then press "go". It will lead you to a page to select your operating system. Follow that link to download the entire CD (large file).
When you are installing the software, make sure to install the scanner software too.
John Lox
Apr 14, 2008 | Computers & Internet
Scanner/Director problems since installing new ink cartridge
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=45391&lc=en&cc=us&dlc=&product=90764
Dec 28, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
88 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
