Question about Olympus FE-310 Digital Camera
Stripes in the picture
Hi, I have a problem. The camera was working fine but for a while now has been taking pictures which seem fine in the camera display but the display on the computer is terrible, it shows stripes and sometimes is not even in the same place. Does anybody know what the problem might be and/or how to repair it? Thanks
SOURCE:
  • 75 Answers
SOURCE: stripes
This is caused by a stuck shutter. Since the camera is under a year old it is still under warranty.
Posted on Mar 28, 2007
leecom72
  • 4806 Answers
SOURCE: Write protected-Olympus EVOLT E-510 Digital Camera.
Hi there
The write protect is on the memory card, take the card out and unlock it, it will be at the side of the card like this 59a6de4.jpg .
Good luck and thanks for using Fixya!!
Posted on May 15, 2009
  • 919 Answers
SOURCE: camera does not take pictures
The problem you are describing is a problem with one of the chips in the camera that controls image processing. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $98 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Posted on Jun 03, 2009
BillB-SA
  • 2761 Answers
SOURCE: the camera turns on - but you cant take a picture
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Posted on Nov 08, 2009
SOURCE: Olympus X 775 Camera Blank Screen
Go back to duracell or energizer batteries... regular is not enough to poer this type of electric device
Posted on Jun 04, 2010
Camera makes overexposed pictures wiht lines can this be a software problem ?
Nope, this is a hardware problem and the camera needs to be worked on. Notice how your display works fine but the finished product exhibits the anomaly. The recording end is messed up.
Aug 12, 2015 | Panasonic Lumix DMC-TZ7 Digital Camera
White screen
This is a problem with shutter not fast enough opening to take a picture indoor shows the horizontal lines. In sun light it is too slow and over expose the picture. Not worth the trouble to fix, buy another camera?
Jun 26, 2012 | Olympus Cameras
When I take a picture it looks fine on the screen. When I then review my pictures there are red lines going through the picture.
The problem is due to CCD/CMOS (the chip that physically captures light and creates the digital image) has broken. If this is the case , a repair would cost approximately $80-$130. This is the most common problem for a camera that takes blank/lines in images but where the menu display functions and old photo's display normally.Please confirm that these stripes are normally behind the menu's. Check to see if the new images are downloaded correctly and if the video function works normally. If this does not work, it supports the idea that the chip has gone.Take it to a repair,if the CCD has to be replaced then a new or refurbished camera would cost only slightly more.
Thank you !!
Jun 21, 2010 | Kodak EasyShare M853 Digital Camera
BLURRY PICTURES
hi,
this is lance assembly problem, you must be contact any authorised person to fix it
Sep 27, 2009 | Nikon Coolpix S1 Digital Camera
Dropped my casio exilim ex-z85a camera and now when I take pictures, there are light horizontal striped lines running through the entire image
By dropping the camera you have caused some shock damage to the LED display so you will no doubt have get it repaired.
Saying that, if you copy the pictures to a computer you may find that the pictures are fine.
Regards.
Aug 11, 2009 | Casio Cameras
Won't take pictures when zoom
Most common problem in al the digital camera's. Slide motor start malfunction and the massage appears"Turn off the power and on again". In this situation you have to replace slide motor or lens block assembly, And your camera work fine again.
Thanks for using fixya.
Jun 27, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Pictures have black stripes running through them
Do you have a card reader for the memory card in your camera?
If so, please remove the card from the camera and insert it into the card reader. If the lines are still threre then it's the CCD unit in your camera. Otherwise it's the interface cable.
Dec 19, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Striped pictures
The sensor chip on which focused light falls has a failed connection. The image is 'read' via a matrix that is scanned to retrieve the image and one of the paths of this matrix is broken.
Oct 14, 2008 | Kodak EasyShare Z760 Digital Camera
Stripes on the photos
Hi if you had not chosen any fader effect then problem is with internal circuit. the blanking lines are visible kindly first chek with fadder effect in setting if it is normal then you need technical expert to physically chek the circuit. thanks Sangita
Jul 08, 2007 | Polaroid i832 Digital Camera
Underexposed, grainy images with a light stripe running down the center
Sounds like your shutter curtain is malfunctioning. Did you bump the curtain when u loaded film & bed it... Take a close look to see if it is binding. This is a very fragile area to monkey with & should be done by a qualified repairman
Jun 26, 2007 | Canon EOS Rebel K2 35mm SLR Camera
Olympus FE-310 Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
