Question about Micro Electronics PowerSpec 8250 PC Desktop
Installed USB microphone, but NO sound.
I installed a USB microphone but I'm not getting any sound from it when I test it. You can everything else that has sound, such as limewire, but you can't hear anything coming out of the speakers from the mic. It says it was installed correctly and all that. The volume for the mic is up, the computer speakers are turned up. When I tested it, it was showing that their was sound going into... but their was nothing coming out. I have no clue what to do. I've tried so many things. If you could help that would be greatly appreciated. Thanks in advance!!
-Justin
  • Micro Electr... Master
  • 4,924 Answers
Select the device from control panel /sound and audio device / audio .../sound recording ...
if it doesnt work ...look for the device ( microphone ) on volume panel ( double click the speaker from the system tray ) if you do not see a volume for mic...click options..and check the microphone from there ...after that look out and be sure it s not muted...it has to work if it is proper installed..
Posted on May 28, 2009
My chrystaleye webcam wont work with skype
SKYPE VIDEO PROBLEM
To test if the Logitech QuickCam is functioning, check the USB cable; make sure it is connected properly. Then click on Start - All Program - Logitech - Logitech QuickCam and see if you can get the camera to capture your image/video. If this works then the fault is with the Skype configuration. Sometimes the WEBcam settings drop off and the WEBcam need to be selected again. Open Skype - Tools - Options - Video Settings and select the Logitech QuickCam Also check the Audio Settings for the Microphone THEN click on Save. Avoid connecting the WEBcam to an USB hub. SKYPE MICROPHONE PROBLEM
If the person cannot hear you then, either your microphone driver not installed or not working OR the microphone is not configured in Skype.
To test your microphone then click on Start - All Programs - Accessories - Entertainment - Sound recorder. Then record your voice and then play it back. If this is OK then the microphone need to be configured in Skype.
To configure the microphone - Open Skype - Tools - Options - Audio Settings for the Microphone THEN click on Save.
Sep 03, 2012 | Acer Aspire 5500 5570-2609 Laptop
Hello, I just purchased the C01U USB mic and whenever I test or record with it I get this really high pitched noise. but when I tap the Mic is goes away and then slowly fads back in after a couple of...
1. Try the microphone on another USB port and check.
2. If not OK, try the microphone on another computer and check.
3. If OK on another computer, re-install it or recover the O.S. from a backup.
4. If on another computer the same problem exists, the microphone could have a internal control defect.
Aug 20, 2011 | Samson C01U - USB Studio Condenser...
I cannot get the dropdown for the microphone settings.I did when I first installed it & then it records everything but the cassette.I cannot change it to usb microphone.
when you plug it into the usb port it should automatically install itself if it does not you might have to install it manually
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it hope this helps
May 11, 2011 | Televison & Video
Samson C03 Microphone using with Realtek HD Audio Manager
SEU MICROFONE PRECISA DE UM RECURSO CHAMADO PHANTON POWER QUE NADA MAIS é DO QUE UMA ALIMENTAçãO DE 48 VOLTS, PORTANTO NECESSITA DE UM APARELHO INTERMEDIARIO, COMO UMA MESA DE SOM COM ESTE DISPOSITIVO OU UM ADAPTADOR PHANTON POWER COM SAIDA USB PARA O SEU PC, NO CASO DA MESA TAMBEM é NECESSARIO UMA PLACA DE AUDIO COM CONEXãO USB EXEMPLO UCA 202 DA BEHRINGER , PODES CRER Só ASSIM FUNCIONA E SOM é MUITO BOM.
Apr 06, 2008 | Samson C03 Professional Microphone
I've bought a logitech quickcam communicate STX. When I installed it first it worked fine. Someone unpluged it from the usb port and it wouldn't work. I re-installed the drivers and it was fine again but...
The microphone may not work because of a hardware or configuration problem. To determine if it's a hardware problem, test the microphone in Sound Recorder.
  1. Click "Start," > "Programs" ("All Programs" for Windows XP) > "Accessories" > "Entertainment" > "Sound Recorder."
  2. Click the Record button and speak into the microphone of the camera. You should see the green line move, indicating the application is picking up sound.
  3. Click the Stop button.
  4. Click the Play button. If there is no sound at playback, check to make sure the correct device is selected.
    1. Click "Edit," then "Audio Properties."
    2. Make sure Logitech is listed as the Preferred device for "Sound recording."
The microphone may also be defective. To test this, try the camera on another USB enabled system.
If you can record sound in Sound Recorder, but not in the QuickCam application, try setting the Logitech Microphone as the Preferred device in Audio Properties.
Feb 25, 2008 | Logitech Webcam
LOGTECH WEBCAM
Hi Melissa,
to put that in cam microphone working, as I have an equal trade mark cam, you need to see on audio settings properties and change the "recording device" to usb device, instaid of the soundcard as is. that means that the sound recording goes to the cam's microphone.
the steps are:
1- rigth mouse click on the speaker next to the clock OPEN VOLUME CONTROL
2- OPTIONS - PROPERTIES - RECORDING
3 - in MIXER/RECORDING DEVICE (where is your soundcard's name) change to USB DEVICE and then OK
4- select MICROPHONE and the close the volume control windows
5- you can test the mic settings in messenger (any version) because of volume and to a clearest voice sound in your pc.
ATTENTION: carefull with the distance between your cam and your sound speakers because of distorcing sound and feedback
Best complements
Jan 19, 2008 | Acer Aspire 3610 Notebook
QuickCam mic doesn't work
For XP users,try:
>Start
>ControlPanel
>Sounds and Audio Devices
>Audio
>Sound Playback
Click on drop down menu arrow.
If there are two audio devices listed: Deselect current device; select second device.
>OK
Oct 05, 2007 | Logitech QuickCam Express Web Camera
Microphone
probably your sound card for your computer is damage or you will have to check your installed drivers once more if that does not work.get a sound card that can fit on computer slot.since your computer sound card is built onto the mother board.good luck.
Apr 11, 2007 | Logitech (980240-0403) Consumer Microphone
Micro Electronics PowerSpec 8250 PC Desktop Logo
2,065 people viewed this question
Top Micro Electronics Computers & Internet Experts
Dennis Maeder
RSole
Masood Rasool
Level 1 Expert
Are you a Micro Electronics Computer and Internet Expert? Answer questions, earn points and help others
