Question about Minolta magicolor 2400W Laser Printer
Installing new black print cartridge
I'vr read the manual, the cartridge instructions and on line.  All say to rotate the cartridges until the one I want is visible and can be extracted to replace the one I need. I've tried this and the black cartridge never becomes available to replace. The only one that lifts out easily is the one with the green handle. None of the cartridges seem to rotate, however I hear the workings. I can't find the black cartridge already in the printer. How do I locate it, pull it out and insert a replacement. I don;t want to force anything for fear of breaking the machine.
  • 104 Answers
Manually Removing Toner for magicolor 2400W
1.  Hold down the Cancel button for 10 seconds or longer.
2.  With the Cancel button still held down, also simultaneously hold down the Rotate Toner button for 10 seconds or longer.
3.  When all LED indicators are blinking rapidly, release both the Cancel and Rotate Toner buttons.
4.  Then hold down the Rotate Toner button again for another 10 seconds or longer.
5.  The Cyan toner cartridge moves into the proper position, so it can be removed.
6.  Remove and/or replace the Toner Cartridge if necessary.
7.  Open and close the covers. Each time you do this, another toner cartridge moves into the proper position, so it can be removed and/or replaced (in this order: cyan, black, yellow, magenta).
The link is located here
Posted on Oct 21, 2007
How do I change the toner HP Officejet 6310 All-In-One
Hi, the officejet 6310 takes ink and can be ordered from most online stores like staples, cartridge world and amazon, All will vary in price, but always stick to the official HP inks although they are more expensive the compatibles do cause problems. below is a link to the cartridges you will need to purchase.
http://shopping.cartridgeworld.co.uk/home.php?cat=901
Unfortunately i cannot attach files to this message otherwise i would put the manual on here, which on page 95 shows step by step on how to change the ink cartridges. I can email this to you if you provide an email address for me. below i have copied the instructions from the manual, but there missing illustrations, so might be a bit hard to follow. please let me know if you require any further help.
Replace the print cartridges
Follow these instructions when the ink level is low.
Maintain the HP All-in-OneNote When the ink level for the print cartridge is low, a message appears on
the display. You can also check the ink levels by using the software installed
with the HP All-in-One.
When you receive a low-ink warning message on the display, make sure you have a
replacement print cartridge available. You should also replace the print cartridges
when you see faded text or if you experience print quality issues related to the print
cartridges.
To order print cartridges for the HP All-in-One, go to www.hp.com/learn/suresupply. If
prompted, choose your country/region, follow the prompts to select your product, and
then click one of the shopping links on the page.
For a list of print cartridge numbers, see the back cover of this guide.
Tip You can also use these instructions to replace the black print cartridge
with a photo print cartridge for printing high-quality color photos.
To replace the print cartridges
1. Make sure the HP All-in-One is on.
Caution If the HP All-in-One is off when you open the print cartridge door
to access the print cartridges, the HP All-in-One will not release the
cartridges for changing. You might damage the HP All-in-One if the print
cartridges are not docked safely on the right side when you try to remove
them.
2. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
1 Print cartridge door
2 Print carriage
3. Wait until the print carriage is idle and silent, and then lightly press down on a
print cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge
from the slot on the right.
Chapter 10
96 HP Officejet 6300 All-in-One series
Maintain the HP All-in-One1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
4. Pull the print cartridge toward you out of its slot.
5. If you are removing the black print cartridge in order to install the photo print
cartridge, store the black print cartridge in the print cartridge protector or an
airtight plastic container.
If you are removing the print cartridge because it is low or out of ink, recycle the
print cartridge. The HP Inkjet Supplies Recycling Program is available in many
countries/regions, and lets you recycle used print cartridges free of charge. For
more information, go to the following website:
www.hp.com/hpinfo/globalcitizenship/environment/recycle/inkjet.html
6. Remove the new print cartridge from its packaging and, being careful to touch
only the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
Caution Do not touch the copper-colored contacts or ink nozzles.
Touching these parts can result in clogs, ink failure, and bad electrical
connections.
User Guide 97
Maintain the HP All-in-One7. Slide the new print cartridge forward into the empty slot. Then gently push on the
upper part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
8. Close the print cartridge door.
9. If you installed a new print cartridge, the print cartridge alignment process begins.
10. Make sure you have plain paper loaded in the input tray, and then press OK.
11. The HP All-in-One aligns the print cartridges. Recycle or discard the print
cartridge alignment sheet.
12. Press OK.
Dec 02, 2011 | HP Officejet 6310 All-In-One InkJet...
I no longer have my manual, how do I change the ink cartridges for the HP Officejet 6300 all-in-one?
them.
slot on the left.
12. Press OK.
Jul 17, 2011 | Computers & Internet
How to change the ink cartridge
Follow these instructions when you need to replace print cartridges.
• Everyday printing: Use a black cartridge along with a tri-color cartridge.
• Color photos: Use a photo cartridge along with a tri-color cartridge.
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
5. Pull the print cartridge towards you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,
store the black print cartridge in the print cartridge protector or an airtight plastic
container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Also, do
not re-tape the print cartridges. Doing so can result in clogs, ink failure, and bad
electrical connections.
8. Hold the print cartridge with the HP logo on top, and insert the new print cartridge into
the empty cartridge slot. Make sure you push the print cartridge in firmly until it snaps
into place.
Jun 30, 2011 | HP PhotoSmart C4385 All-in-One Printer
I bought a new ink cartridge, but cannot find my manual. How do you change the cartridge???
Changing an HP Ink Cartridge
  • 1
    Open the lid of the printer. Depending on the model, there will be two cartridges on the right, one for black and one for color.
  • 2
    Find the cartridge that is running low on ink. The black cartridge will be in black, the color cartridge will have a patch of color (usually green) on it.
  • 3
    Pull down on the black clamp that is holding the cartridge in place and slide out the used cartridge.
  • 4
    Open the package of the new ink cartridge. Remove the protective tape and slide the new cartridge into the printer.
  • 5
    Snap the black protective case back into place and close the lid.
  • techbelkin
    Nov 11, 2010 | HP Officejet 5610 All-In-One InkJet...
    Ink is stuck in the printer. I can't get it out.f4280 deskjet
    I found this on the HP Web Site. You can download the user guide and the Manual. Show step by step instruction to change the cartridge. If you find this helpful pls rate me.
    http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3390949&lc=en&cc=us&dlc=en&lang=en&cc=us
    http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
    1. Make sure the product is on and you have letter or A4 unused plain white paper loaded in the input tray.
    The print carriage should move to the far right side of the product. If the print carriage does not move to the right side, turn the product off, and then on.
    3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it.
    If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    If you are replacing the black print cartridge, remove the print cartridge from the slot on the right.
    2 Print cartridge slot for the black print cartridge
    4. Pull the print cartridge towards you out of its slot.
    6. Remove the new print cartridge from its packaging, being careful to touch only the black plastic. Gently remove the plastic tape using the pink pull tab.
    CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching
    these parts can result in clogs, ink failure, and bad electrical connections.
    7. Slide the new print cartridge at a slight upward angle into the empty slot. Then gently push on the upper part of the print cartridge forward until it snaps into place.
    If you are installing the black print cartridge, slide it into the right slot.
    Jan 28, 2010 | HP DeskJet F4280 All In One Printer InkJet
    Changing cartridge on printer
    The Basics manual from HP:
    http://h10032.www1.hp.com/ctg/Manual/c00694908.pdf
    Check out page 17 of the Basics manual for detailed instruction on replacing the cartridges.
    cartridges are not docked safely when you try to remove them.
    slot on the left.
    5. Pull the print cartridge toward you out of its slot.
    print cartridge.
    connections.
    8. Slide the new print cartridge forward into the empty slot. Then gently push on the
    9. Close the print cartridge door.
    If you installed a new print cartridge, the HP All-in-One prints a print cartridge
    alignment sheet.
    Note If you have colored paper loaded in the input tray when you align
    the print cartridges, the alignment will fail. Load unused plain white paper
    into the input tray, and then try the alignment again.
    If the alignment fails again, you might have a defective sensor or print
    cartridge. Contact HP Support. Go to www.hp.com/support. If prompted,
    choose your country/region, and then click Contact HP for information on
    calling for technical support.
    Jan 03, 2009 | Office Equipment & Supplies
    Installed new black ink cartridge per instructions. HP #56 - machine type hp psc 2210 all-in-one. Machine instructed how to run cartridge alignmet check. In all modes machine runs about one half check and...
    to complete the alignment it needs to detect the lines printed from both the black and colour cartridges.maybe ur black cartridge is printing the necessary pattern but the colour is not printing so when it tries to read the colour paattern ,it cant read and cancels the alignment and ejects the paper out..it will keep on doing this if it cannot read the both colour and black patterns.see to it that both ur cartridges are printing and working properly.
    Dec 17, 2008 | Office Equipment & Supplies
    Changing ink cartridge on the HP Photosmart C3180 all in one
    slot on the left.
    print cartridge.
    connections.
    alignment sheet.
    Nov 25, 2008 | HP Photosmart C3180 All-In-One InkJet...
    I haven't the manual for this printer color laserJet 2600n series,
    HP Color LaserJet 2600n Printer - Installing Print Cartridges When a print cartridge approaches the end of useful life, the control panel displays a message recommending that to order a replacement. The printer can continue to print using the current print cartridge until the control panel displays a message instructing to replace the cartridge. The printer uses four colors and has a different print cartridge for each color: black (K), cyan (C), magenta (M), and yellow (Y). Replace a print cartridge when the printer control panel displays one of the following messages: Replace yellow cartridge, Replace magenta cartridge, Replace cyan cartridge, Replace black cartridge. The control panel display also indicates the color that should be replaced (unless a genuine HP cartridge is not currently installed). Change the print cartridge
    1. Turn off the printer.
    2. Open the front door. c00315320.gif CAUTION: Do not place anything on the transfer belt (ETB), which is located on the inside of the front door.
    4. Remove the new print cartridge from the bag. Place the used print cartridge in the bag for recycling. c00315322.gif
    5. Grasp both sides of the print cartridge by the blue handles and distribute the toner by gently rocking the print cartridge from front to back. CAUTION: Do not touch the shutter or the surface of the roller. c00315323.gif
    6. Remove the orange shipping locks and the orange shipping tape from the new print cartridge. Discard the shipping tape and shipping locks according to local regulations. c00315324.gif
    7. Align the print cartridge with the tracks inside the printer, and using the handles, insert the print cartridge until it is firmly seated. c00315325.gif
    9. Turn on the printer. After a short time, the control panel should display Ready.
      NOTE: If a cartridge is in the wrong slot or is the wrong type for the printer, the control panel will display one of the following messages: Incorrect yellow, Incorrect magenta, Incorrect cyan, Incorrect black.
    10. Installation is complete. Place the used print cartridge in the box in which the new cartridge arrived. See the enclosed recycling guide for recycling instructions.
    11. If a non-HP print cartridge is in the printer, check the printer control panel for further instructions.
      NOTE: When replacing or changing a black print cartridge, a cleaning page will automatically print. This helps prevent speckles on the front or back of printed documents. A cleaning page can also be generated using the control panel or the HP Toolbox.
    Nov 03, 2008 | HP Color LaserJet 2600n Printer
    HP 1220c problem
    Did you try both cartridges? Sometimes a fried circuit on the color cartridge will cause a out of ink on the black even when the black is new. Double check that you are using the correct cartridge for the printer. and look at the copper/gold contacts in the printer where the cartridge goes. look for dried ink or tears. Clean with a Q-tip dipped in water. CAREFULLY. If it's torn.... enjoy your trip to walmart.
    Aug 28, 2007 | HP DeskJet 1220c InkJet Printer
    Minolta magicolor 2400W Laser Printer Logo
    346 people viewed this question
    Top Minolta Office Equipment & Supplies Experts
    Adorjani Laszlo
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Ben
    Ben
    Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
