Question about Rolleiflex 3001 35mm SLR Camera
Rolleiflex 3003 Battery Pack
I have Rolleiflex 3003. Now over decades the battery back is weak. From I know NO one do the rechargeable battery replacement.
I have 2 film magaziens and battery packs. The batteries can be replaced
Posted on Oct 20, 2013
Where i can find the battery back, for 3003 the batteries can refield
Posted on Jul 09, 2009
2003 Honda Civic Hybrid code P1601, i pulled the codes this morning and i got p1600, p1601, p1449, i dont know what to do can anyone help me with this Thank you
you need a repair book on that car so you can look up the codes or call Honda and see if they will give you the codes and tell you what is wrong is the car even running good you can also take it to auto that has a reader they can put it on and they can tell you what they mean.
Aug 03, 2017 | Honda Cars & Trucks
Envizen tablet EVT10Q won't take a charge. The charging port is loose.
Hello Jennifer Sprigs,
In my decades of playing with "rechargeable" batteries...
(and a bunch of nerd-ling reading... have convinced me we don't know what we think we know (your is LITHIUM-ION)).
Including Lead Acid ... I have accomplished some strange things with persistence... (definition of insanity almost applies).
I'm not entirely convinced that your battery issue is not simply a weak or worn common connector... but I will tell you that
I have achieved some worthy successes in RECHARGING...
Simply by repeated process... applied battery...
Gotten the charge period to expand from a brief flash
(into a descent charging period (inactivity is problematic)).
to a second... to two seconds... to five... (so on & on).
If you have noticed any increase... I'd say to try it again & keep trying.
looked for it ... Envizen EVT10Q Lithium-ion 5400mAh
I have also caved in and bought NEW batteries
(I'm just saying... Check the cost and balance that against how much time you want to FIDDLE AROUND (if available)).
Mar 19, 2017 | The Computers & Internet
I charged my KX-TGA652, it keeps saying use rechargeable battery. Does not seem to hold charge
It does take rechargeable batteries. Remove the back and change batteries for Ni-cad or similar rechargeable batteries. Trying to recharge normal batteries is dangerous. Any rechargeable make of battery will normally work and they recharge when phone is in cradle
Feb 21, 2015 | Panasonic KX-TGA652B Cordless Phone 2 Pack
Nikon Coolpix 5700 was working fine, now it won't turn on. Batteries are fine, but camera just won't power up at all. No error message, nothing but a dead (black) screen. No idea why it won't come on--it's...
Two quick suggestions first is the battery chamber contacts clean make sure they are clean. Are you using a battery pack with rechargeable AA's ? if so check the battery orientation it only takes one out of place. If you are using the rechargeable battery I know you said the batteries were fine but make sure the power is up on the rechargeable. I've had it where I put a battery on charge knowing it was pretty well dead came back 5 minutes later and the light was green, took the battery of the charger unplugged the charger plugged the charger back in and put the battery back on the charge. It then completed its true cycle.
Jan 04, 2011 | Nikon Coolpix 5700 Digital Camera
X box controller keeps turning itself off - I have put new batteries in
Connection problems might be caused by one or more of the following factors:
  • Weak batteries or a weak Xbox 360 Rechargeable Battery Pack
  • Interference from another wireless device, such as a microwave oven, a cordless phone, or a wireless router
  • Metallic objects positioned between the console and the wireless controller, such as a chrome faceplate or metal dividers, shelves, or doors on an entertainment center cabinet
    Note All licensed Xbox 360 console faceplates are tested for interference, and do not interfere with licensed wireless devices.
  • There are already four controllers connected to the console.
uparrow.gifBack to the top THINGS TO TRY Solution 1: Restart your console Turn your console off, wait a minute, and then... Solution 1: Restart your consoleTurn your console off, wait a minute, and then turn it on again.
If your controller is still not working, try the next solution. uparrow.gifBack to the top Solution 2: Replace the batteries or the Rechargeable Battery PackInsert fresh AA batteries, or attach a fully charged Xbox 360 Rechargeable Battery Pack to your controller. If you have an Xbox 360 Rechargeable Battery Pack
  • Remove the battery pack and reattach it to your controller, making sure that it is attached correctly.
  • Press and hold the Xbox Guide button. In the upper-left area of the Xbox Guide button, the battery meter indicates your current level of battery strength. You might need to recharge the battery pack, if the level is low.
If you have an Xbox 360 Play & Charge kit
  • Make sure that the Xbox 360 Rechargeable Battery Pack is correctly connected to your controller and plugged into one of your console's USB ports. If you check both of those things but are still having the problem, try the suggestion below.
  • Plug the charge cable into each USB port on your console, one by one. There are two USB ports on the front of the console and one on the back. If the controller works in one USB port but not another, try another accessory in the USB port that did not work with the controller. If the USB port does not work with any accessory, your Xbox 360 console might need to be repaired.
  • Turn off vibration feedback (rumbling) on the controller. If you play games with feedback while charging, it takes longer for the controller to charge and might drain the battery pack faster than it can recharge. Here's how to turn vibration off.
    1. Press the Xbox Guide button on the controller.
    2. Go to the Settings area, and then select Preferences.
    3. Select Vibration.
    4. Select Enable Vibration to clear the checkbox.
If your controller is still not working, try the next solution. uparrow.gifBack to the top Solution 3: Remove objects between the controller and the consoleThe controller works within 33 feet (10 meters) of your console. However, objects placed between the controller and the console might reduce this range. In addition, objects that use wireless technology (for example, a cordless phone) can interfere with your wireless controller. Remove or relocate objects or wireless devices that might interfere with the wireless controller or console. Here are some things that can cause problems:
  • Microwave ovens
  • Cordless phones
  • Wireless routers
  • Chrome faceplates
  • Metal dividers
  • Shelves
  • Doors on an entertainment center cabinet
If your controller is still not working, try the next solution. uparrow.gifBack to the top Solution 4: Disconnect all controllers and headsetsIf all four rings surrounding the power button on the console are green but the controller has four flashing green lights, four controllers might already be connected to the console. Disconnect all of the controllers, and then try to connect the controller with the problem.
  • To disconnect a wireless controller, press and hold the Xbox Guide button for three seconds, and then turn the controller off.
  • To disconnect a wireless headset, turn the headset off.
  • To disconnect a wired controller or headset, unplug its cable from the console.
To learn more about connecting your wireless controller, please read the following Knowledge Base article: 906947 (http://support.microsoft.com/kb/906947/ ) How to connect an Xbox 360 Wireless Controller to an Xbox 360 console or computer If your controller is still not working, try the next solution. uparrow.gifBack to the top Solution 5: Replace your controllerIf your controller still does not work correctly, it might need to be replaced. Please contact Xbox support at the following address: http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) uparrow.gifBack to the top Additional supportPlease visit the following Web site for information about how to contact Xbox support: http://www.xbox.com/support/contact (http://www.xbox.com/support/contact)
Dec 05, 2010 | Microsoft Xbox 360 Controller
Need to replace battery back-up pack. Have any
Oh wow. You have an old timer there. I think they used a rechargeable 3.6Volt pack so you should be able to use any old rechargeable nickel cadmium or nickel metal hydride 3,6V battery such as out of a cordless phone. try a local electronics shop.
Mar 27, 2010 | Casio Parts Cash Register PC Desktop
Battery Packs for Powerware 9355 UPS
The Batts can be charged externally, then refitted, usually I extend the DC cables so I can work with the batt outside the unit. This is ONLY to be done if you understand the risk and what may happen if you get it wrong.
Batts are always live and can cause fire/explosion/severe burns if shorted!
IF YOU ARE NOT SURE THEN GET SOME EXPERIENCED HELP!
OK so the UPS will not normally recognise a very low batt pack, that is the reason you can not start the test, this test will back of the rectifier so the batt pack takes the load for a short period.
If the batt pack is out of range then this will make the load go off, so the UPS is designed not to allow the test,unless the batt is at the right level.
If you can get the batt pack up close to normal then the unit will recharge it to full.,Wait until it is fully charged before testing.
If this is sucessful the cyle the batt a few times allowing it to reach around low batt warning before recharging. This will assist the batt in recovery. During this process if possible monitor with a test intrument(fluke 123 or 43B will do) the batt pack discharge curve , once the batt pack has dropped to its charge level from float, it should be a smooth decay.
depending on the state of the batts you may be ok, if there are weak ones in the string then you may have to replace all of them depending on the age of the batt pack.
MAKE SURE YOU ARE VERY CAREFUL WITH BATTERIES, THEY ARE VERY DANGEROUS, AND ALWAYS LIVE!
Check you manual for safety procedures, BEFORE working on Batteries.
hope this helps
thanks for using Fixya
Feb 03, 2010 | Powerware 9355 UPS System
Battery pack for Rolliflex 3003? How to replace/repair
First try a "Batteries Plus" type store - you'd be surprised what they have. If that doesn't work you may have to try getting some eager tech school students to build you a special circuit that will "step down" the voltage from a higher voltage battery and use a wired connection to the contacts. Also please provide a review of the camera - it seems like a great 35mm camera.
Jun 14, 2009 | Rolleiflex 3001 35mm SLR Camera
My Xbox 360 wireless controller battery pack broke!
Well as you probably know all there is to a rechargable battery pack from xbox is 2 generic batteries that connect to the plate that connects to your controller. I recently took mine apart to try and fix it because it was not working at all. If you still have the original battery case that takes the AA batteries i would go out and buy a rechargable battery base and charge the cheap *** batteries that xbox uses in their packs. Then use the batteries that came out of the pack and put them in the original harness. Or you could just use the ones you buy.
Feb 08, 2009 | Microsoft Xbox 360 Controller
Rolleiflex 3001 35mm SLR Camera Logo
650 people viewed this question
Top Rollei Photography Experts
Tony
Are you a Rollei Photography Expert? Answer questions, earn points and help others
