Question about Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118)
This card freezes the system
I have never been able to boot the system after installing this card, so installing drivers may also be a joke. When I remove the card, the system boots normal. I am running Win XP.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Two possibilities:
  • IRQ conflict - try installing the TV card in another slot or switch the other cards. Normally, the PCI slot right after the AGP or video card is shared. Preferable location would be where there are no immediate cards already installed right next to the TV card;
  • hardware fault - only solution is to replace the card.
Good luck and thank you for using FixYa.
Posted on May 28, 2009
Asus gt 440 computer wont boot up
Has the card got an additional power socket on the leading edge, make sure you have put the 6 pin PCIX power plug to the card from the PSU.
May 10, 2012 | Computers & Internet
I have Aspire T135 and everytime I boot the PC, it freezes at the Windows XP logo screen right before going into Windows. I checked memory, hdd, cdrom, etc. I installed a PCI slot video card and changed...
try booting in safe mode, and watch as the drivers are opened, as safe mode boots. take note of the last driver or file which it stops on before freezing or resetting, then look up (google) the name of the file or driver (.dll file), to find out where your problem is. if it turns out to be a driver file associated with your phone modem, then it is your phone modem which is preventing the computer from starting.
if that doesnt work, then strip the computer down completely to 1 ram stick, the cpu, mobo, video card (or integrated) and 1 hard drive. disable any unnecesarry integrated components (such as the soundcard) in BIOS, and remove any usb devices or pci cards which are not absolutely necessary to boot the computer (such as a phone modem card, an external hard drive or wireless network card).
the computer should boot once stripped down to the bare essentials and all unnecessary hard ware is disabled/removed. if it boots, then add back/reenable your extra cards, and devices one at a time, until you find the device which is keeping it from booting.
if it will still not boot when stripped down, then it is an essential, such as the motherboard, which is at fault.
Oct 28, 2010 | Acer Aspire T135 PC Desktop
Windows 7 is shutting down my graphics card (Nvidea) ...error 43...and freezing screen resolution at 600x480. Tried updating the driver, restoring the system to an earlier point, tried reboot at last known...
Press "F8" before Windows boot and you'll be presented with Advanced Boot Option. Select Safe Mode and hope it can booted successfully into this mode. Uninstall the related driver and reboot the system to normal mode.
Once it is booted, install the driver obtained from NVIDIA which is WHQL certified for Windows 7. Once installed, reboot your system and hope it works now.
Jul 14, 2010 | Microsoft Computers & Internet
Ragnarok online freezes after installing geforce
probably that your power supply is not sufficient to handle geforce fx5500. you may try to install the latest driver for this video card or if not, try to check if upgrading your power supply will help
Dec 07, 2009 | MSI FX5500-TD256 GeForce FX 5500, (256 MB)...
MSI FX5200-T128 :: Hard-Freeze
You could try using the driver for the FX5200 directly from Nvidia. Maybe the MSI drivers are causing the issue. If not try using the video card in another computer and see if it works. Without testing the card or the board it is hard to say. Sometimes a weak powersupply can cause problems like this. Also make sure if there is a power connection to the video card that it is hooked up. Some video cards need additional power plug hooked up.
Sep 10, 2009 | MSI FX5200-T128 (128 MB) Graphic Card
Computer freezes with black screen
check that all cables are securley fitted to your drives . try unistalling the graphics card , boot up the computer , if it boots up then you will need to install the drivers that came with the graphics card first
Jan 25, 2009 | MSI : 661FM-L P4 SIS661FX FSB800...
I am trying to install a sabrent SBT-F2A 2 port firewire IEEE 1394A PCMCIA Cardbus adapter. When I insert the card while laptop is running, the laptop freezes. When I boot the system with the card...
I checked the sabrent website and didn't find it listed there. If the disk doesn't seem to have drivers for it then I would do one of 2 things
1. contact sabrent from their websites contact us www.sabrent.com
2. check places like driversguide.com and other driver storage sites for your drivers
Dec 02, 2008 | Computers & Internet
Having trouble with my MSI 865pe neo2 motherboard
Dear Slerpie
Im pretty sure you are right when you mention about your BIOS setting.
What you need to do is to remove the graphics card and ensure that the BIOS is set to onboard VGA and save it. Once you have done this, you should try to restart windows, if i fails, then you will need to re-install the operating system.
Once you are sucessfully logged into windows, you can then try installing the drivers for the GPU card (Graphics Processing Unit video card) and then shutting the system down. Once you have powered off the system, you install the card, and configure in the CMOS/ BIOS to display the graphics card on either PCIEX or AGP (depending on your motherboard type) and then restart the system. Windows should then load up with little or no problems at all. Some cards may state that you have to load the drivers after you insert the card, but you can find the manuals for these on the GPU vendor/ manufacturer website.and it is as simple as that
All you have to do is make sure that your card is compatable with the rest of your system environment, and that your monitor is plugged into the correct socket on your video card if you have more than one output. Certain cards have DVI outputs, and if your monitor is VGA, then you will need a 15pin D-Sub male to DVI male adapter/ connector, and these are available cheaply online.
Should you have any issue relating to this upgrade, please do mail/ message me back and i will endeavour to help you on this issue, im available 24hrs a day 7/365 days a year.
I hope this works for you.
regards
oz
Apr 10, 2008 | Intel Motherboard
XP-SP2 hangs on boot after installation
I think maybe better uninstalling driver, but leave card in and boot system and let windows find the card(hardware) first instead of wot sounds like windows looking for driver and freezing in the boot up process as it will look for a connection to internet for an update or driver. Normally any usb periferals should be connected after driver installation, but any pci or agp cards inserted first, then driver.
Nov 05, 2006 | X-Micro Technology XWL-11gCAG 802.11g/b...
Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118) Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
