Question about Durabrand Car CD Player and AM/FM Receiver, DB1200
No wiring harnessfor db1215 cd player were can i get one
No wiring harness i need to know were i can get one
thesoundman
  • 41 Answers
SOURCE: WIRING COLOR CODE
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
Posted on Sep 21, 2007
techman
  • 3130 Answers
SOURCE: 1998 ford el xr6, need stereo wiring harness colours
You did not specify if you wanted the wiring diagram for the Expedition or the Explorer, so I got you both. Good Luck
1998 Ford Expedition Stereo Wiring
Constant 12V+ White/Purple Switched 12V+ Black/Pink Ground Black/Green Illumination Blue/Black Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 6" x 8" Doors Left Front (+) Light Blue/White Left Front (-) Orange/Light Green Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 6" x 8" Rear Doors Left Rear (+) Tan/Yellow Left Rear (-) Gray/Light Blue Right Rear (+) Brown/Pink Right Rear (-) Orange/Red
1998 Ford Explorer Stereo Wiring Constant 12V+ Light Green Switched 12V+ Yellow/Black Ground Black Illumination Light Blue/Red Dimmer n/a Antenna Trigger Orange/Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 5" x 7" Rear Door Left Rear (+) Gray/Light Blue Left Rear (-) Tan/Yellow Right Rear (+) Orange/Red Right Rear (-) Brown/Pink
Posted on Feb 23, 2008
SOURCE: Error Code E-2
*transit screws
er-2 = Mechanism error
manual says that holding down the eject button for 3 seconds may help
Posted on Jul 01, 2008
  • 14 Answers
SOURCE: No wireing harness
Ok everyone,
If your looking for an answer for this I hope this helps.
The connector on the back of the Duraband receiver is the same design as the connector used on
most computer power supply connectors for the motherboard.
You can cut off the old connector for the PC power supply, and then cut off as many extra pins as
needed so it will fit into the back of the receiver.
Only thing is you will need to re-label each wire according to your old harness that may be damaged.
If ANYONE has the existing harness, and would like to tell us which pin goes to which color, this would be great. Most of the receivers have a color code on the case bottom, but it doesn't identify which color corresponds to which pin... please help...
Randy
Posted on Oct 05, 2008
etirbynnor
  • 655 Answers
SOURCE: Need wiring harness color coded diagram for pioneer dehp6800mp.
Hello randscates,
Here's a link to the manual. The wiring color code for the supplied harness is on page 78. The diagram is rotated 90 degrees clockwise. I recommend that you download the PDF and print out the page you need.
Hope this helps.
Posted on May 16, 2009
Instructions on installing durabrand DB1215
Why did my db 1215 not come with wires so I could install it in my car?
Oct 17, 2009 | Durabrand Car CD Player and AM/FM...
Need wiring plug for a model DB1215 am/fm/cd receiver that was lost but we want to keep the radio unit
Just bought the DB1215 Model--Can you tell me what is the best size speaker to use and how many?? Thank you Dan
Oct 12, 2009 | Namsung Car Audio & Video
Installing a cd player in a 1992 honda accord
The harness looks like what is depicted on this link: http://cgi.ebay.com/JVC--16-PIN-WIRE-HARNESS-FOR-CD-PLAYER-BLACK-BRAND-NEW_W0QQitemZ370214069143QQcmdZViewItemQQimsxZ20090612?IMSfp=TL090612198008r8862
This connector fits the following JVC Car Radio/CD/MP3 Players with 16 pin connection.
All wires are labeled.
Hope this helps....................sodeep
Jul 26, 2009 | JVC KD-G220 CD Player
Difficulty wiring into GM harness
well if your trying to actively wire it up with the car battery still connected that is why you are blowing fuses. just a heads up too if you have a live connection while hooking up the cd player you could short out other electrical devices and you could be in alot more trouble thatn just blowing fuses. the black wire is what is blowing fuses its because you have it hooked up wrong to a wire that is sending voltage not recieving voltage. ground the black wire to the actual chassis instead of hooking it to the ground wire from the harness or whatever color its grounded to which shouldnt be anything but black if you have the black wire hooked up to ANYTHING that isnt black that is why you are popping fuses. so hook up the red yellow and make your own ground you shouldnt have any problems after that.
May 08, 2009 | Car Audio & Video
WIRING CHANGE FOR 2002 DODGE CARAVAN
Your best bet on that one is to go to a place that sells car audio systems or even some autoparts retailers have them,and get the proper adapter harness already made up. A few more dollars but, a whole lot less headaches.
Mar 06, 2009 | 2002 Dodge Caravan
Wiring/Installation of Pioneer CD Player
You need to get an installation kit that also has the universal wiring harness to connect to the factory harness in the car. That way you only need to match the wire colors of the Pioneer harness to the wire colors of the universal harness and made good connections and insulate those connections. Then the Pioneer harness plugs into the Pioneer radio and the universal harness plugs into the factory harness in the car.
Let me know if this helps, or if you need more help.
Dave
Jul 06, 2008 | Car Audio & Video
Error Code E-2
theres 2 screws on top of the unit called teansit screws. remove them, if that isnt the problem then return the pos.
Jun 14, 2008 | Durabrand WD268 Cassette Player
Help
need cables that go from receiver to car wires. can you please help
May 16, 2008 | Jensen CD-2010X CD Player
Replacing car radio
you need to get a wiring conecter kit. the directions will be in the box. i just got mine today and had to get one of those kits... walmart has them =P
Dec 24, 2007 | Car Audio & Video
Car Audio & Video Logo
110 people viewed this question
Top Durabrand Car Audio & Video Experts
matt martin
matt martin
Are you a Durabrand Car Audio and Video Expert? Answer questions, earn points and help others
