Question about Mitsubishi WS-55515 55" Rear Projection HDTV
Picture and sound go out and remote isn't working properly
I have a 2002-2003 Mitsubishi WS 55511 1080HDTV, all of a sudden the remote doesn't want to function properly. Also, the picture goes black and the sound goes out then goes on and off quite often. There are times when the screen looks like a VCR picture that isn't tracking then goes black. Sometimes it will display "Check Connections or power. The connections for RGBHV or Y Pb Pr may be invalid." then the messages goes away. It does this with DVD player also, but the sound and picture go out, it too can look like a VCR picture with tracking problems. The TV is controlled by a Crestron WiFi remote. Sometimes the TV will not power off with the Crestron remote. Also, recently the Mitsu TV remote will not allow changes in devices or will not bring up the device menu. The batteries are new too and I have reset the TV also. I have DirectTV, no changes have been made to the unit or anything moved or unplugged. Any ideas of what might be the problem?
    Problem Solver:
  • 10 Answers
I've had this problem with other tvs and it was caused by the power supply board starting to go out. May want to call tech support to verify. Note that these board are very expensive unless you buy used.
Posted on Apr 21, 2010
  • 126 Answers
Take the original Mitsubishi remote and remove the batteries. Install new fresh batteries and then try to operate the set. Do not try to use any of the inputs that are active. Just check menu funtions with the mits remote. All kinda irrational stuff happens when multiple and universal remotes get involved. If this a model remote that has a selector switch at the top for choosing tv/sat/vcr, etc make sure it's on tv.
Posted on May 28, 2009
I own a WS-48413 Mitsubishi 48" projection TV that has been working great for 7 years. Now all of a sudden there is no sound, only a picture. Tried to trouble shoot with the manual, but no luck. Is...
amlupo,
If the picture is good and you use Comcast as your cable supplier I believe that your Comcast converter box is bad. This is a very common problem and an easy one to fix. Call Comcast and tell them the problem and they should replace the box for free.
Thanks for using FixYa and for the great rating.
hardrocko
Apr 05, 2011 | Mitsubishi WS-48413 48" Rear Projection...
Mitsubishi WS-65511 volume control has gone crazy. All of a sudden volume went to full blast and now with manually pressing volume button it is either full volume or lowest volume. We have DISH and...
Mitsubishi WS-65511 volume control went crazy after a storm. Now we don't having any volume. None of the controls are working on the front of the panel with the exception of the device control.
Jun 02, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Ws-65909 picture and sound are fuzzy, will a new power supply fix it???
It does not sound like a power supply problem. Most of the boards for this set are no longer available from Mitsubishi.
The most common problem these sets have is called convergence. Go into the customer menu with the Mitsubishi remote and select convergence--enter the "advanced" and look at the grid of lines (set will have on screen instructions for this) Let me know more exactly what your picture looks like.
If you need more help or advice rate this solution as I do this here for Free. Reply here and I will help you.
Regards, SD TECH
Nov 27, 2009 | Mitsubishi WS-65909 65" Rear Projection...
WS 65313 Mitsubishi went black all of a sudden
hold down the menu and input buttons after it shuts off it will flash with a code. call tv repair place and they can tell you what code means.
Jun 04, 2009 | Mitsubishi WS-65313 65" Rear Projection...
Mitsubishi WS-55513 55 in. - Picture to latge for scheen
Change your Display Format (widescreen mode) . You're using ZOOM. Press FORMAT on the TV remote control to cycle through the available display formats.
Feb 09, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-65809 turns off right away
check the collector drop on Q29a002. If it is less than 16 nano amps, repl ic u12 in conver circuit. stk392-570 and pico fuses f04 and f05 24v circ
Jul 28, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi WS-55807 TV won't turn on
It s a Power supply problem.If you are not familiar with electronic repairs take it to an authorized repair shop.
To get a service manual see link
Download Mitsubishi WS-55807, WS-65807, WT-46807, WS-55857, WS-65857, WS-55907, WS-65907, WS-73907 Service Manuallockmanualsdnw_en.gif
Login or Register to get access all drivers database.
Please be sure to enable cookies.
Feb 21, 2008 | Mitsubishi WS-55807 TV
Mitsubishi ws 65807 sound with no picture
push qv and 9 on your remote and a screen will come up and follow the directions to correct your problem.
Jan 05, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Ws-5511 Mitsubishi
On these models we have found that a switch is sticking on the control panel not allowing the set to operate properly.
Disconnect the control panel.
You will be able to use the remote on it.
To find the plugs for the control panel:
Remove the speaker grill and front panel, then follow the wire to the connection.
Remember to unplug the set before putting your hands inside of it.
Dec 13, 2007 | Mitsubishi WS-65908 TV
Mitsubishi WS-55515 55" Rear Projection HDTV Logo
161 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
