Question about Viking VIPR101 Kitchen Hood
Viking downdraft ventilator electrical problem.
I have a Viking VIPR101 domndraft ventilator that has completely stopped working. Blower and lifting motor are both inoperable. I have checked that there is power to the unit, and it is not obstructed in any way. This would appear to be a blown fuse or circuit breaker inside the unit. Where is the fuse and how do you access it?? I have v1vd500 downdraft, its really bogus how they made this equipment, they don't need a circuit breaker, they did this so you would eventually have to spend money. It is the circuit breaker and you have to take the whole thing apart. We have circumvented ours. Viking is rubbish, find a good friend who can help you.
    Problem Solver:
  • 5 Answers
You seem to have a slightly different model, but see a solution at:
http://www.fixya.com/support/t410261-viking_downdraft_ventilator_electrical
it is probably the same thing
Posted on Jan 31, 2010
Power at the plug, no response from "on/off" button.
Follow the power line with a tester, see where it is interrupted
Sep 16, 2015 | Viking VIPR162 36" Downdraft Ventilation...
Downdraft ventilator has stopped working
We have a Viking VIPR101 30" downdraft ventilator. We've learned that the ON-OFF switch on the side of the ventilator can overheat and burn out when it is held down continuously (poor design). Best to push and quickly release it. First time we had the switch professionally replaced--it's modular and very simple to swap out. Next time we fixed it ourselves with switch part # PV300182 from allvikingparts.com. They had replacement guidance on-line. Hope this is useful.
Mar 17, 2015 | Viking VGRT360-6B 36 in. Gas Cooktop
I have a wolf dd36i downdraft cook top ventilator just stopped working it has power and the switch is conected to the remot e
WOLF DD36I USER MANUAL Pdf Download. - ManualsLib
www.manualslib.com > Brands > Wolf Manuals > Cooktop > DD36I
View and Download Wolf DD36I user manual online. ... cooktop. Wolf downdraft ventilation systems are recommended. for use with Wolf electric ... The downdraft will operate most efficiently when ductwork does not exceed 40' (12 m) in length.
Feb 16, 2012 | Viking VIPR101 Kitchen Hood
30" viking downdraft goes up & down fan runs and will not responed when pushing on touch panel
After 11 years of use, the same problem just happen a few days ago - fan keeps running, doesn't respond to the on/off switch. Also cannot reset filter alert. As far as I can tell the entire switch panel isn't working. Or worse, shorted out. Might have to replace the ribbon and some switches.
For example the switches can be found at AllVikingParts.com For example --> http://www.allvikingparts.com/Button_Switch_Assy_p/pv300182.htm
There's a another thread on this forum: http://www.fixya.com/support/t410261-viking_downdraft_ventilator_electrical
I'll post the exact solution as soon as I have it figured out completely.
Mar 11, 2010 | Viking VIPR101 Kitchen Hood
My Viking VIPR101 Downdraft Ventilator is not working.
It's fixable, but it is easier for them to just sell you the whole expensive part. See the problem and solution at:
Jun 04, 2009 | Viking VIPR101 Kitchen Hood
Viking VIPR101 will not go up or down
Oct 18, 2008 | Viking VIPR101 Kitchen Hood
Downdraft blower quit working
replace whole unit thats roughly what the whole unit costs 157.00 just a little secret there they dont tell you cause they mark up the prices i worked for the company that sold and installed this equipment you also remember tax
Jun 01, 2008 | Kenmore 59940 Kitchen Hood
Folks,
I just took mine a part due to the same problem. I am an EE, so I have some experience in this matter. The problem was indeed the membrane ON/OFF switch. This switch is basically just stuck on the panel like a sticker. You can literally just pull it off and stick it back on. Underneath it is 3 metal "buttons". When you press it, one of these buttons presses on a flex circuit to complete continuity. This send AC line current down to the lift motor under the gear box cover. The lift motor starts moving. After it starts, a cam hits a relay switch, which completes the circuit thru the relay. This is what keeps the vent moving up after you let go of the On/Off Switch.
At first, I through I could just clean the switch up. I figured crud got down in there. But it did not work. I looked at the switch under a microscope, and the problem is the flex circuit was actually burned thru. This is usually caused by a weak spot in the flex combined with too much current. My best guess is this switch is undersized for this application. The switch will also allow current to flow even when the relay takes over, based on how it is wired. I'm not sure I like this, as if one tends to hold the button is all the way up or down, then that just more current thru the switch for a longer time which means more heat and better change of burning thru. Of course if the switch was better quality or design, it wouldn't matter in he first place.
Anyway, I'm going to take the switch to my lab and try and put a jumper wire across the burned area. This probably will not work or it will just burn in another place in the future. So I'll probably have to get another switch. The problem will be finding a good looking one. All one needs is a Single Pole Momentarily ON switch for the application. From it, run the 2 wires the control board connector (polarity does not matter). It is all pretty apparent once you take the top cover of the vent off (4 screws, 2 each side). The cable that runs from the control pad to the unit below uses a S-Video type connector and is keyed, so you can't get it back on incorrectly. Total cost in parts will be very minimal
For you DIY, remember there is AC voltage levels running thru this switch. Make sure YOU TURN POWER OFF when working on it and know what you are doing. You can get shocked.
Mark
Feb 24, 2008 | Viking VIPR101 Kitchen Hood
Filters for the Kenmore Downdraft Blower
CAN YOU PLEASE GIVE ME THE RIGHT CUTOUT FOR THIS DOWNDRAFT
Nov 13, 2006 | Kenmore 59940 Kitchen Hood
Viking VIPR101 Kitchen Hood Logo
662 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
