Question about Canon Cameras
My camera doesn't work even with new batteries
I have a powershot A560 and I have used many batteries and my camera will either not work or just work for a few minutes
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixY,
Initially:
  • clean the battery contacts of the camera using Q-tips and/or cotton buds dipped in alcohol;
  • depending on the length of time in service, these contacts may have developed a resistive film over itself. It may be necessary to scrape this off the contacts to expose fresh metal;
  • in some instances, it may even be necessary to slightly bend / stretched the battery contact so as to afford them more pressure to the batteries.
Should none of the above be corrective, then it would most liekly be an internal electronic fault.
Good luck and thank you for using FixYa.
Posted on May 28, 2009
It doesn't power on
Your camera can be defected. If you buy new batteries, and it still doesn't work, than you'll probably want to send it back to the manufacturer. First, call them and tell them your problem, and if that doesn't work, than you might want to carefully examine your camera, to check if everything is in the correct place, and their all working correctly.
Jun 11, 2012 | Canon PowerShot A560 Digital Camera
We have purchased canon power shot A560 camera. While using the camera batteries are discharging immediately even without taking shots for some times. Pl explain the reason. We are using KODAK AA NiMH...
Hi, these are known issues with various Canon PowerShots
LCD eats up lots of power.. if there is a dim option use it or shut it off completely
1st Reset your camera to the manufacturers setting.
2nd Make sure your battery setting is on the correct configuration (can be found in settings -setup)
3rd Take a look in your battery compartment to see if there is any residue, if so
clean with a qtip and isopropyl alcohol
Jan 23, 2011 | Canon PowerShot A560 Digital Camera
My Canon PowerShot A560 says that the memory card is locked...even after I change the batteries. What can I do to fix it?
Have you tried the switch on the side of the SD card in both positions? Failing that, the camera will need a new SD slot fitted by repairer.
Jun 02, 2010 | Canon PowerShot A560 Digital Camera
CAMERA WON'T TURN ON. I HAVE NEW LITHIUM
Things to check first are battery contact points, and micro switches that are located on the battery and memory card doors. Details on what needs to be checked may be seen here. It won't work for every case, but it's worth a try.
Nov 01, 2009 | Canon PowerShot A560 Digital Camera
Batteries wear out quickly
most cameras use alot of energy so it could be normal but you may be using batteries that dont put out enough voltage. your rechargeable batteries may be wearing out (as they all eventually do). i suggest trying out duracells. the computer may have just reconized the old camera so it knew what to do but since you got a new one, your computer doesnt reconize it.
Aug 07, 2009 | Canon PowerShot A560 Digital Camera
Powershot A560 overheating
change your batteries our contact your customer care
Jun 20, 2009 | Canon PowerShot A560 Digital Camera
Low or no power even with new batteries
when you dropped it, it may have nocked something loose.
Apr 11, 2009 | Canon PowerShot A560 Digital Camera
Low battery
Digital cameras are like miniature computers, constantly processing large amounts of data, their power requirements far exceed film based cameras and conventional batteries are simply not up for the task. I have seen plenty of times where someone has bought a brand new pack of cheap batteries which fail to even turn on a digital camera! You are best to spend your money on a set of rechargeable Ni MH batteries. They will pay themselves off many times over and will reduce unnecessary landfill. You can of course still buy disposable if its more convenient but you really do have to spend up on top of the range quality to get any good use out of them. Also be aware that cameras using only two batteries (such as the 560) are more demanding again on battery performance.
A5560 Noman
Hi , chlean the battery teminals with cotton tip , use rechargeable battery nickel hydrite typical 2500 mAh you will satisfied.
Jan 15, 2008 | Canon PowerShot A560 Digital Camera
Unable to open the flip to insert batteries as well memory card
Push release button then move the battery cover to the right to release the cover. Don't pry straight up.
Nov 17, 2007 | Canon PowerShot A560 Digital Camera
Cameras Logo
60 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
