Question about Acer Aspire 5610-4648 Notebook
Black screen and previous problems with ACER Aspire One (XP)
Hello!! I have an Acer Aspire One and during the start up process the screen works I can see the Windows Logo and Bios, but after that the screen black. I can heard from the Audio that the Windows (OS) works. I NEED HELP, PLEASE!!!!!! I have had a similar problem, and previous ones as well. A couple months after getting acer aspire one (xp), when powering up it would often make a loud whirring sound (kind of like when a cd/dvd player starts up). It was intermittent and I didn't get it in for repair. Started happening less frequently. Recently it would not power off without me removing the battery and then last week the screen went black. Still regular whirring sound inside but not even a flicker on the screen. And have to remove the battery to power off. Anyone have any resolution with Acer yet on this issue?
  • 489 Answers
Aspire One uses Atom process and its very small. it get hot easly and there is a fan on it also fan is so small. you need to change to fan. take the service.
hope it work
Posted on May 28, 2009
Hi, my acer aspire one netbook can't open XP and it says netbook acer aspire one Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM You can...
The Acer Aspire One Netbook has a hidden partition containing the files required for restoration to the original factory condition. The restoration clears all user data from the C: drive and requires that you have the netbook plugged into its AC adapter as the process takes significant time during which it should not be interrupted at the risk of hard disk corruption. To begun the process....
1. power on the netbook while it is plugged into its AC adapter
2. during power-on, while the Acer Logo is showing, press Alt and F10 together several times
3. Acer eRecovery loads showing the Windows screen momentarily
4. follow the on-screen directions and make the selection to recover the factory default image
Apr 10, 2011 | Acer Computers & Internet
Hearing continuous beep sound at startup that disappears on Esc
I started having the smae problem yesterday with my Acer 1410 bought end of 2009. It started after I had stoped some suspicious process to work on start up (using msconfig). During the night I scanned the computer for virus but found nothing. Tonight I will enable those process to work on start up again and see what happens.
I will post the information tomorrow.
Aug 02, 2010 | Acer Aspire One PC Notebook
Hello i have an Acer Aspire One model zg5 netbook
You're going to need to boot it from the Windows XP installation disk, which means if you don't have a CD drive you'll need to get an external CD-ROM drive. This will fix the problem.
Jul 16, 2010 | Acer Aspire One PC Notebook
My acer aspire 4315 hangs during shutdown. windows XP OS
This happens when there is a process still trying to work in the back end.
Try to disable most of the applications which get opened by default when windows starts.
Click on start/run/ and type msconfig. Once the window comes up click on start up tab and disable all.
Now try to reboot the system.
Also hope there is no usb device connected at the time of shut down. This would also make xp hang.
Thanks
Mar 01, 2010 | Acer Aspire 4315 Notebook
ACER Aspire One screen black out after OS start up.
start the notebook in safe mode and change the pixels to a lower pixel
Dec 27, 2008 | Acer Aspire 5610-4648 Notebook
ACER Aspire One screen black out after start up.
OK, Not sure about the Aspire One, But I had the same problem with the Aspire 5610Z.
I simply found the Bios battery and with a small screw driver, created a short circuit of the bios by touching the two leads (just for a couple seconds) from the Bios Battery to the Motherboard. And It Works Fine Now!
Be sure to Disconnect all power from the laptop, and remove the Battery before doing this.
You can do as I did and download a free manual of your laptop which shows you where the bios battery is located.
Good Luck ô¿ô
Error Message : insufficient system resources exist to complete the API
boot your system in safe mode by pressing f8 key repeatedly during the booting process then select safe mode and press enter then go to system restore option, and select system restore, then select some previous date where system is working fine, restore it
how do you like the solution please rate it
Oct 12, 2008 | Acer Aspire 3680 Laptop
Black screen with cursor acer aspire 5315
start your laptop in a safe mode by pressing f8 during booting, the restore your system to a back date where its working fine
Sep 30, 2008 | Acer Aspire 5315 Notebook
Acer comp
Reboot the computer and during startup start pressing the F8 key until the boot menu appears. Then select "Last Known Good Configuration". The PC will reboot on it's own and hopefully be fixed. Hope this works for ya.
Sep 05, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5610-4648 Notebook Logo
205 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
