Question about Canon Cameras
I will but in new batteries and the camera works for 2 min and then stops
Put in all diffrent types of batteries and it works for 2 min and then stops.
    Brigadier General:
  • 6,966 Answers
Hi again,
Please check your other posting here.
Posted on May 28, 2009
Video camera PANASONIC G200EN long time not working now when i put play work for 10 min and go off put again on does not come on
batteries degrade over time when not used and sounds like not fully charging. i'd get a new battery firt as very cheap on ebay i just got a samsung dv camera battery for £2.50 on ebay
Sep 19, 2016 | Panasonic Video Cameras
I have a polaroid i634 that has an issue with power. Initially I put in alkaline batteries and it worked for awhile (or at least as long as my daughter used it). Then it stopped working. I was told to use...
Hello ..
I hope that really problem with charging.
However, it look like cause from battery. Whatever type of new battery that you used, that no meet the requirement as original battery that included with camera. During testing the camera, they also don't use other battery except that original battery. Maybe it seem like have same power, But it chemistry is different. However, you can try using same battery from polaroid also.
TRy look this..click here
I don't want to scare you, but is good to have new battery same like original and also from same company. As long you are using other type battery, It maybe will effect components in camera. So beware and careful.
If you think that charging is problem. THen try recharge back around 8hours. However if u are using external charger. and not using camera to charge battery.If you only can charge through camera, try recharge around 2-3 hours. Pull out battery from camera. place safely and avoid any magnectic environment . Around 2-1 hours, charge again 2-3 hours. After charge, around 10-15 minutes, try used it. It still have problem? If still face same problem. I advice to find suitable battery.
Jul 06, 2011 | Polaroid i634 Digital Camera
I bought a polaroid pdc 5055 today from a second hand shop,as it has no manual i dont know how to use it,but i put some new batteries in and they lasted 1-2 mins! do i need to use rechargeables or any...
Here is a link to download a free copy of the manual. You can go through the manual and see if you are required to use a special type of battery or if it is just faulty.
Hope this helped?
Jan 28, 2011 | Polaroid PDC 5055 Digital Camera
How to reset house alarm after power cut
alarm may be in battery back up mode when power is lost it will automaticly start running off these batteries that are usually located in the panel. diffrent devices have diffrent ways or restoring regular mode. i would contact the maker.
Feb 27, 2010 | Lorex 4 Channel Business & Home Security...
Hello
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 02, 2010 | Kodak EASYSHARE M1063 Digital Camera
Flas not working, wrong info on displa
Here are the steps:
3. Without the memory card,turn on your camera.
4.Set the flash to iconfillflash.gif.
If issue persists, call 1.800.235.6325 for repair.
Thanks.
Neerak21
Jul 21, 2009 | Kodak EasyShare Z740 Digital Camera
Everytime i turn on the camera it goes right back out
ok honestly our camara type is a ***** they need the perfect batteries and dosent take just any brand chargeable batteries are a waste because our camera will reject them no matter what try a diffrent brand
May 25, 2008 | Polaroid PhotoMax PDC 4055 Digital Camera
Battery Peoblem
Are you using the correct type of batteries - normal alkaline are not powerful enough Do check out your manual.
May 02, 2007 | Olympus Camedia D-390 Digital Camera
Batteries are going dead within 5 min
What type of rechargables are you using? Ni-Cad are reputed to have a 'memory' so that if recharged whilst not fully run down this is accumulated so that only the new bit of charge is 'active'. So-put the batteries in a torch and leave it on until the batteries are completely flat, then recharge. And/or get a couple of sets of Ni-Mah rechargeable and a suitable charger and start afresh.
Apr 27, 2007 | Fuji FinePix 3800 Digital Camera
Cameras Logo
21 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
