Question about Hitachi H65XXX 1 - 1/8 " Hex Shank Demolition Hammer
Need manual for Hitachi Demolition Hammer
Anybody know where I can get a manual for a Hitachi Hex
Demolition Hammer - H65 1 1/8, 11.4 amp.
Thanks in advance for your assistance.
  • 2,005 Answers
How to put oil in Hitachi H65
OIL ?? I think Hitachi has always a yellow grease lubrication
hitachi grease demolition hammer Google zoeken never seen heart of oil in Hitachi demolitions. but there could be models in your Country thats new for me .
Otherwise BOSCH HILTI and the one and only brand DUSS demolition hammers and also a few brands of Chinese hammers need oil lubrication . an expensive sinc-free hydraulic oil the same as used in some pressure washers life lasting oil but for HItachi look at the link for the grease 2 tubes a enough . good luck and dont forget the piston pin to replace with a new not only the gaskets and o-rings and also the oil and dirt seals on the front where the striking pin is that must be absolutely not air leaking because all your work burns in a few months again out . you can start all-over again.
May 15, 2014 | Hitachi H65XXX 1 - 1/8 " Hex Shank...
Chisel is stuck wont come out
Remove chuck assy and see if it will release, it might need a bit of help with a vice. If not then it will have to be taken apart and pressed out.
Feb 07, 2013 | Hitachi H65XXX 1 - 1/8 " Hex Shank...
I have a Rockworth 1500 Rotary Hammer Drill something has broken inside the SDS chuck, it may need repairing. Is there anyone in the Bedfordshire area.
I have seen many versions of this hammer with many different mfg names. I believe that this is a China copy of a hitachi hammer. No parts are available for this tool. The tool looks substantial from the outside, however internal parts are weak and break/burn out very easily (unlike the Hitachi/Japan version which is a workhorse, years of use before failure). If your hammer is china version, do not invest any more money because other parts will start to fail (most fail within short time from motor burn or broken parts ).
Aug 02, 2011 | Hitachi H65XXX 1 - 1/8 " Hex Shank...
What kind of oil can I use in my hitachi H65?
Hitachi hammers use 30wt non detergent oil. But you can use lighter oil in cold climate. If too much oil accumulates in hammer, it may just come out bit retainer or build-up inside gun. Oil enters the hammer by wick process, of wick is missing oil will enter too quickly. If your brand label is glued on, you may have a hitachi copy from china (most hitachi labels are rivited on). China hammers may use different oil.
Jul 29, 2011 | Hitachi H65XXX 1 - 1/8 " Hex Shank...
This demolition hammer will make the sound like is rotating inside to do the hammering motion, but the shank doesn't do anything at all. what could cause this problem? Thanks.
Large hammers have an air driven piston (an air cushion betweem pistons) and an intermediate anvil that actually hammers on bit. If the cylinder and air cushion piston are dry there will not be enough suction/pressure between the driver piston and driven. Remove lower part of hammer and lube with electric hammer grease. Make sure that orings fit snuggly and the anvil is not jammed. Do not store hammer with the bit pointing up because the driven piston will slide down cylinder and hug driver piston. If the hammer was stored pointing up, turn hammer around and place in stand with nose down in a warm location so that the driver piston will drop into place. Good holidays
Dec 17, 2010 | Hitachi H65XXX 1 - 1/8 " Hex Shank...
I need the parts for rockworth power task 1700w
Hello I need a new trigger switch for my Rockworth PowerTask
serial no uk004984 ARPD1/OOK. On the switch itself inside it has HY15C. Please put me in touch with your on parts division. Thanks.
Jun 13, 2009 | Hitachi H65XXX 1 - 1/8 " Hex Shank...
Important features
power, raw strength, comfort and vibration
Aug 27, 2008 | Hitachi H45FRV Round Hex Demolition Hammer
Hitachi H65XXX 1 - 1/8 " Hex Shank Demolition Hammer Logo
999 people viewed this question
Top Hitachi Hammering Experts
John Trevino
Jim Goldsmith
Jim Goldsmith
Are you a Hitachi Hammering Expert? Answer questions, earn points and help others
