Intel ASUS P4P800S-X 848P Socket 478 DDR 400 ATX Motherboard 3-in-1 Combo (P4P800SXCOMBO) Logo
Anonymous Posted on May 28, 2009
Asus p4p800s-x won't boot and no display on the monitor..
I have an asus p4p800s-x mobo, my problem is.. it won't boot.. there is the green light powered on when I connected the power supply plug but when i push the power switch to turn on the computer it will just power on but it will not show display on the monitor.. and i don't see any boot signal on my keyboard.. i've tried to change my graphic card, memory and even up to cpu.. but still don't work.. anybody here could help me?? please.. is this something to do with the jumper..?? i've also tried to remove the mobo's battery and switch it on..turned off.. then return battery back and switch it on again.. it just powered it on, cpu fan is moving same with the graphic card's fan..please..what is the possible solution to solve this problem, aside from keeping it rest forever in the trash bin..
  • Anonymous May 28, 2009
    hello sir.. what would be the recommend volt for this.. i'm currently using 300 watts psu.. please suggest.. thanks..
    i don't know what recommended watts to use for this mobo.. i might burn my mobo if i use the wrong volt.. my mobo is working fine before with just a 300 watts of power supply unit.. until then.., it just happen when i turned on my computer lately it does not show any display on the monitor..i suspected my video card, i tried to replace it with other working video card but still no work.. then i noticed that there is no boot signal on my keyboard whenever i turn on my computer..help please..
Anonymous
Level 1:
Teacher:
An expert who has written 2 tips or uploaded 1 video tip.
  • Contributor 27 Answers
  • Posted on May 28, 2009
Anonymous
Contributor
Level 1:
Teacher:
Answers
27
Questions
Helped
14538
Points
80
Get a better power supply, as i understand it, youre computer is getting too little power from it. pick a power supply with more volt
Sata hard drive not support
The hardware of your system need more hardware capacity and some slots on the mobo for the sata cable.
1helpful
ASUS P4P800S-X SATA problem
It could be a bios thing have a look a there for a option to chage from IDE to SATA
Asus p4p800s-x mobo will not post re:cpu upgrade
Try to reset the BIOS, this will force a redetection of the cpu. If it's the same after that then either the cpu is bad or its model isn't supported by the BIOS - try to upgrade it using an older cpu.
2helpful
2answers
Recommended psu wattage inreplacement to 300watts psu for asusp4p800s-x
the needed wattage is directly linked to the componets you want to use other then the mobo itself. the main power surges are the CPU (takes 40 to 110 Watts) a graphics card (from 5 to over 150 Watts) the Drives (about 25-30 Watts eachs), the RAM and all the other addons and gadgets you build into your PC. Just add the different Wattages together and give it quiet some headroom. I usually drive this kinds of mobos with 400-550 Watts PSU to be on the save side, if i use a more or less "standard" graphics card, and even more with high sophistcated cards or lots of drives or such.
if you "see" low power (Volts) it might also be a problem with a partwise defective PSU.
1helpful
2answers
Asus P4P800S-X IS RUNNING LCD SCREEN IS BLACK
First thing is check the monitor by replacing it with any working monitor. If that does not work remove the Graphics card and do the same. The problem will be either in the Graphics card or the monitor....sodeep
No display on my asus P4GE-MX mother board
Is there any beep from the motherboard? First thing that you need to check is the RAM. unplug the power cord and remove the RAM. Now, plug in the power cord and try switching the Comp and see if there is a any sound from Mobo. It should idealy warn you that there is no RAM with continous BEEP. If that happens, the Mobo is fine.... Grab a new RAM and try it out. The system should boot now. (If there was "No RAM warning beeps" when you switched on the system without RAM). There are many issues that may put down the Mobo but in most cases its the RAM that stops functioning... Try this and see if it helps. Please post your result here so that we can see if you need further assistance.
Troubleshooting no screen output, please help
sounds like your system is not booting, that may be, obiusly you just have power but that's it...no boot routine. hope somebody else could help on "how to make sure your system can boot again, then the rest.
Motherboard will not display video!
remove everything except for video card and memory cd hard drive etc give it a try
if it shows boot screen you have problems in something you disconnected retry one at a time
if not try different video card
10helpful
Download sound drivers
My mobo is MS-6763 ver 1.0 M-ATX, internal sound. After formatting to a new win XP pro, no sound was detected. I need to know is it the mobo itself need a driver or i have to install only the sound driver. Pls help me to find a solution.
Motherboard
How about your screen; is it good?
Your monitor cable, is it damaged?
Does the computer beep, to tell of booting progress?
Is the new MoBo really new? What about the video card?
Try different RAM. Bad RAM will not let a computer boot.
Try booting the MoBo out of the case: lay it out on wooden surface and plug in power supply and monitor, then turn on. Listen for beeps, HDD cranks. Also watch the screen.
Come back after doing these checks so we can isolate the problem.
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
