Question about Nikon COOLPIX L10 Digital Camera
Lens Error! My camera died when I was filming. I have never had a problem with the lens going in and out. Now it says lens error and thats all. Help?
  • 744 Answers
Hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u rate me as fixya!!!
Posted on May 28, 2009
It has a flashing E, it will not take pictures, the lens does not retract any ideas please?
Flashing E error Mean Lens Error.
Either shutter lens is damage due to weak magnets in the Coil which activate the shutter lens blinking function.
Mar 19, 2015 | FUJIFILM Instax 200 Film Camera
I'm getting an FEE symbol on the window when I turn the camera on and ready to take a picure.Nothing happens. No click. This an N65 Nikon not a digital
You will need to go into more detail.
Do you have film loaded and how many shots have you taken.
Is this equipped with a motor drive? Are the batteries fresh?
Please be specific and detailed.
Thanks,
Worldvet
Jun 24, 2008 | Nikon Cameras
Fuji film finepixF480 showing focus error
Possible that the lens mechanism is jammed , sometimes the flexible connector of the lens focus/zoom can be faulty.You try to check for some tips from the link below; http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 30, 2011 | Fuji FinePix F480 Digital Camera
When i turn on my camera it says lens error and the lenso stays half way out
Hi.
If the lens do not extend completely, then problem is lens itself.. When this happens the motor is unable to retract or to extend the lens either because one of the lens rings is damaged, or because of dust inside lens rings.
Sometimes lens error occurs because batteries are nearly drained and insufficient power to lens motor. This will cause the lens rings getting out of alignment and you get jammed lens. In other cases the lens gets jammed either because of dust or dirt or because of a mechanical problem.As a result the camera freezes with lens half of the way out.
In some case the len
s can be unjammed manually (see the tips below), more commonly the lens and the camera must be disassembled and there is no other way to fix the problem.
Try the tricks below. They rarely work, but you never know:
Test always with fully charged batteries you need as much power as you can get to unlock the lens. Ensure that batteries are Alkaline or good working rechargeable.
If there is dust or sand in lens blow air with a compressor on top the lens..
Sometimes methods like helping the lens movement while turning camera on and off works, but this methods can do more damage to the camera. Help out the lens while turning the camera on.
Remove the battery, point camera to the floor and put back the battery while holding on button and still pointing to the floor. Turn on this way and see if it works.
Connect camera to USB (that gives extra +5V power) and turn on still pointing to the floor.
You find some more detailed hint using the links below. The links refer to digital cameras (no film). In your case disregard all the parts that do not apply( e.g some hint is for lens not retracting - the cause of the problem is the same and I reported the link).
Lens not retracting on digital camera.
Fixing Lens Error.
Lens Error.
Most of the time the lens error must be repaired disassembling the camera. Sometimes lens rings must be replaced. If you need a quote on repair see:
Repair.
Regards.
Ginko.
May 31, 2011 | Nikon COOLPIX L18 Digital Camera
Every time I attempt to take a picture with my cam EOS40d, I get an error 99.I turn of the camera but error keeps appearing.
Check for clean lens to body gold contacts.
Take the lens off the camera. Look at the gold contacts that are in the body and on the lens. Many times, it's a simple process of rubbing a pencil eraser on these to remove dirt/film on them to allow proper contact. BE CAREFUL not to allow eraser crumbs to fall in the camera body. You can tip the opening slightly downward while you're cleaning... a lens brush can help remove any crumbs too
Let me know if it clears up your error.
K
Jun 17, 2009 | Canon EOS 40D Digital Camera
Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
Cannot get Error to go away
If it's a D lens or similar, check that the lens is set to its minumum aperture (and locked) - ERR normally means that the lens is not at its minimum aperture.
If your lens is a G lens, then the camera is probably faulty.
May 05, 2008 | Nikon N75 with 28-105 lens 35mm Film...
FEE error message
To get rid of the pesky fEE just set your lens to f22 or f16 ( depending on what lens you have ) and that is all. You might also want to lock this setting in ( if it is a Nikon lens then the lock is on the side just above the lens aperture ring.
Dec 07, 2007 | Nikon N55 35mm SLR Camera
Nikon N50 SLR film
Hi: You may want to try changing the aperature setting,or removing the lens,then re-installing the lens. Good luck.
May 29, 2007 | Nikon N50 35mm SLR Camera
Nikon COOLPIX L10 Digital Camera Logo
62 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
