Question about Maytag MBF2556HE Bottom Freezer Refrigerator
Refrigerator not colling
My refrigerator is not cooling; freezer (on the bottom) is fine; freezer vents are covered in frost.
  • kadams8061 May 28, 2009
    Thanks, Sea Breeze...that doesn't sound good...definitely sounds broken. Uck!
  • Maytag Master
  • 4,655 Answers
The freezer vents are electricaly controled as is with most of your refrigerator. Inside the fresh food compartment there is a control board part number 12868513 this may be the reason for the problems you are having. I am placing a link for your refrigerator below. Place the model number in the model search feature. This takes you to some models just the same as yours, just choose one. On the left of the screen click on controls. there you will see the part I mentioned. Yor freezer is also not defrosting properly also and this is most likely the control board. Let me know what you find and if you have other questions, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 28, 2009
  • John Tripp
    John Tripp May 28, 2009
    I am here to help. If you need anything just let me know, Sea Breeze
The bottom freezer is working fine, but the top part is not cooling
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 08, 2011 | Whirlpool GX5FHDXV (248 cu ft) Bottom...
Refrigerator not cooling freezer works fine blower motor in rear of unit on but turning slowly
Since the freezer is fine, you are in good shape. Pull off the back cover inside the freezer to inspect the evaporator coils. You should see a light frost pattern. If it is heavily frosted, then you have a open heater element - located at bottom of evaporator. If heater is good and you have heavy frost buildup, replace motherboard and thermistor which is clipped to the top of the evaporator.
Oct 01, 2010 | GE GSS20IEP Side by Side Refrigerator
Bottom freezer is frosting over and causing the freezer to work improperly - not cool enough. I can defrost (with a hairdryer) the wall so that the vents work for a while (3 to 4 days) before frost covers...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | Refrigerators
Bottom of refrigerator is not cooling
Hi: Is your freezer so full it's blocking the vents? If so unblock the vents. If not put your food in a cooler, frozen and fresh. Unplug your refrigerator. Take a hair dryer to the back of the freezer to melt frost accumulated behind the panel. I know it's supposed to be frost free. You have a problem with the defrost heater or the timer. The frost is blocking the vents. Most likely it is the later, but if you see no frost it could be the circulating fan. The location of these will be in your parts list. Kenmore still gives these with their products. If you don't have it go to sears.com and use parts direct. They will have a diagram. I hope this helps, Jeff By the way, If you are not handy just do the hair dryer thing and it will work for a weed or two until the frost plugs it up again.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Freezer Side is fine bit refrigerator side isn't cooling. Vents have been cleaned.
Pretty common problem among refrigerators. Look to see if you have frost on the rear wall of the freezer just above the lower basket. If you see frost on the rear panel, it most likely has about 3 to 4 inches full of frost on the coils behind that panel. If it does, you will have to remove the lower rear panel, and defrost the coils until they are clean, just like it was at the factory new. Once those are cleaned of frost, you should replace the defrost heater at the bottom of those coils. Some GE's have a kit that has a heater and a defrost thermostat all in one, and some do not. Some only come with just a heater replacement. If it comes only with the heater, you must also order a defrost thermostat, which is positioned above the coils, also. They both MUST be changed.
The other thing is to make sure that the fan inside of your freezer is working properly. The fan motor, and the defrost heater assembly are very common problems. Your refrigerator will work fine if you find out frost was the problem here, because the fresh food side gets its cold from the freezer side. If it is plugged with frost, the fan can't push air through the coils to the fresh food side. Hope this helps.
May 21, 2009 | GE GSH25JFR Side by Side Refrigerator
Refridgerator not cooling
Hi, Try these settings..
  1. Check the temperature setting
  2. Assure that there is enough room for air flow in the refrigerator or freezer
  3. Check for air flow restrictions in vents
  4. Test the temperature control
  5. Clean the condensor coils
  6. Check the door seals
  7. Test the door switch
  8. Test defrost heater
  9. Test defrost timer
  10. Test evaporator fan
  11. Check for a clogged drain tube
  12. Check for refrigerant leak                                      Pls rate my suggestion..thank you
Apr 11, 2009 | GE Refrigerators
Refridge not cooling
freezer side is working good but cooling side is not cool
Sep 24, 2008 | Amana ARB8057CSR Bottom Freezer...
Warm fridge
If you are sure the fan is running either the damper motor (vent in fridge section) is bad and not opening or there is ice in the return vents and not letting air circulate. Take out the bottom drawers in the fridge and look down the two return vents in each corner with a flashlight. If they are iced up the top will not cool.
Nov 17, 2007 | Maytag MFD2560HES Bottom Freezer French...
Maytag MBF2556HE Bottom Freezer Refrigerator Logo
158 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
