Question about Samsung HT-TX72 Theater System
My dvd home theatre system ht tx75 keeps shutting down
It says "protection" then it shuts down. I turn it on then in a few minutes it shuts down again. Need help Hi: I am having the same problem as many of the owners of the Samsung HTS (HT TX75.) The player shuts down in the middle of a movie and and continues to shutdown ever few minutes thereafter. Can you help? I have the same problem. At first I thought It was on the sleep timer. but after looking in the book and trying to reset it, nothing worked..... IM TIRED OF THIS STUPID THING.
  • 56 Answers
Protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotating
if problem still persist replace the fan
Posted on Jul 02, 2009
    New Friend:
I had ths problem and I just solved it.
1. open the DVD player box.
2. check the fan
3. unplug it and replug it
4. if it doesn't work just press the center of the fan where there is a white and blue sticker.
5. plug the dvd player and after a while, the fan should start to turn
Posted on Dec 22, 2013
  • Anonymous Anonyme
    Anonymous Anonyme Dec 22, 2013
    2. check the fan
  • Tony Edwards May 03, 2017
    I replaced the fan with a new one and mine still shuts down after 30 minutes. I was looking at the back and the fan was working when it shut down. Anymore suggestions to fix it?
Have a 2003 dodge intrepid 3.5 . the engine sounds a little rough,after running for a few minutes the check engine light comes on as well as the oil light.the car shuts off and will not run untill maybe 30...
You need to get the codes read. My guess would be some sensor is sending an overheating code to the computer which in turn is protecting the engine by shutting it down. If you don't have a reader, most auto parts shops will do a free read for you.
Jun 08, 2017 | Dodge Cars & Trucks
My problem/// cleaner turns on for a around ten (10) seconds and then shuts off wait a few minutes and it will turn on but goes off again at ten (10) seconds?????
These units have a automatic resetting thermal fuse near the motor to help to protect it from burning up by running too hot. This will need to be inspected and tested to see if it's holding it's proper temps., if not it will have to be replaced. There should also be an inspection of the machine to detect what was causing the reset to shut down that quickly, so that can be repaired as well.
Oct 22, 2013 | Rainbow E series Canister Wet/Dry Vacuum
New air conditioner turns itself off two minutes after starting
this sounds as if you have an over amping compresser or blower motor......you'll need an amp meter to be sure. as they over amp they heat up and go off on internal protection until they cool back down in which case it may try to run again and again and again and again and again......should I continoue...good luck
Jul 08, 2010 | Sharp CVP10NC Air Conditioner
Computer shuts off after a few minutes
Hi daddyo1269. That problem could mean that the laptop is overheating, probably the fan is not turning on and the CPU temperature can rise very very quickly and it shuts down in order to protect the CPU or the motherboard. After you turn it on, turn the laptop upside down and check the fan. If the fan is spinning propertly then the motheboard is "short" for some reason so you have to take it to a repair shop. I hope this helps and dont forget to rate.:D Thank you.
Apr 28, 2010 | Dell Inspiron 700M Notebook
Samsung ht-x30 sutting down protection error
My samsung shuts down with "PROTECTION".Help me to solve the problem.David ilomo.
Dec 05, 2009 | Samsung Audio Players & Recorders
Jets shut off...
Most jetted tubs turn off after 20 to 30 minutes. It is a safety feature as well as a thermal protection feature for the motor. I doubt if there is anything wrong with your tub. If you contact the manufacture of the tub, they will most likey confirm what I have said to be what is going on. If it was a hot tub, like the ones used outdoors, this would signify a problem.
Sep 11, 2009 | Home
SAMSUNG DVD HOME THEATRE SYSTEM HT-TX72
I have no audio. I hooked it up to another TV and same issue.
May 28, 2009 | Samsung HT-TX72 Theater System
Samsung HT-TX72 Theater System Logo
2,162 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
