Question about AT&T CECT Unlocked i68+ Quadband GSM FM Mobile Phone+Free gift Smartphone
GPRS not subscribed? T-mobile help?
Can anyone provide me with the exact directions to set up my T-Mobile account correctly on this Sciphone so that I can receive picture messages, internet, etc.?
  • 193 Answers
Must follow exactly for full help topics i offer a cd with all settings for every provider along with hundreds of java games wallpapers and mp3 ringtones. if interested submit 10 us dollars to digitalunderground23@yahoo.com. will send as soon as payment is eceived in padded envelope first class mail. SMS Messaging: 1.) From the main screen tap the SMS Text icon. 2.) Tap SMS on the Messages menu. 3.) Tap SMS settings on the SMS menu. 4.) Tap either SIM1 or SIM2 on the SMS settings menu, whichever SIM you are setting up at this time for SMS messaging. 5.) Tap Profile settings on the SIM1(2) message settings menu. 6.) Tap on any unused profile to select it, then tap the Edit button on the bottom of the screen. 7.) You should be on the Profile name menu with the name field already highlighted. Go ahead and tap the Edit button at the bottom of the screen. 8.) Tap in the following text between the quotes in the Profile name editor: ?T-Mobile? Next tap the Options button at the bottom of the screen. Next tap the Done button. You should be back on the Profile name menu with the new name. 9.) Tap the area below the profile name. The top of the menu should change to read SC address and the bottom of the screen should show a numeral keyboard. Tap in the following text between the quotes in the SC address editor: ?+12063130004? Next tap the OK button at the bottom of the screen. 10.) A Save? question box should pop up. Tap the Yes button at the bottom of the screen. You are done setting up SMS messaging for T-Mobile. You can continue to tap the Back button on the bottom of the screen until you exit out of all the menus to the main screen, or simply press the On/Off button once to get back to the main screen. At this point you can test SMS messaging by sending yourself a text message, or continue with other setup of the phone. The next sections will show you how to set up MMS messaging as well as an internet connection if you are paying for T-Mobile?s internet access services. One note about internet services, as a T-Mobileweb customer you can get full access to anywhere on the internet if you install & use a Java based web browser such as Opera Mini instead of the internal browser of the phone, and as of this writing you don?t need to be on their much more expensive internet plan, the simple $5.99 T-MobileWeb plan will work! You can get Opera Mini here => MASTER Download List Our next step will be to set up the data connections you will need to use. If you are not going to use the internet or will only be accessing T-Mobile?s T-Zones, then you only need to set up the first data account service we will name T-Mo MMS, otherwise if you want to access the full experience of the internet, please set up both data account service connections outlined in the next section. Don?t worry if at any time you exit from one of the menus and find yourself back at the slidelock screen, simply just slide unlock the phone and continue from where you last left off! Data Account Services: 1.) Setting up regular data account services for MMS & T-Zones access. 2.) From the main screen tap the Service icon. 3.) Tap Data account on the Services menu. 4.) Tap GPRS on the Data account menu. 5.) Choose any of the profiles in the current list and tap the button. 6.) You are now on the Edit screen. 7.) Tap the area just below Account name, then tap Edit at the bottom of the screen. 8.) Tap in the following text between the quotes ?T-Mo MMS? Tap the Options button at the bottom of the screen. Tap the Done button. 9.) Tap the area just below APN, then tap the Edit button at the bottom of the screen. 10.) Tap in the following text between the quotes ?wap.voicestream.com? Tap the Options button at the bottom of the screen. Tap the Done button. 11.) Both the User name & Password areas should remain BLANK. If they are not blank, then tap on each one and Clear what is in them so they are both blank. 12.) The Auth. type should be set to Secure. If it is not, then tap on the area and use the arrows to move the selection so it has Secure, then tap Done. 13.) A Save? question box should pop up. Tap the Yes button at the bottom of the screen. 14.) Tap Back button on the bottom of the screen. Tap Back button again on the bottom of the screen. You should now be on the Services menu. 15.) Tap WAP on the Services menu. 16.) Tap Settings on the Internet services menu. 17.) Tap Edit profile on the Settings menu. 18.) Tap either SIM1 or SIM2 on the Edit profile menu, which ever SIM you are setting up at this time for MMS messaging. 19.) Scroll down the list until you come to Profile 8. You can use any profile if need be, but profile 8 is usually the first not already filled. 20.) Tap on Profile 8. Tap Edit profile. 21.) Tap just below Rename profile, then tap on the Edit button at the bottom of the screen. 22.) Clear the current text, then tap in the following text between the quotes ?T-Zones? Tap the Options button at the bottom of the screen. Tap the Done button. 23.) Tap the area below Homepage, then tap on the Edit button at the bottom of the screen. 24.) Clear the current text except for ?HTTP://?, then tap in the following text between the quotes after the HTTP:// ?wap.myvoicestream.com? Tap the Options button at the bottom of the screen. Tap the Done button. 25.) Tap the area below Data account, then tap Select at the bottom of the screen. 26.) Tap GPRS on the Data account menu. 27.) Scroll down the list until you come to T-Mo MMS, the data account set up earlier under the Data Account Services section. Tap on T-Mo MMS to select it. 28.) Tap the area below Connection type, then tap Select at the bottom of the screen. 29.) Tap on HTTP, then tap on OK at the bottom of the screen. 30.) Tap the area below Proxy address, use the numeric keyboard at the bottom of the screen to tap in the following numbers, ?216155165050?. The result should look like 216.155.165.050 under Proxy address. 31.) Tap the area below Proxy port, use the numeric keyboard again to tap in the following numbers ?8080? to replace the current 0 value. 32.) Tap the OK button on the bottom of the screen. 33.) The areas under both User name & Password should remain BLANK. If they are not blank, select each, and Edit them by clearing all text. 34.) Next tap the Done button at the bottom of the screen. 35.) A Save? question box should pop up. Tap the Yes button at the bottom of the screen. 36.) Tap the Activate profile button on the T-Zones menu screen, and you should be taken back to the Select profile screen where a big green check mark will be beside the newly saved T-Zones profile. 37.) Tap the On/Off button once to exit to the main screen. 38.) If you ONLY want MMS and T-Zones access without the full internet connection, you can now skip down to the MMS Messaging section and continue setting up MMS messaging; otherwise continue below at step 39 to set up a second data account service which will be used for your internet connection. 39.) Setting up a 2nd data account service for full internet access. 40.) Tap the Service icon on the main menu. 41.) Tap Data account on the Services menu. 42.) Tap GPRS on the Data account menu. 43.) Choose any of the profiles, other than T-Mo MMS, in the current list and tap the button. The profile right under it would be fine. 44.) You are now on the Edit screen. 45.) Tap the area just below Account name, then tap Edit at the bottom of the screen. 46.) Tap in the following text between the quotes ?T-Mo Internet? Tap the Options button at the bottom of the screen. Tap the Done button. 47.) Tap the area just below APN, then tap the Edit button at the bottom of the screen. 48.) Tap in the following text between the quotes ?epc.tmobile.com? Tap the Options button at the bottom of the screen. Tap the Done button. 49.) Both the User name & Password areas should remain BLANK. If they are not blank, then tap on each one and Clear what is in them so they are both blank. 50.) The Auth. type should be set to Secure. If it is not, then tap on the area and use the arrows to move the selection so it has Secure, then tap Done. 51.) A Save? question box should pop up. Tap the Yes button at the bottom of the screen. 52.) Now that you have set up a second account service for internet use we can adjust the WAP settings for T-Zone to use this faster and less restricted internet gateway. 53.) Tap the On/Off button once to return to the main menu. 54.) Tap the Service icon on the main menu. 55.) Tap WAP on the Services menu. 56.) Tap Settings on the Internet services menu. 57.) Tap Edit profile on the Settings menu. 58.) Tap either SIM1 or SIM2 on the Edit profile menu, whichever SIM you are setting up at this time for SMS messaging. 59.) Tap T-Zones on the Select profile menu. 60.) Tap Edit profile on the T-Zones menu. 61.) Tap the area below Data account on the Edit profile menu, then tap the Select button at the bottom of the screen. 62.) Tap GPRS on the Data account menu. 63.) Find and tap on T-Mo Internet on the Data account menu. 64.) Tap the Done button on the bottom of the Edit profile menu. 65.) A Save? question box should pop up. Tap the Yes button at the bottom of the screen. 66.) Tap the Activate profile button on the T-Zones menu screen, and you should be taken back to the Select profile screen where a big green check mark will be beside the newly saved T-Zones profile. 67.) Tap the On/Off button once to exit to the main screen. 68.) Continue below with setting up MMS messaging. MMS Messaging: 1.) From the main screen tap the SMS Text icon. 2.) Tap MMS on the Messages menu. 3.) Tap MMS settings on the MMS menu. 4.) Tap Server profile on the MMS settings menu. 5.) Tap either SIM1 or SIM2 on the MMS settings menu, whichever SIM you are setting up at this time for MMS messaging. 6.) Scroll down the list until you come to Profile 8. You can use any profile if need be, but profile 8 is usually the first not already filled. 7.) Tap on Profile 8. Tap Edit profile. 8.) Tap just below Rename profile, then tap on the Edit button at the bottom of the screen. 9.) Clear the current text, then tap in the following text between the quotes ?T-Mo MMS? Tap the Options button at the bottom of the screen. Tap the Done button. 10.) Tap the area below Homepage, then tap on the Edit button at the bottom of the screen. 11.) Clear the current text except for ?HTTP://?, then tap in the following text between the quotes after the HTTP:// ?216.155.174.84/servlets/mms? Tap the Options button at the bottom of the screen. Tap the Done button. 12.) Tap the area below Data account, then tap Select at the bottom of the screen. 13.) Tap GPRS on the Data account menu. 14.) Scroll down the list until you come to T-Mo MMS, the data account set up under the Data Account Services section. Tap on T-Mo MMS to select it. 15.) Tap the area below Connection type, then tap Select at the bottom of the screen. 16.) Tap on HTTP, then tap on OK at the bottom of the screen. 17.) Tap the area below Proxy address, use the numeric keyboard at the bottom of the screen to tap in the following numbers, ?216155165050?. The result should look like 216.155.165.050 under Proxy address. 18.) Tap the area below Proxy port, use the numeric keyboard again to tap in the following numbers ?8080? to replace the current 0 value. Then tap OK. 19.) The areas under both User name & Password should remain BLANK. If they are not blank, select each, and Edit them by clearing all text. 20.) Next tap the Done button at the bottom of the screen. 21.) A Save? question box should pop up. Tap the Yes button at the bottom of the screen. 22.) Tap the Activate profile button on the T-Mo MMS menu screen, and you should be taken back to the Select profile screen where a big green check mark will be beside the newly saved T-Mo MMS profile. You are done setting up MMS messaging for T-Mobile. You can continue to tap the Back button on the bottom of the screen until you exit out of all the menus to the main screen, or simply press the On/Off button once to get back to the main screen. At this point you can test MMS messaging by sending yourself a picture message. Internet Access: If all you want to use for internet surfing is the phone?s built-in browser, and you have set up the data account service for the internet in the earlier setup, then you are ready to surf the internet by simply tapping on Service from the main menu. Then tapping on WAP and using the various options to navigate the internet like Homepage, Input address, etc. However, this won?t provide as robust an internet experience as a Java based internet program such as Opera Mini 3.1 or 4.1, or another java based internet browser. If you do decide to install a Java program for browsing the internet, there is one more setting which must be changed prior to using the Java internet browser. Java Internet Settings: 1.) From the main menu tap on the Java icon. 2.) Tap Java settings from the Java menu. 3.) Scroll down and tap the area just below Java SIM1 (SIM2) profile, which ever SIM you are currently setting up. 4.) Use the arrows to scroll the setting until T-Zones appears in the box. 5.) Tap the OK button at the bottom of the screen. Now you should be completely set up for SMS, MMS, as well for internet on the T-Mobile network if you have a T-Mobile internet plan!
Posted on Jun 05, 2009
    President:
  • 1,285 Answers
    President:
  • 1,734 Answers
You need to configure the GPRS service manually in your system settings.
Find an Sciphone i68 user manual at http://chinamanuals.com including network settings for major providers (also T-Mobile)
Posted on Jun 03, 2009
I have a sciphone 168 and when i am trying to use theinternet it says gprs not subscribed. i am on orange and cant find a way round this
If you have the correct Orange wap set up, then it's your SIM card, you need to call your wireless provider and they will fix this matter in their server. I have a T-Mobile sim card and my i68+ have the correct GPRS settings and I can't get in the internet, but I borrowed another T-Mobile SIM card with unlimited internet and place it in my i68+ phone and it worked. So it's most probably the SIM card IF the GPRS settings in your phone are correct.
Nov 03, 2009 | Dual Electronics CECT P168 Cellular Phone
Internet not working
GPRS: general packet radio service (that's the net in your mobile)
Your GPRS is not subscribed and it needs to be subscribed.
-- Call your service provide (Orange), and ask them to give you info of subscribing GPRS service.
As much as I know... Subscribing to GPRS is free, but the usage charge will be there.
Aug 23, 2009 | Lands Phones
Gprs not subscribed
hello friend some chines mobile cant work with GPRS so check it
Jul 13, 2009 | Dual Electronics CECT P168 Cellular Phone
Unable to use my GPRS on my sciphone i68+
These settings are for T-Mobile
Tmobile Setting
WAP
1- Main Menu click on Entertainment then click on Services
2- Click on Data Account–> click on GPRS
3- Choose any account–> click on Edit
1- Account Name
TMOBILE
2- APN
wap.voicestream.com
3- User Name
leave it blank
4- password
leave it blank
5- Auth. Type
Normal
CLICK ON DONE AND SAVE IT
CLICK ON BACK TWICE IT WILL TAKE YOU BACK TO SERVICES
5-Click on WAP –> click Settings–> click Edit Profile.
6- Choose any one on list then press ok–>Edit Profile
1- Rename Profile->(name it anything or u can name it T-mobile GPRS)
2-Homepage–> http://wap.myvoicestream.com
3-Data Account–>Select–>click on Gprs–> you will see the one we named earlier TMOBILE, select it and press OK
4- Connection Type
HTTP
5.Proxy serv address: 216.155.165.050
6.Proxy port number: 8080
7. Username
leave it blank
8. Password
leave it blank
CLICK DONE AND SAVE IT—>CLICK ACTIVATE PROFILE AND SAVE
SMS
1- Click on thee envelope icon it will take you to Messages
CLICK ON SMS
1- Message settings–> click in Profile Setting
2- Click edit on any profile name it T-mobile that will be line No. 1 in No.2 type +12063130004
MMS
1-Message Settings–>click Server Profile
2-Click on any 1–> click on Edit Profile
1- Rename profile
T-mobile MMS
2- Homepage
http://216.155.174.84/servlets/mms
3-Data Account
click on GPRS–> choose Tmobile–> press OK
4- Connection Type
HTTP
7.Username: leave it blank
8.Password: leave it blank
CLICK ON DONE –> SAVE–>ACTIVATE PROFILE
Jul 05, 2009 | Dual Electronics N99i Cellular Phone
I have a Problem with my sciphone it tellsme GPrs Not subscribed
These cect i68 sciphones are not GPRS compatible, they are GSM compatible, that means that when you want to get onto the internet you have to dial a network phone number. speak to your network supplier and ask them for the GSM telephone number then set that up in the wap gsm settings area in the phone menu.
Jun 26, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
I have CECT KA08 which keeps saying GPRS Not Subscribed. Does anyone know how to rectify this. It can either be on T-Mobile of preferably Vodafone
Chinamanuals.com can help you.They have Sciphone / KA08 settings for each provider worldwide. Sendthem a request with your providers name and your country.
Jun 16, 2009 | Dual Electronics CECT P168 Cellular Phone
GPRS not subscribed
Your Prepaid doesn't have Data Service... GPRS is the 3g network ... so if you dont have a Data Plan... or data service on your phone you can't go on the internet... and i bet if you could with a prepaid card... it would DRAIN your $$
Jun 03, 2009 | HTC Touch Pro Smartphone
GPRS not subscribed? at&t?
There is a site, specialized on manuals and provider specific network settings. Ask them.
Jun 02, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Getting "GPRS NOT SUBSCRIBED" message
Data Account Setup:
From the Main Menu select > Services > Data Account > GPRS
Scroll to an empty account (IE: Account icon_cool.gif and select Edit
Set Account Name to T-Mobile Internet
Set APN to internet2.voicestream.com
Leave Username and Password blank
Press Done
Select Yes to Save
WAP Profile Setup:
From the Main Menu select > Services > WAP > Settings
Select Edit Profile
Scroll to an empty profile (IE: Profile icon_cool.gif and select Edit Profile
Set Profile Name to T-Mobile Internet
Set Homepage to http://www.t-mobile.com
Select Data Account > GPRS > T-Mobile Internet
Set Connection Type to HTTP
Leave Proxy blank
Leave Port blank
Press Done
When Prompted to Save select Yes
Scroll to T-Mobile Internet and select Activate Profile
To Access the Browser:
Select Homepage to bring up the homepage
Select Enter Address to browse other pages
To setup Picture Message (MMS)
Create Data Account
Select Menu
Select Services
Select Data Account
Select GPRS
Choose an empty profile
Account Name enter T-Mobile WAP
Press Options
Press Done
APN enter wap.voicestream.com
Press Options
Press Done
User Name
Password
Auth. Type choose Normal
Press Done
Press Save
Create Profile
Select Menu
Select PIM
Select Messages
Select MMS
Select Message Setting
Select Server Profile
Select a Profile
Select Edit Profile
Select a profile
Choose Edit Profile
Rename Profile enter T-Mobile MMS
Homepage enter http://216.155.174.84/servlets/mms
Press Options
Press Done
Data Account select GPRS
Select T-Mobile WAP
Connection Type select HTTP
Proxy Address enter 216.155.165.050
Port enter 8080
User Name
Password
Press Done
Activate the profile
Jan 25, 2009 | Dual Electronics CECT P168 Cellular Phone
AT&T CECT Unlocked i68+ Quadband GSM FM Mobile Phone+Free gift Smartphone Logo
1,528 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
