Question about Toshiba Satellite A200-0ET00X Notebook
Toshiba A215 laptop - monitor goes crazy/locks up sometimes
Sometimes when I move the display screen angle or touch any key on the keyboard (mouse does not do this), yellow and blue horizontal lines start going across monitor and block out display and lock everything up so that I have to reboot.
Often I have to reboot several times to get back to a logon because the screen will either be blank (white) or dark blue and black with a very strange pattern.
Any Ideas?
The computer has not been abused but it almost seems like I have a bad wire or cracked board inside that is affected by the movement or pressure of the keyboard and monitor.
  • meteshadow May 11, 2010
    it looks like  LCD data cable that comes from mainboard goes to LCD. this cable is very thin and able to break down..
    hope it works.
sree184
  • 87 Answers
SOURCE: toshiba laptop screen goes wierd
This was probelm of lcd panel
u go nearest service center and check lcd panel
Posted on Jul 15, 2008
Ray-Tosh
  • 124 Answers
SOURCE: Laptop monitor goes black
If you're working on the computer when that happens, it's not probably a power setting. Try to update your BIOS to the most current version at the toshiba support website (support.toshiba.com) & see what happens. Fixes the issue most of the time
I hope this helps.
Posted on Sep 28, 2008
RescueTechLA
  • 2653 Answers
SOURCE: Toshiba Satellite M45-S169
Try booting into safe mode
Press F5 on the keyboard every few seconds when your start the computer.
Go into the Device Manager and remove the Display Adapter ( Video Card)
Restart the computer normally.
Let me know what happens.
Posted on Mar 03, 2009
  • 66 Answers
SOURCE: Red Line down LCD screen
replace the lcd
Posted on Oct 30, 2009
Testimonial: "Solved the problem "
  • 11800 Answers
SOURCE: Laptop Monitor shows balck and white stripes
From what i can barely see it your photo it looks like your video chip  (which is part of the motherboard's chipset) has died. It will be expensive to replace the motherboard.
To recover all your data is easy - just remove the hard disk from the laptop, put it in a case like one of these
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010010092%201053807124%201054107131&name=SATA
then connect the case to another pc.
Posted on Mar 26, 2010
The cursor moves randomly while I use the trackball
this problem is caused by a defective mouse, replace it.
Sep 09, 2009 | Logitech Marble Mouse Trackball
CRAZY MOUSE IS ALIVE
I take it that it is a led mouse (red light under it)..
Get a brush and brush where the light is under the mouse, sometimes a tiny hair or bit of fluff can stick in there and cause that problem...
Jul 01, 2009 | HP P2360AA Keyboard/Mouse
How to block VGA port on my laptop
in most cases, you can switch between display modes by using the function keys. the keys from F1 to F12 on your keyboard should contain various symbols (sometimes in blue). one of those symbols looks like the front of a monitor (on some laptops it says "LCD/CRT"). look for the key with the monitor symbol (or the text "LCD/CRT"), press and hold the Fn-key on the bottom line of your keyboard and then press the display mode function key. then you will see if the image on your display switch from one screen to the other.
if you cannot find such a key, you can disable the external display by right-clicking your desktop and choosing properties from the drop-down menu. on the "settings"-tab you should be able to see two virtual displays. click on display 2 and then uncheck the box that says "extend my windows desktop onto this monitor".
May 26, 2009 | HP Photosmart C6180 All-In-One InkJet...
Toshiba satellite a215s7422 screen blackout problem, however, computer powers up and fan is running. external monitor will start in safe mode. sometimes i see the word signal on external monitor. help
Sounds like your refresh rate is incorrect
Boot into safe mode. Go to Start > Control Panel > Under Appearance and Personalization , select Adjust screen resolution ,
Selct your laptops display , set the resolution to 1024x768 , click on advanced settings then click the monitor tab at the top.
In the box below , select Use hardware default setting .
Hit ok.
If that doesnt fix it something is wrong with the drivers.
Start in safe mode with networking and get the drivers from here and install them.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1852724&rpn=PSAFGU&modelFilter=A215-S7422&selCategory=3&selFamily=1073768663&selModel=1852724%7CPSAFGU
Mar 04, 2009 | Toshiba Satellite A215-S7422 Notebook
Screen goes to sleep after "no signal" message
If you do not move the mouse or press any key on the keyboard it could be just going into video power save. Confirm it by moving the mouse or pressing a key on the keyboard. If the monitor comes back on, adjust the power settings in control panel and change the time for the "turn off display" to a more suitable setting.
Dec 31, 2008 | ViewSonic VA1930WM LCD Monitor
Need to reset display settings
Hi
Take a look at the keyboard and find the FN button on the bottom left. (The letters FN are in blue)
Now look at the F keys at the top of keyboard and find one that has either a couple of monitor symbols or the letters CRT/LCD - again in blue
Holding down the FN key and press the other key, this should change screens between the external and internal monitors. Don't expect an instant change - it sometimes takes a couple of seconds to do the job.
If that does not work then attach another external monitor, right click on the screen and select properties. Now select the far right tab (settings) and then go to Advanced tab and then select Monitor
Here you should be able to change screens back to the LCD of the laptop
Dec 09, 2008 | Toshiba Satellite P30 P35 Series Notebook
Optical mouse moves by itself
yes reinstall the software
Aug 31, 2008 | Computers & Internet
Keyboard
Hi this Tony my lap top toshiba M45-s265 is making crazy things,when I prees shift key ,everthing changes .the letter go to caps lock size and the numbers changes to works only the symbols, and when this happens also ,if you go to select any folder in my documents on windows you chooice one folder ,with mouse and set all the folders ,what could be happens
Mar 28, 2008 | Toshiba Satellite M45-S265 Notebook
Toshiba Satellite A200-0ET00X Notebook Logo
188 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
