Question about Samsung SyncMaster 2233BW 22" LCD Monitor
Says to check signal cable
Powered up but floating box says check signal cable, both ends look perfect
  • Jim Goldsmith
    Jim Goldsmith May 11, 2010
    please connect the monitor to another computer to ascertain that the problem is the monitor
    let me know
5 Suggested Answers
  • 139 Answers
SOURCE: New Monitor Installation
Does your computer have more than one video adapter installed. If so, try plugging into the other one.
Posted on Jan 13, 2008
  • 59 Answers
SOURCE: floating box says check signal cable
plug the blue cable connection into the VGA port (also blue) on the back of the PC and then turn it on. If you have multiple VGA ports and it doesn't work the first time try the other port.
If the cable is white check that you have a white DVI port on the back of your PC and use that port.
Posted on Jun 13, 2009
  • 63 Answers
SOURCE: HDM1 BOX FLOATING
This is telling you that you do not have a High Definition Mode source connected to teh screen.
Posted on Oct 03, 2009
SOURCE: Samsung SyncMaster 226BW - floating box "Check Signal Cable"
had the same issue, called up customer care of samsung and they suggested me to change the cable to D-15 10 series. I was getting the comp o/p on TV but with the "Check Signal Cable" messg with the old VGA cable where some pin is not grounded used for computer to monitor connectivity.
Abhi..
Posted on Oct 28, 2009
How can I fix a no signal message on my sky+hd box
If you receive some channels and not others here's what to check.
Has your dish moved? has it been windy?
Turn off the sky box at the wall and check the two cables coming in from the dish. Unscrew the two "F" connectors and check there is a bit of cable sticking out of the end, if it's not long enough you will lose some channels. if you strip the cable back and make them too long then you will not get the plug back on. Be careful here as the middle cable must be straight to fit in the hole and the outer braiding must not touch the center cable. Make sure the box is off at the wall when handling this cable as there is up to 18 volts on it.
Because you say "it powered on again" i'm thinking your box has a power supply problem. When they were made they did not use good quality parts so there is a repair kit of 15 capacitors that usually need changing. Let me know if you can't get it sorted as i have done these before.
Sep 16, 2014 | Televison & Video
I'm currently installing my new SyncMaster 2280HD Monitor to be used for now just as a monitor. When I turned on the computer onscreen all I get are two floating boxes that say AV in the upper left...
It sounds like there is a connection issue between the computer and monitor. Make sure the cable connecting the computer and monitor is securely fastened on both ends. If you verify that it is and the problem persists, try using a different cable.
May 27, 2011 | Computers & Internet
The LED vizio comes on the front of the tv...........screen is blue with floating signal saying No Signal!.
Tries unplug the tv and the cable or satalite boxes too.Replug it all back like an hour later.The tv know will reset itself back to the factory setting.The cables or satalites boxes it upgrading it softwares.The tv should have incomming broadcasting signal and work now.Not,call the cables or satalites compannies to replaced those inputs boxes first,have the same problems with those new input cables or satalites boxes.Than the tv,the Tuner signal board have problems and the cause.That the board,where the incomming broadcasting signal cable plug into it.That the tv Tuner signal board.Tries websites Shopjimmy.com,Ebay.com to buy a whloe refurbish Tuner signal board for the replacement.
Nov 07, 2010 | Vizio VX32LHDTV10A 32 in. LCD HDTV
I just have a TESTING.... box floating on the screen. Even the menu buttons display nothing. Has this beast finally bit the dust?
Possible reasons for that may be bad cable connection, burnt videocard, or problem in the signal board in the monitor.
So, first check with another monitor if your PC is actually giving a singnal. Then look both ends of the cable for bend pins. They can be easily strighten with thin plyers. You can replace the cable VGA (or DVI) cable to see if it will fix the problem.
If your videocard is OK and the cable is OK, then try to open the monitor. Replace the capacitors on the signal board. Look for blown capacitors on the power board too. Replace if any.
If this cant help, there is major problem with the signal board of the monitor and more measuring is needed. There are buffer elements between the connector and the signal processor and some of them may be faulty. If there are no buffers and the signal goes directly to the processor, entire board should be replaced.
If there are VGA and DVI inputs, you may try the other input with the relevant cable.
Aug 11, 2010 | ViewSonic VA800 17.4" Flat Panel LCD...
I have a sharp tv with a cable box and i lose signal, like the tv is restarting itself. started when i got the tv. tried hdmi and component cables and switched tv providers and still does it... any ideas?...
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Oct 18, 2009 | Samsung LN32A550 32 in. LCD TV
Abhi..
Jul 25, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Floating box says check signal cable
Jun 13, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
The monitor went black and a new graphics card did not solve the problem. a floating box says check the signal cable. I put a working monitor on the computer and the same floating box appeared.
oh chicki chiki yeyahhh! man u gotta man up and try to install a striperama new card, in diferent socket, or get one of the diagnostics card or ebay or something! punchis punchis!
Feb 24, 2009 | Computers & Internet
How do we adjust our tv
You didn't mention anything about a cable box, VCR, etc. which might be connected. A snowy pic. means simply, inadequate signal is reaching the tuner, or the TV tuner itself is bad. If the first is so... check your cabling. If you have a VCR or DVD player hooked in between the cable box or outside antenna (whichever is the case), VCR (RF or ant.) out should go to the TV, VCR antenna (RF or ant.) input to the cable box. Also check the cable wire itself. If you look at the end of the cable, you should see a relatively thin center wire. This center conductor is what carries the signal. If it is missing, bent over, or too short to make contact with whatever it is connected to, you will have a very snowy pic. If you have a spare TV, connect it in place of your "new" TV, to narrow down the problem. Lastly, if all is well with hookup, cabling, etc. the TV might have a problem. Sometimes the tuner has a component defect, or the coaxial connector can be broken.
Sep 25, 2007 | Televison & Video
No Satelite Signal Indication
The "front end" of your Receiver might be defective. Since your other unit is working then what might be happening is the signal to your unit might be dropping, to check this I would use a Satellite power meter, however if you do not have one you can use your other unit and connect it to the cable that your supposed defective unit is connected to. If the unit works then the problem is the supposed defective unit, if the unit does not work then this denotes a possible cable problem. Tell me if this works for you?
Sep 25, 2007 | RCA DRD485RG DirecTV DTV Receiver
Samsung SyncMaster 2233BW 22" LCD Monitor Logo
783 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
