Question about GE Refrigerators
Freezer too warm. As high as 16 deg.
The freezer temp. changes from about 4 deg. to 16 deg. what should i check to correct this problem?
  • GE Master
  • 4,655 Answers
Need the make and model number, Thanks, Sea Breeze
If I knew it had a defrost thermostat that is where I would point you first.
http://servicepartstec.blogspot.com/
Posted on May 28, 2009
How to set freezer on LG Bottom Freezer LRFD22850
Hello Fran Miller,
For OPENERS... (my opinion)
always start by setting you temperatures at mid range.
Owners manual... Page 16
Setting the controls 16 - 17 Adjusting control settings...
http://www.searspartsdirect.com/partsdirect/user-manuals/LRFD22850ST-LG-Parts-Refrigerator-Parts-manual
I get a little PUSHY about FOOD TEMERATURES...
(stored poorly there's no quicker way of poisoning ones self)...
I strongly recommend getting TAYLOR refrig/freezer
THERMOMETERS (like Amazon... cheap = $6 ea).
Let the refrigerator stabilize EMPTY 24 HOURS
Loaded with food (not recommended: 72 hours).
ADJUSTING CONTROL SETTINGS
Give the refrigerator time to cool down completely before adding food. It is best to wait 24 hours before you put food into the refrigerator. The mid-settings indicated in the previous section should be correct for normal household refrigerator usage. The controls are set correctly when milk or juice is as cold as you like and when ice cream is firm.
THERMOMETERS
Amazon com Taylor Refrigerator Thermometer 20 Deg To 80 Deg 3 1 4 3 3 4...
Hope I am helping
Carnac the Magnificent
Jul 11, 2017 | LG Refrigerators
Igloo refrigerator's freezer: -16 deg. Fridge: 60 deg. No evap fan & duct from freezer to fridge. Cond coil clean. Discharge line warm. T/STAT@coldest temp. Fridge gasket seals. Condensate drain clear
freezer is working fine, refrigerator won't go above 60 degrees.
www.shopyourway.com > Manage My Life > Questions
Freezer is working fine but fridge won't go about 60 degrees. Cleaned out pass through from freezer to fridge, clean vents, and cleaned coils. All to no avail.Missing: gloo
Beckly Powerful Suction Cup Handle No Tools Necessary!
www.amazon.com > ... > Bathtub Appliques
Amazon.com, Inc.
Rating: 3.6 - ‎85 reviews
Just Turn 60 Degrees and place on any Flat Smooth surface. For Bath Safety and Cabinet Doors Also Fridge Accessory. Beautiful ... No tools, no glue! No need ...
[PDF]Operate Refrigerator In Room Warmer Than 60°F
Jan 03, 2016 | Refrigerators
Freezer 20 deg --fridge 55 deg fridge not cooling
Check compressor working and also with correct pressure. Keep arm in condenser coil. If you feel warm, check freezer to hear slight whistling sound. If not short of gas or gas leak. If warm and no whistling sound means, system chocked. Release all gas and flush out system. Vacuum and do gas charging. Thermostat setting must be 3 to 5 degree Centigrade.(37*F to 41*F). Thanks.
Feb 04, 2011 | Refrigerators
Need to know how to change the temp on the frige part also whats the correct temp it should be at
need to kow brand and model # of frig to help / tempts for frig 38 deg and freezer 15 deg or lower to 5 deg .. mm
Apr 19, 2010 | Refrigerators
2001 GE side by side refrigerator model TGX26KRDA WW Beginning about a month ago the refrigerator temperature rose to 60 deg. F. Freezer remained well below 0 deg F. Checked baffle which was open and...
Is the fan that moves the air from the freezer to fridge running If there is a switch in cabinet somewhere the freezer door would contract it, with door open push in switch hear the fan both are good. Don't hear fan check evaporator or freezer fan and that switch it may be a duel switch open light closed fan run. Tricky there are light switches, when out light on or when switch is in its lights out
Mar 17, 2017 | GE Refrigerators
Water was frozen all inside the freezer and fridge temp was high
Self defrost mechanism may have an issue. If it stays on too long you will have excessive temps build up in refrig as well as freezer. There is also a defrost thermostat that is supposed to turn compressor back on when temps get too high - check that out also.
Apr 14, 2017 | GE Profile PSW26P Stainless Steel Side by...
GE PFS22MISBBB freezer not cold enough. Temp won't reset.
replace the fan as quickly as possible it may be shorting and causing damage to your control board,
Mar 30, 2008 | GE PFS22SBSSS Stainless Steel French Door...
Refrigerators Logo
61 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
