Lenovo 3000 Y410 Notebook Logo
Posted on May 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Power calibration error while dvd writin
When writing dvd in lenovo y410 7757-42q i am getting power callibration error using nero as well as iso. i have a slot in drive so i can't clean the lense,even i used cd cleaner solution but i get no results.during cd writing nothing happens but it fails only during dvd writing. loading and reading of dvd also take exess time and when cd rotates the drive produces a noise almost like a mixure grinder. so please help me by telling some solutions.
Anonymous
Level 2:
  • Expert 197 Answers
  • Posted on May 28, 2009
Anonymous
Expert
Level 2:
Answers
197
Questions
0
Helped
82155
Points
386
You might need to re-install the cd-burner driver (nero). suspected also could the your dvd-rom drive faulty. contact your service center to replace your dvd-rom drive.
1helpful
3answers
DVD RW doesn't write(power calibration error)
This may due to lens alingment problem or dust in the lens. Clean the lens using lens clear CD/DVD.
1helpful
2answers
Uninstall Nero from your system completely with from registry then restart system and again install nero then try.
I hope that this has been very helpful for you
I just purchased a new DVD rewriter with Nero 7 Essentials, from Smartstart. I am trying to write an image file (.iso) to Memorex DVD+R disks. With the progress bar at 1% and before anything gets...
Were you able to write a single music or another file using Nero? Were you able to burn the image using the Active ISO burner? Did you try a new fresh blank DVD or are using the same DVD again? Try to free some more space from your C drive and then check again.
2answers
Cannot write onto CD or DVD
try updating! Nero version 7 is old and cannot work in XP with any upgrade past sp1 If you have Vista now that is another reason to upgrade Nero There is a version 8 now
Error in writing DVDs
HI WHEN WRITING CD OR MP3 NERO IS GREAT,BUT FOR DVD'S USE CLONE DVD OR ALCOHOL120
2answers
Power Callibration Error
This error has nothing to do with your DVD drive hardware, so you can be sure your Laptop is ok. This is software error with Nero. Try and reinstall Nero or just try and burn DVDs at lower speed.
2answers
change the cables of dvd drive, also check power
DVD Writer not working
the device has a power callibration error, meaning that it cannot apply sufficient power to the laser head, to burn your disks.
Alternatively the laser head may be-weak, out of alignment.
this is a Drive error, you can try a CD head cleaning Disk.
The problem, could also relate to the motherboard not supplying enough power the actual drive itself.
ensure you have a full battery, and A/C adaptor into the laptop.
also try uninstalling-re-installing nero.
if all this fails, consider a repair or re-placement DVD Rom.
Mike @ compurepair.
Power Calibration Error.
first re install your nero .and
A) Power Calibration is controlled by the recorder. Before any write operation, all recorders must do a 15 step power test to determine the optimum power for writing to the CD; this is called "Optimum Power Calibration"(OPC). And during the write, it continues to do this test to get the best write throughout the whole CD; this is called "Running Optimum Power Calibration" (ROPC). This whole process is controlled by the recorder, though initiated by programs such as Nero. There is an area on the inner part of the CD for the test and test data info to be stored. You can use this area up to 999 times.
So, when you receive the "Power Calibration Error" or "Power Calibration Area full" error message, then the cause will be either poor media, poor Power, or a defective Recorder.
POSSIBLE SOLUTIONS:
1) A might enable the OPC on this medium
2) Try another brand of CDR or CDRW media.
3) Also try different power connectors, and for recorders, do not share power with other devices. It needs its own power connector. If this occurs with an External recorder, the power source in the chassis could be the cause. Take the recorder out of the external chassis, and connect it internal, as a test.
4) Try different configurations, such as taking the CDROM to the Primary IDE bus as Slave, and have only the recorder connected to the Secondary IDE bus as Master.
5) Send the recorder in for Service.
Here is the direct Link: http://www.nero.com/en/632181809668074.html#23
I Hope this helps,
Power calibration eror
Just install Nero 6 and that will fix it!!!
Nero 7 and 8 have communication problem with DVD RW drive!!
good luck
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
