Question about RCA F32645 32" TV
F32645 no picture
I have audio, but no picture. Sometimes it will come back on for a minute but then the screen goes black.
5 Suggested Answers
Shuttle83
  • 1139 Answers
SOURCE: Scattered black lines appear then screen gos black, but still have good volume
Hello 4fiddy,
You have actually diagnosed your own problem, Let me explain; the line "I can slap the left side of the tv and picture will almost always come back on" This indicate some form of poor connection (cold solder joint). If you have a soldering iron, solder (circuit type not pipe type), and a multimeter. Use the soldering iron and solder to redo the cold solder joints , and then test it (the connection) with the multimeter.
I hope this helps
Thank you,
Shuttle83
Posted on Sep 25, 2008
  • 103 Answers
SOURCE: I have a rca hd56w66, my screen shuts off but the
Sounds like you lost the power supply to guns, now this doen't mean you have to go looking for it, you will need a repair person to fix it. Word of advise, if you haven't had one of these fixed before it can range in upwards of 600.00 or more to fix now days.
Posted on Oct 09, 2009
tvtek
  • 1284 Answers
SOURCE: picture goes out
Has the lamp ever been replaced on this TV? If not it would be the first suspect. The next time the picture goes out look for light coming from the back of the TV where the lamp is. If you see no light then replace the lamp. Please take a few moments to rate my answer. Thank you...
Posted on Nov 18, 2009
jdvillanueva
  • 2098 Answers
SOURCE: my rca r52wm24 Tv turns on but after about 20
Hi mcpheeters16,
First to isolate the loose connection from fault, check the cable connectors from the lamp and the ballast board. Pull-out the cables and then re-insert. Also check the ballast board from bad solder joints (crack/cold/dry joints). This is hard to spot I would advice you to work in the brightest area or use table/portable lamp to locate it. Once found, re-solder it.
You have to check also leaky/dried electrolytic capacitor in the ballast board and its power supply. This will do the same symptom. You must have a capacitor checker because not all of it bulged/dome at the top.
Another parts concerned is the lamp itself. Once near to its peak burning life it will produced an intermittent fault like what you've experienced right now.
If you don't have necessary tools and test instrument and can't do the job yourself, I would advice you to look for a qualified technician to troubleshoot the unit.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Mar 23, 2011
Philips 52'' hdtv 1080p while watching it looses picture but still has sound
The back light inveterate board and CCFL lamps should be checked. Check and replace the faulty component. Back light inverter can only be replaced as card basis.
Jan 30, 2013 | Philips 52 In. LCD HDTV
Radio/nav system dead
I have 2010 Porsche Cayenne and Nav screen just goes black and turns back on - sometimes it does it few times a day sometimes its working fine ..any idea?
Jul 13, 2010 | 2006 Porsche Cayenne
47in Phillips-tv picture goes black still has
Could be the signal board has a bad cap, in this case it sounds like you are getting intermitten power to the inverters....when the tv goes down and of course you have audio....Shine a flashlight on to screen and see if you have a picture...look carefully. If this is the case..you have the above problem!
Nov 23, 2009 | Televison & Video
Picture goes black but hear the sound
this is the problem related to display of ur TV screen...please contact the service centre...plz dont try to repair it urself..
Apr 30, 2009 | Sharp Aquos LC-C3234U 32 in. LCD TV
Black box on picture
Use your remote to turn off the closed caption,
Please rate this fixya.
Jan 24, 2009 | RCA F32645 32" TV
Screen goes black
here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main digital board.
Sep 08, 2017 | Televison & Video
Half of the screen goes black
the light engine is defective and needs to be changed..this set is not that old..contact mitsubishi customer relations to see about having it done under a customer accomodation, as they have had a lot of problems with the engines
Nov 28, 2007 | Mitsubishi WD-73732 73" Television
Sometimes no picture on RCA tv
its nothing really, if your tv is new then it is normal but if it continued to do it then its broken
Oct 28, 2007 | Quasar SP-3233 TV
RCA F32645 32" TV Logo
82 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
