Question about AT&T Blackberry Curve 8300 Smartphone
Uncaught exception error
I have BB Curve 8300 version 4.5.0 Whenever I'm in the middle of chatting using Blackberry Messenger, the error message pop up saying "Uncaught exception: ". After that I cannot send message anymore and have to end conversation and start again. Any info how to resolve this problem? Thanks ...
    Brigadier General:
  • 7,752 Answers
You will need to try this method
2. You need to install a BlackBerry OS file that is specific to your device. The original version, as supplied by the carrier, is the safe choice, but you can use any model specific version. This is not supplied on your BlackBerry CD, Ref: 3 links to BlackBerry's download pages.
3. Once the OS has been installed, you have to prepare it for the device.
Select Start / Computer and select the Drive C: Icon.
Open Program Files / Common Files / Research in Motion / AppLoader.
Navigate to the bottom and delete the file Vendor.XML file.
4. You are now ready to restore your device. Verify that BlackBerry Desktop Manager is NOT running. Plug the device directly into the computer's USB port.
We are about to venture into the bowls of the beast. Windows is not suitable for this job, we are going to invoke the Command line interface with an option switch.
Windows XP: Start / Run... / Command
Windows Vista: Start / Command (type this into 'start search')
Posted on Jan 31, 2010
My blackberry 8520 is showing error 523 n uncaught bb expectations
my blackberry curve 8520 is showin uncaught expectation 8 >= 8 cant text as my message bix has disapeared
Dec 10, 2010 | RIM BlackBerry Curve 8520 Smartphone
How to fix blackberry 8520 app error 523
just wipe it or reload with the new updated OS
May 09, 2010 | RIM BlackBerry Curve 8520 Smartphone
BB messenger error "Uncaught Exception: java.lang.null...
When attempting to send messages from the BlackBerry device, the BlackBerry device user receives the following Java error called uncaught exception java.lang.illegal argument exception:
To over come this error you need to complete the following steps:
First, perform a full backup of the BlackBerry device data:
  1. Connect the BlackBerry device to the computer using the USB cable.
  2. Open BlackBerry Desktop Manager, and then double-click Backup and Restore.
  3. Click Backup.
  4. Save the backup file.
Run the application loader tool and erase all data on the BlackBerry device:
  1. In BlackBerry Desktop Manager, double-click Application Loader.
  2. Click Next.
  3. On the Device Security Password screen, type the BlackBerry device security password, and then click Next.
  4. On the Device Application Selection screen, click Next.
  5. On the Completing the Application Loader Wizard screen, click Advanced. The Device Data Preservation screen is displayed.
  6. Select the Erase all application data check box, and then click Next.
  7. Select Do not automatically back up and restore the device application data during the loading process, and then click Next.
  8. Click Finish. The BlackBerry device resets. This might take several minutes.
Hope I helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 20, 2009 | RIM BlackBerry 8800
Error code on my blackberry 8330
Keep getting error code 0x80043ac9 when sync'ing my BB Curve 8330. Won't let me finish sync'ing address book. Stops at 2906 of 3814 contacts. Calendar won't update either. Worked fine until 8/10/10. Back up works fine.
Jul 06, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
I cannot get on the internet
you have a corrupt Operating System on the phone, try this method to correct it
When your device fails to start, it show one of these symptoms:
1. Totally dead.
2. Trying to restart, LED activity only.
3. Failed to start, a white screen with an error message.
__________________________________________________ ________
1. Physical damage, water is the worst enemy of delicate electronic device. Try drying it with a desiccant and replacing the battery. If there is no activity, you can still try the last ditch technique, nothing to loose anyway.
2. Your device is not able to start, something has gone wrong and the OS is corrupt.
3. Geeks call this an "Uncaught exception error". That is a polite way of saying, the last thread has terminated, the OS has halted because it is corrupt.
In many cases, the Application Loader can be used from Desktop Manager or Windows,
If that fails to connect, there is one final solution. Go Old Skool ...
The good news, starting from scratch, you will be back in service in a couple of hours. biggrin.gif
Mar 07, 2009 | AT&T Blackberry Curve 8300 Smartphone
I no longer can receive emails due to a strange time out message
You made need to upgrade your OS you are presently using....
Feb 23, 2009 | AT&T Blackberry Curve 8300 Smartphone
Blackberry 8300
you should delete that and us just the msger or bbm on the phone maybe that particular software is not compatible with the BB OS.
Nov 10, 2008 | RIM BlackBerry 8800
Blackberry 8300
Try pulling the battery out of the BB for about a minute and then replacing it. Sometimes doing that (a reboot) will fix application errors. The device will automatically restart when you re-insert the battery. You will not lose any data when you do this. Turn the device off before you remove the battery.
If that doesn't work I suggest contacting the software developer to see if there is a new version. Sometimes new versions fix incompatibilities and bugs. It's 99% likely that a new version will be free if it fixes bugs.
Apr 25, 2008 | AT&T Blackberry Curve 8300 Smartphone
AT&T Blackberry Curve 8300 Smartphone Logo
393 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
