Question about Raypak Free Hydraulic Lift Gate Delivery - No L...
Raypak 2199 digital pool heater poor quality product
Raypak digital 2100 ,a one year old, may be 5 hr maxi of use pool heater having false flamme sigal FFL message and not starting because PC board is out!! Poor quality and not reliable product fronm Raypak, cost of PC board $ 345.00, will not recommand to anyone Raypak .Laurent.5-27-09. A$ 1800.00 heater unit,one year old with 5 hr maxi of use.Shamefull.
  • 22 Answers
SOURCE: raypak 2100 digital heater give fault code eol
ILO or ROL. There is no EOL.
ROL is a switch inside the lower left corner of the heater. Press the red button. ILO is a lockout. Power down and power up.
Posted on Dec 21, 2008
  • 22 Answers
SOURCE: Raypak FFL Fault Code
the ffl is a false flame sensing when the heater is not in call for heat mode.
Posted on Feb 21, 2009
  • 246 Answers
SOURCE: raypak pool heater ser.#0606211992.
indicates false flame sensing check for flame rectification not touching ground like a piece of metal dirt or has been bend on the past
Posted on Aug 31, 2009
  • 139 Answers
SOURCE: Service light comes on our Raypak RP 2100 pool heater.
this usually indicates a high limit condition.you must first ascertain if you have a component failure or a true high tempature condition.your model has 2 limit controls and they are both located in side panel on water in/out header
Posted on Sep 19, 2009
  • 990 Answers
SOURCE: Back flare on Raypak pool heater
You will need to pull the burner tray out and clean and blow out the burners. Then you will need to pull the orfaces from the gas manifold and clean each one and blow out the gas line. Then with a mirror you will need to check the fire brick inside the burner box. Then you will need to replace anything that is damaged. Good luck.
Posted on May 15, 2010
Testimonial: "thanks for the insight. I assume that I will have to disconnect the gas line and then reconnect afterward. Appreciate your information."
Humming noise in raypak 2100
if coming from gas valve or regulator replace if from heat exchange check manual bypass
May 15, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak 2100 just get SPK then LO codes. won't ignite
if wired 120 volt check wiring and check gas pressure see if lines have cobwebs
Jan 02, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
RayPak 2100 series digital pool heater Code "EOL".
press the mode button until the display reads "off". Remove the four screws holding the control cover on. Swing panel down so that the back of the board is visible. Press the mode button until "RESfl" appear. Press and hold both "up" and "down" buttons for 5-7 seconds until three dashes appear (---). This resets the fault history and clears any stored faults.
Sep 05, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak pool heater piliot light on heat will not turn on
Make sure that gas control knob is set to ON (counterclockwise). Make sure that ON/OFF switch is ON. Check that temperature setting is high enough to call for heat. Make sure pool pump is running and water is flowing to unit.
If not above there is a diagnostic procedure on page 33 of manual at:
http://www.raypak.com/uploads/6000.52AG.pdf
May 24, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak Free Hydraulic Lift Gate Delivery - No L... Logo
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
