Question about Sony KP-51HW40 51" Rear Projection Television
Red lines on Sony KP51HW40 Rear projection TV
I have KP51HW40 Sony rear projection tv for over 4 years now. I have started to get red lines going across the screen (horizontally in a curve not straight) and then in a while the TV turns all red. I will have to shut the tv down for a min or so and then turn it back on,its all good for a while. Then once again the same problem will come back in few minuts. I will appreciate if anyone has faced similar problems or have any suggestions of fixing this issue. I definitely would not want to spend over $500 to fix this, when the new TV can be purchased for $1000. Thanks Had the red line issue and fixed it but now it turns red and then shuts down like it overheats
    Problem Solver:
  • 6 Answers
Before you break down and have the tube repaired, it could be a faulty or mis-adjusted screen setting. These projection TV's have three individual CRT tubes. Each tube has a FOCUS and SCREEN adjustment on a block inside the TV. I have the 57" model of the same series of TV's and just had to do some work on it. If you remove the front panel and the small wooden panel behind that, you should see a block with 6 screw adjustments. On my TV the set on the right was for the red tube. The top screw adjusts focus and the bottom adjusts screen. Focus (as the name implies) makes the screen go in and out of focus. If your TV isn't blurry then don't touch the top knob. The bottom knob is SCREEN. This knob adjusts the brightness (power) of the tube. If this knob is turned up too high, red lines will start to develop across the screen. At first, they'll only be visible when the screen is black, but if you keep turning it up they'll become very visible. If you turn it up even higher the whole screen will become red. Running it at full power (the whole screen being red) will cause an electronic lockdown and shut off the TV (at least it did with the blue tube, I was playing with the knobs and accidentally made it turn all blue then click off. I waited a few minutes, turned the knob down, then turned the TV back on and all was fine again). What you need to do is simply turn down the bottom right knob until the red lines go away. Put the TV on a blank screen (all black, just having it on an unused video input works great) and then slowly turn down the lower right knob (red screen knob) until the lines go away. Then put the TV on a picture to make sure the red is still visible. Finally, turn off the TV and turn it back on and use it for a while (don't put it back together yet, but make sure the front panel buttons and LED's are connected). I had a problem where the TV gave me an error code 5 (AKB error, shown by the Standby light flashing in sets of 5). After some reading and experimenting I found out that it was giving me this because I had set the red TOO low. I turned it up until the lines showed up and then turned it just slightly until the lines just vanished (but no further down) and then reset the TV by going to the system menu (Display, 5, Channel +, POWER while the TV is off) and then pressing 8 then Enter (Factory Reset). If you simply follow my advice (don't turn the knob down any further than necessary, just to the point that the lines don't show) then you shouldn't get the error at all.
Posted on Jun 02, 2009
  • 126 Answers
Yeah, seen that more times than I shoulda in the last 4 years. The red picture tube has a cathode to heater short. That means it's no good. That red picture tube is no longer availible. But all is not lost. There is a company that rebuilds those tubes reasonably. Most reputable tv shops will know this. The ones I've done cost around $450 out the door. One minor hitch is that with all the shipping involved the job usually takes about three weeks. That can be expidited but then the price goes up.
Posted on May 28, 2009
2 Suggested Answers
SOURCE: Red lines on Sony KP51HW40 Rear projection TV
This should be a very simple fix. The lines on your screen are call retrace lines. Basically you need to open the TV and the job is about 15 minutes to solve the issue with arched lines, either blue, greed, or red. There is a great how-to guide here: http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Posted on Jul 02, 2007
Red out of place on a sony kp51hw40
red and green lights repeat but tv not start
Sep 29, 2012 | Sony KP-51HW40 51" Rear Projection...
MY TV DOES NOT TURN ON AND I HAVE A BLINKING RED LIGHT MODEL IS KP51HW40
the blinking red light is an error code. How many times is it blinking and I will let you know what the error is indicating?
Aug 22, 2011 | Sony KP-51HW40 51" Rear Projection...
I have a sony 50 in rear projection. 9 years old
Sounds like the CRT tubes are going out which is fairly common on Sony. Inside the back of the TV there are 6 knobs - 2 for each color...one is for focus - dont touch - the other for brightness...turn down the brightness just a hair untill the lines go away.
Dec 01, 2009 | Sony KP-51WS510 51" Rear Projection...
Red lines across screen
had tv that did the same thing after three years but they were green cost me 300 bucks to get it fixed and the guy said every 3 to 5 expect it
Jul 03, 2009 | Sony KP-51WS500 51" Rear Projection...
I have a sony kp51hw40 bigscreen projection type tv and the picture turns red after a while, like all red, should i replace it or fix it?
TAKE THE FRONT OFF. THEN REMOVE COVER FOR CRT'S.BE CAREFUL YOU DON'T PULL WIRES OFF THE KEY BOARD.WITH TV ON ,TURN THE RED SCREEN CONTROL COUNTER CLOCK WISE A HAIR.I BELIVE IT THE CONTROL ON THE VERY LEFT.TURN SET OFF THAN ON, TO SEE IF THAT SOLVED YOUR PROBELM.IF IT NEED NOT THAN TURN THE RED SCREEN CONROL SOME MORE.
Mar 27, 2009 | Sony KP-57HW40 57" Rear Projection...
5 flashing light code
Disconnect RED Tube CRT board if set plays without shuting off RED tube is bad or video IC on CRT is bad.
Feb 12, 2009 | Sony KP-51HW40 51" Rear Projection...
The screen turns red after being on for about 30 minutes
or
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Nov 10, 2007 | Sony KP-65WV700 65" Rear Projection HDTV
Sony Kp-65wv700 Too much red -- white looks redish
fix the red:
Nov 01, 2007 | Sony KP-65WV700 65" Rear Projection HDTV
cold solder on yhe red crt drive.u can find it at the back of red crt try to solder cold joint..or much better if u can refresh all the solder joint. also ,a corrosive terminal of red yoke might also be the culprit. hope this help u...
May 10, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
512 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
