Question about Fisher and Paykel Fisher & Paykel Washer
Fisher Paykel Smartdrive MW058K diagnostic mode query
I have learned how to test the valves and water pump in diag. mode.
Is there a method of forcing the spin cycle in this mode? Even it means standing by the machine for spin duration.
All wash cycles have completed OK then error 37 x'25' (00100101). Got this far with a scavenged pressure transducer. Do not wish to address transducer issues to solve this problem.
  • 2 more comments
  • goldentotara May 28, 2009
    My clothes are clean but wet. Everything but the pressure transducer is working perfectly. I just want to know how to force the actual spin!!! I assume there is a diagnostic facility, possibly unpublished, that does this.
    I will repeat a simple technical question. In diagnostic mode, for example, user can operate/test pumps and valves by manual control. So can the spin be operated/tested also?
    Diagnostic level 4 let me test lid, balance, pump, valves etc. No problem.
    Diagnostic level 11 shows current motor speed. This implies hidden software window to force spin to occur. If I can't find it i will have to buy a new board or keep swapping transducers until I get lucky.
    I will close the problem. But someone out there probably knows the answer!
    many thanks
    Brigadier General:
  • 8,619 Answers
Hi
I hope you are following this diagnostic procedure--
Hold "Wash Temp Down", then press "Power". Wait for the two short "beeps". Toggle the "Spin" buttons until "Hold" and "Slow Spin" lamps are lit. You are in Diagnostic mode and diagnostic lights will light up. Write down the LED's which are lit across the top row of progress LED's(start at the right and note which lamps are lit.)
Unfortunately the spin teset is not covered under the diagnostic mode. It can only be tested physically. However, i'll suggest you to check the lid lock assembly which is the usual problem with F&P wasing machines. The lid lock assembly has a solenoid which when dis-engaged doesn't let the spin cycle to start as the machine thinks the lid is open. Lubricting the solenoid can help. You can check out the lid lock assembly by clicking on the link below--
Fisher Paykel Smartdrive MW Series parts Manual
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on May 28, 2009
  • 108 Answers
OK U SHOULD CONTACT THE DEALER OFF UR Fisher Paykel Smartdrive MW058K diagnostic TELL HIM THE PROBLEM HE WILL SOLOVE THE PROBLEM WHY I AM SAYING LIKE THIS BECAUSE IT IS WE SHOULD CHECK WITH OUR HANDS AND HE WILL CHECK IT THAT'S WHY I AM SAYING TO CONTACT HIM OK RATE ME WITH UR CHOISE
  • k srinivas ganesh
    k srinivas ganesh May 28, 2009
    Brigadier General:
  • 3,917 Answers
Place the machine into diagnostic mode so you can read the bibary fault code. To enter diagnostic mode:
1. Have the machine plugged in and turn it off at the control panel.
2. Perss and hold the WASH TEMP DOWN the press the POWER button. The machine will give two short beeps.
3. Using the SPIN SPEED UP or the SPIN SPEED DOWN buttons you can get different information.
When you press the SPIN SPEED UP button until the HOLD and SLOW SPIN LED's are on, the WASH PROGRESS LED's will display the fault code. Interpret them using the tech sheet inside the control panel -- pray to pot-bellied, one-eyed, fish-smelly Buddha that you repairguy didn't "borrow" it.
Sounds like you you probably have a bad diverter valve.
fault code is #37, blocked pump error
Thank You
Can you give me the dimensions of the MW058k model (pride 5.5kg smartdrive) and can you also advise what model has replaced this one
560mm (W) X 560mm (D) X 920mm (H)
That model is 19 to 20 years old. There have been many models since then.
Apr 16, 2017 | Fisher and Paykel Washing Machines
Fisher and paykel intuitive washer what is a code 50 please
50. (00110010) Phase 2 to 5 - Hot Valve Fault
The Motor Controller has measured a voltage from the valve diagnostic circuit that indicates
that the hot valve is faulty. The most likely cause is that the valve harness has not been
connected correctly.
Primary Source - Wiring
Action - Check valve harnesses are correctly fastened to valves.
Secondary Source - Water Valves
Action - Check valve coils are not faulty ( open circuit ). If either of these valves are low
impedance it is likely that the Motor Control output has also failed, in which case replace Motor
Controller and valve(s).
NB. Phase 5 can give fault code 50 when Smartdrive powers off while spinning. In this case
there will be no fault.
Mar 18, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel Smartdrive MW058K stops during cycle and hot and cold water temp lights flash along with progress light
This means that the machine can't get any water or enough to wash with.Check to see taps are on hoses for kinks and filters in water hoses are not blocked.
Jul 24, 2012 | Fisher and Paykel Washing Machines
Fisher Paykel Smartdrive MW058K error code 106
106. (01101010) Display Module to Motor Control Module Communications Error
These faults are reported when the Display Module detects an error in the communications
between the Display Module and the Motor Control Module.
Primary Source: Display Module.
Action: Replace Display Module.
Secondary Source: Motor Control Module.
Action: Replace Motor Control Module.
Jul 23, 2012 | Fisher and Paykel Fisher & Paykel Washer
Fisher&Paykel Laundry: Fisher&Paykel Washer: smartdrive 058 leaking by the pump...
Hi if you can see the water leaking from the base of the pump pump needs replacement better to do now than later when pump fails and takes out main board :)
May 18, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher paykel smartdrive 601
I can talk you through diagnostics if you want to go on live chat cheers
Mar 13, 2009 | Fisher and Paykel Fisher & Paykel Washer
Fisher Paykel GWL10US Washer won't spin
Look at my issue on "eco smart won't drain, smells hot". You could have same issue and your motor just hasn't burned up yet.
Oct 16, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel GWL10US won't spin
hi
if the pump works fine in diagnostic mode then it has tobe a module problem
cheers grant
Oct 15, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel GWL10 US spin cycle issue
check out another website. ths.gardenweb.com/forum/laundry for other fix it tips on FPaykel.
Oct 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel Smart Drive 608 wont spin
remove the pump from underneath front right move whith clip forward the twist pump out.but you will need to remove all the water first you may a ball of lint stuck in the pump.hope this helps.
Mar 29, 2008 | Washing Machines
Washing Machines Logo
369 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
