Question about Olympus FE-150 Digital Camera
The zoom wont go back in. it is stuck up
The zoom lens wont open or wont go back in.
  • 4,472 Answers
Most likely the lens has been knocked out of alignment.There are some things you can try but beware.
If your camera is still under warranty, the best thing you can do is to take it to the nearest official repair shop and they should fix it for free.
If your camera is out of warranty, or if the manufacturer refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try the following methods to repair it yourself.
First, make sure your camera has fresh batteries and it is in recording mode.
Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
Another method is to tap the padded USB cover part on a hard surface, for example, a desk. Sounds simple, but it works.
Try forcing the camera lens. Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended. Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
Posted on May 28, 2009
I am getting zoom error on my screen and the lens wont open
Most cases its the lens motor stuck or burned out, I would suggest nothing less then having a camera shop look at this for you.
The cause:
1. stuck motor from debris
2. burned out motor
Take the batteries out then on the front of the camera give the camer a little tap, put the batteries back in and see if this does it, if not take it to the camera shop.
I hope this helps
Jul 07, 2010 | Cameras
The zoom won't go back. It's stuck. I can hear
Hi there its happens when the lens not ready for work. Some how its not able to stable his focus method. That's why its stuck. There is a chances of lens guide pin disturbed or damaged & thats why continues failure. Its mean he inform you there
is a system error. So please visit the service center for repair that. Its a very common & repairable problem. Thanks.
Apr 05, 2010 | Sony Cyber-shot DSC-W300 Digital Camera
Zoom is stuck and it wont stay on
Have you tried using a fully charged battery?
also, there could be a dust build up or a sand residue stuck inside the lens that it why its having a hard time coming in or out eventually.
Try to hold your camera, with the lens facing down, from your right hand and while turning it on, hit the camera gently on your left palm. Try this several times.
Sep 04, 2009 | Panasonic Lumix DMC-LZ3 Digital Camera
How can i repair my D60 Nikon lens? It wont zoom in or out ?
Sounds like its damaged, if the zooming is stuck. It might have fallen causing internal parts to damage.
I strongly recommend contacting Nikon service for this kind of repairs, because its far too easy to trouble the glass if you open it. I mean even if you manage to fix the issue many things can go wrong inside and the lens wont be come out clean. Better to leave it to professionals here.
Ruchir
Aug 13, 2009 | Nikon D60 Digital Camera with 18-55mm lens
It wont turn on, And the zoom is extended.
I had exactly the same problem. Lens stayed open, when powered on you get three beeps and nothing. I found when I pulled the lens out a little harder it gave a little click. When I powered on it worked perfectly.
Nov 25, 2007 | Samsung Digimax S800 Digital Camera
Olympus FE-150 Digital Camera Logo
138 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
