Question about Motorola Cell Phones
My last question was how to use redial on my phone
I received an excellent response as to where redial was listed on phone and to make sure it was turned on, and it was but I don't know how to use it. What key do you press to phone same number again?
  • 1,305 Answers
Try holding down the send button for a couple seconds... it should redial for you..
Posted on May 28, 2009
Automatic redial phone option
On most cell phones, to redial the last phone number dialed, press the green phone icon when the keypad is displayed on the screen. You can only redial the last number dialed. To obtain a copy of the user manual, follow this link and download the pdf. http://www.gsmarc.com/huawei/ascend-g610/manual/
Nov 14, 2013 | Huawei Cell Phones
Uniden cordless phone caller id quit working
Using the Caller ID and Redial Lists
Caller ID (CID) is a service available from your telephone provider that shows the phone number (and sometimes the caller's name) of incoming calls. Contact your telephone provider for more information.
Caller ID list
Redial list
When a call comes in, the phone displays the number and name (if available) of the caller.
The phone saves the information for the last 30 received calls to the
CID list.
When it's in standby, the handset shows how many calls came in since the last time you checked the CID list.
Each handset remembers the last 5 numbers you dialed on it. The redial list is separate for each handset.
Dec 02, 2012 | Uniden Cordless Phone
Where is the redial button
The phone remembers the last five numbers dialed. To see the redial list, in standby mode press the PAUSE button (marked with an arrow curving back upon itself).
Sep 08, 2011 | Uniden D1680 Cordless Phone
Where is the re-dial?
Hi, Hope this helps.
Making a call using the redial list
The last 5 phone numbers dialed are stored in the redial list.
  1. 1 {REDIAL}
  2. 2 Press {^} or {V} to select the desired number.
  3. 3 phone icon.
I have also inserted a link to the manual below: http://service.us.panasonic.com/OPERMANPDF/KXTG5631S.PDF
Hope i have helped, ALAN
Jun 28, 2011 | Panasonic KX-TG5632 Phone
HOW TO USE RECALL KEY OR HOW TO USE THE REDIAL FUNCTION
Don't confuse the two. In most systems, the RECALL button gives you new dial tone on the line you're currently on, and the REDIAL function will dial the last number dialed or a saved number.
Since you're asking about a phone and did not list the SYSTEM, if you set has Last Number (LNR) or just redial, when you press the button, it will either try to use the last line dialed, or you may have to select an outside line and get a dial tone, then press the LNR button. It will dial out. If you press the RECALL button, it will drop your present call and give you new dial tone without having to hang up, pick up the handset, and select a line. You may actually have to press both buttons to effect a LNR sequence.
Carl
Aug 18, 2010 | NEC ETJ 16DD-1 Corded Phone (necetj16dd-1)
HOW TO Solve auto redial Problem on samsung E1100T ,MY SAMSUNG MOBILE AUTOMATICALLY REDIALING FROM RECENT RECEIVED CALL LIST . I LOST MY ALL BALANCE.PLEASE SOLVE MY PROBLEM .
thats simple...
1.go to "call settings" in your mobile.. there if you see ..sometimes you get two options as "all calls" and "voice calls".. choose voice calls and inside this auto redial ill be there ...turn it off
2.go to "call settings" and there itself if u find auto redial ,turn it off..
if any clarifications ..mail me simplY ..."ssgodfather@gmail.com"
"DONT FORGET TO RATE THE SOLUTION.. RATING KEEPS ME ALIVE AND MAILING YOU"...
Apr 15, 2010 | Samsung SGH-J600 Cellular Phone
When putting the phone in the clip sometimes it will redial the last number called. I don't see any buttons on the outside that would redial. I know the right button on the right top brings back the last...
The right button on the right top that brings back the last dialled number may be the culprit. Check to see if a long press on this button redials the last number. If so, then the clip is pressing it too long. Can you avoid using the clip or modify the clip so as not to press this button.
Nov 09, 2009 | Motorola Mobility i560 Cellular Phone
Recall last phone call to see number
Press "Redial" then *(star). The redial key is a multifunction key. You can either use redial or utilize the phone system speed dial directory.
Jan 09, 2009 | NEC DTH-8D-1 Corded Phone
Continuous redialling of most recent number
there may be some virus attack...
give restore factory settings ... this solves your problem....
Feb 18, 2008 | Samsung SGH-D900 Cellular Phone
Incomplete info code 634 how to fix
That codes says:
"Redial count over with no response
or busy tone was not detected.
Note:
U.S.A. and Canadian models
will redial only once if a busy
tone is not detected."
The number you're dialing was first busy. When it went to redial, it detected no phone signal on the other end. If it happens to only 1 or 2 customers, then it's something to do with their lines and you can't fix that.
If it happens often, then get your phone lines checked out by your phone company, make sure your fax is not sharing the line with another other device and make sure it is not a digital line.
Other than that, you're looking at having to replace the main board in the fax. Which basically means it's time for a new fax machine.
Jan 02, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Cell Phones Logo
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Trisha
Trisha
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
