Question about Dell E228WFP LCD Monitor
MONITOR HAS WHITE SCREEN IN SLEEP MODE
MONITOR HAS WHITE SCREEN WHEN IN SLEEP MODE
  • Anonymous Mar 12, 2014
    I have a dell monitor SE197FP...how do I get it out of sleep mode
    President:
  • 1,623 Answers
Hello sillypw...Try using the monitor, on a different PC, Try lowereing contrast to 60% or lower. and the brightness to 50%
Check that there is no damage to the cable and connectors.
If none of that helps... the monitor itself is likely, possible faulty panel or invertor board.
Good luck...i hope this helps.
Posted on May 28, 2009
My screen is saying burn in and keep switching colours all the time.(white,red,green,blue.
You may need to send in unit for service because your unit is unable to go to sleep mode when the signal cable is disconnected or the PC is turned off. Please call ViewSonic Customer Care for support.
Although this will not hurt the monitor, you just need to apply an active video signal to get a display correctly. However, it will not work as expected to go into sleep mode. You'll need to call ViewSonic Customer Care to get this taken care of.
May 09, 2014 | ViewSonic VA721 17" LCD Monitor
My monitor seems to be stuck in sleep mode
This happens when there is no communication with video card. Check cables, re-seat video card, make sure monitor is set to correct mode. VGA (15pin blue), DVI (white), or HDMI.
Aug 28, 2012 | Dell desktop and monitor- Inspiron 530...
When the CPU switch on, the system running upto 10 minutes. after that the monitor screen automatically off.
Here is artical I found on how to disable sleep mode on a monitor, this would be for VISTA or 7, if you are using XP it's a bit different. ____________________________________________________________ How to Disable Sleep Mode on a Monitor
Your computer monitor or laptop screen will enter sleep mode after your computer remains idle for a set period of time. You can disable sleep mode if you prefer the screen to remain illuminated. You merely need to change a setting in the Windows Power Management properties box.
Difficulty: Moderately Easy Instructions
  1. Click "Start" and "Control Panel".
  2. Click "System and Security" and "Power Options". This will bring up a new dialog box.
  3. Click the menus to the right of "Turn off the Display" and set them both to "Never". This will disable sleep mode.
Read more: How to Disable Sleep Mode on a Monitor ' eHow.com http://www.ehow.com/how_6953659_disable-sleep-mode-monitor.html#ixzz1CiGFFyLk
Feb 01, 2011 | Acer AL1916W 19" LCD Monitor
Screen bleeds into white after coming out of sleep mode. Turn on an off a couple of times and screen is fine. Is it my video card or is my monitor dying?mag FP-2226AFW 22"
guest, FP2226AFW may have internal "switch-mode-power-supply" problem. Swollen electrolytic filter capacitors or "thermally fractured" component leads to printed circuit board solder joints that will need to be "reflowed" to restore unit to normal operation. Prove that problem is monitor by swapping-in a known-good monitor to your pc first!!! If pc is ok, then 2226AFW unit will need "tear-down" and Inspection" of it's "switch-mode-power-supply/cold-cathode-fluorescent-lamp INVERTER power supply printed circuit board. Do some reading in my fixya profile and those of other CCFL back-lit lcd monitor tech's and you may just find a solution. All CCFL back-lit lcd monitors of the same basic design and functional operation. 12fixlouie
May 20, 2010 | Computers & Internet
Are screen savers good for TFT monitors
unless the monitors are being turned on and off frequently the sleep mode idea is alot more efficient
Mar 30, 2010 | Dell E197FP LCD Monitor
My monitor does not power up when I come out of sleep mode. The screen is either dim going to black or white. I keep having to unplug and replug to get the screen to work.
mishwilly. If monitor will do same thing with different KNOWN GOOD pc, then monitor will need it's "switch-mode-power-supply" fixed. Could also need CCFL inverter circuit checked! Do you have warranty service? Follow the links to other web sites that you find in my FIXYA profile to read about other options open to you. 12fixlouie Read, read, read.
Feb 04, 2010 | Samsung 204T 20" LCD Monitor
Blank screen
Hi this is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen went white, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace.
Thank you,
Mar 18, 2008 | Mag Innovision LT776s 17" LCD Monitor
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
Mar 10, 2008 | Computers & Internet
MONITOR
change the pc to stop it from going to sleep
Mar 03, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Dell E228WFP LCD Monitor Logo
523 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
