Question about Lexmark X125 All-In-One InkJet Printer
Paper feed The paper will not feed on my x125. It goes down about an inch and then stops. The rollers are turning but the paper won't feed
  • Anonymous Jan 02, 2008
    Paper won't feed even when I put more in when it says its empty.Roolers are working.
  • 4,889 Answers
Looks like something is in the way of the paper...Refer this link..I have already posted this solution..
http://www.fixya.com/support/t224821-feeds_paper_crooked
Posted on Oct 21, 2007
Everytime I send something to print the printer starts normally, it grabs the paper to start printing but then the paper never moves again. It sounds as though the document is actually printing but theres...
I don't know what printer you have, but this applies to all printers. The first paragraph is just for inkjets. The the whole is related to laser printers.
85% of paper jams are caused by worn rollers. The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease.
Metal Tab Separation- Pull out your paper tray and examine either end where the paper sits in. If any of the corners are held down by metal tabs, this is your paper feed system. Chances are, you only have one rubber roller or one set of rollers arranged along side of each other. Reach in where the tray goes and feel up. You should feel some rollers. They might be completely round, or they might be shaped like a half moon. Clean whichever part of them you can with the solution, and this should stop your paper jams. It might be necessary to turn them, but don't force them if they don't move freely.
Pickup Roller and Separation Pad-
If your printer uses this paper feed system, you should see a small piece of flat or slightly curved rubber or cork. It would be towards the end of the paper tray, or deep inside the paper loading cavity on top loaders. This 'separation pad' rubs against the paper feed roller, so if you find the pad, you've found the roller. Clean it and your jams should stop.
Three Roller Paper Separation System- Pull your paper tray out, and look for a roller on either end of it. If you find one, clean it. Then look inside the printer where that roller would rest with the paper tray inserted. You'll find another paper roller there. Clean this one also. Finally, look further back or closer to the front of your printer (depending on which way your paper feeds) to find another roller or set of rollers. Clean all of these, and your paper jams will go away
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 15, 2011 | Office Equipment & Supplies
Samsung 1710 stops before printing
to fix the problem you have to press the plate that the paper sits on down until it clicks into place once you do that it should work fine.
Oct 29, 2007 | Samsung ML 1710 Laser Printer
I've had my brother mfc-7440n for over 2 years and it's been working great until this past week. Now, it has a paper jam every single time I try to print anything, causing me to have to remove the...
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
Jul 10, 2011 | Brother MFC-7440N Laser Printer
My Dell 1110 laser jet printer begins to pick up a sheet of paper, but then stops just as the paper turns up with the roller. This will happen several times before the printer actually picks up the...
Three Roller Paper Separation System- Pull your paper tray out, and look for a roller on either end of it. If you find one, clean it. Then look inside the printer where that roller would rest with the paper tray inserted. You'll find another paper roller there. Clean this one also. Finally, look further back or closer to the front of your printer (depending on which way your paper feeds) to find another roller or set of rollers. Clean all of these, and your paper jams will go away.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jun 20, 2011 | Dell 1110 Laser Printer
MX340 printer will NOT feed paper -- first sheet goes in about 2 inches and THAT IS ALL! This problem started suddenly -- all other functions appear normal. have even turned upside down and shaken to...
Two things you could try:
1) Your pickup rollers are dirty/worn:
Remove the tray, you should see either in the front or back some rubber rollers that feed the paper into the machine. These are much like tires in that they need thread to move the paper - if they're worn out, they need replacing - if they have a lot of paper dust or other stuff on them try to clean them with a moist lint-free rag. (Water only is fine, rubbing alcohol if they're bad)
Also look for a seperation pad, this will be a rubber or cork pad under the rollers. Clean this as well and if it's worn, replace.
2) A sensor is stuck or malfunctioning:
Run a page, make a mental note of where it stopped. Run another, did it stop in the EXACT same place both times?
Look in front of where the paper stopped, is there a small plastic flag right before the paper? Is it damaged or stuck? Try taking some canned air to that flag/sensor and try again.
Usually situations like these are either just simply worn/dirty rollers not feeding paper to the sensors in time or the sensors are damaged.
If neither of these resolve the problem then you may be looking at a solenoid issue or something else you wouldn't be able to repair on your own.
May 31, 2011 | Canon MX340 AllInOne InkJet Printer
Paper feed issues when there is no Paper jam. All the rollers move when the printer tries to feed paper. It'll feed about and inch and a half of paper and then stop showing a Paper Jam.
Thanks, Joe
May 19, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
My CLX 3175FN printer continues to have a paper jam. Right now I cannot print any paper size without it jamming. What can I do to correct this problem?
Paper jams
85% of paper jams are caused by worn rollers. The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Also:
Start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at the drum and the paper underneath. If the issue is there at that point then it would point to the cartridge. If not then it is in the fuser area.
Thanks, Joe
Apr 21, 2011 | Samsung CLX-3175FN Printer
Paper won't feed through. goes about 2-4 inches the stops no matter how many times i clear the jam.
Hi If you remove the toner/drum unit and look into the back of the printer you will see the paper feed roller and just above it a long thin foam covered roller. Clean this foam covered roller with a damp cloth, it will be covered in toner and too slippy to feed the paper. Turn it and clean until it feels sticky again, all should now work !
Aug 31, 2010 | Samsung ML-2240 Laser Printer
I had a paper jam ,I removed the jam now I get a error message that says E3 and the paper goes down about two inchs then stops going down and the E3 come up is continues to make noise like itis still going...
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 27, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Won't feed paper
Hiya .. Your roller guides.. just need a general clean... and the sensors located just on the inside of the printer at the bottom where the paper sits ..
Regards Faggly
Mar 25, 2008 | Epson Stylus Photo R300 InkJet Printer
Lexmark X125 All-In-One InkJet Printer Logo
41 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
