Question about Maytag Neptune MDE5500AY Electric Dryer
Loud banging noise while drying
I have a Whirlpool Imperial Series Electric dryer YLEN2000KQ1,ML4901093 are the numbers found on label. When the dryer runs with no clothes it sounds okay(like a little stone inside) but when there is a load of clothes the sound becomes a loud banging noise like heavy shoes inside? Can you help
  • KEN LaPOINT
    KEN LaPOINT May 11, 2010
    Sounds suspiciously like one of the drum roller bearings is locking up. if you open the dryer, and with the door open, if you turn the drum by hand, does it move smoothly? quietly?... how about turning the drum by hand and putting a little bit of downward pressure on the rear of the drum... is it worse?... if so, you may get by with changing the rollers... let me know what you find out...k
    President:
  • 1,136 Answers
Hi, There is a good chance the rear rollers (drum supports) are going bad. You will need to remove the front panel to see if this is the problem.
UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off.
When you remove the drum, notice how the belt threads through the idler pulley and sets on the motor pulley.
I hope this helps you. Please let me know if this helps and if I can assist you further.
Vic
Posted on May 28, 2009
  • 331 Answers
The Idler bearing maybe going. its fairly easy to replace. go here http://www.repairclinic.com/Maytag-Dryer-Parts?s=b4a8c203
the part is cheap and i will show you how to remove the front door and replace the bearing.
Maytag neptune dryer making loud banging noise mde6700ayw
First, check the vane's (paddles inside the drum) to see if one is loose. Post back the results.
Nov 06, 2012 | Maytag Neptune MDE6700A Electric Dryer
We have an estate by whirlpool dryer that quit working. During last cycle it made a loud bang noise that ended the dry cycle and the clothes inside were dry. When we tried to restart it, it wouldn't...
The fuse is tied into the door switch circuit and looks like this:
Unplug the dryer and remove the rear cover. All the heater components is back there.
Service manual and more info are HERE at my FixYa tip.
Jul 17, 2011 | Estate TEDX640JQ Electric Dryer
My dryer is making a loud banging noise a few minutes into the cycle
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Sep 05, 2010 | Whirlpool WED5100VQ Electric Dryer
When we turn on our Whirlpool Supreme electric dryer, it heats up and dries clothes, but it is making a loud squeaking noise throughout the cycle...sometimes louder than others.
The squeaking noise can be caused by any of the following.
Location High:
Belt slipping on the dryer drum
Worn Drum seals but would sound more like a dragging noise
Location Low:
Belt tensioner pulley bearing frozen and the idler pulley shaft is spinning inside the belt tensioner assy.
Belt slipping on the motor bearing
Motor bearing is dry
Thanks for using FixYa!
Kelly
Mar 04, 2010 | Whirlpool LER5636P Electric Dryer
Whirlpool imperial series dryer heats not spinning
This problem is almost always a broken belt. Yes you can do it yourself.
Go to repairclinic. com and put in your model number for the exploded view of your dryer. Locate the belt part number and belt orientation.
Jan 03, 2010 | Whirlpool Dryers
Looking for the age of Whirlpool electric dryer model number LET7848AQO Imperial Series CleanTouch 7 cycle 4 temp.
Link Below will give you the ability to calculate your manufacture date from the letters in the SERIAL number.
Whirlpool Date Codes
Sep 09, 2009 | Whirlpool Dryers
Dryer won't start
Could be a blown fuse.Check out repair manuals and more pix HERE The fuse looks this:
Sep 01, 2009 | Dryers
Whirlpool imperial dryer model ylen2000kq1 the dryer will take three complete cycles to dry 5 towels. Also the vent outside clogs with lint and has to be cleaned out every week
you have a heat coil out most likey, if you have an ohm meter you can check it out. reply to this post and I will give you the instructions
Jun 22, 2009 | Dryers
Loud Noise While Drying
Your rear drum bearing is dried up and need to be re-gresed with high temp grease
Jan 05, 2009 | Kenmore 60172 Electric Commercial Dryer
Whirlpool Imperial Electric Dryer won't start
I have a problem with my Whirlpool IMperial electric dryer, not a Duet gas dryer.
Jul 12, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Maytag Neptune MDE5500AY Electric Dryer Logo
286 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
