Question about GE Profile Prodigy WPSE4200A
GE Prodigy gas dryer will not start
Model DPSR513GAWW.  Sensor lights are on except for "Time Dry" section.  When dial is turned to start unit, only a "buzz" sound is heard, and does not turn on.  Would appreciate any help.. need to know if this is worth fixing!  Thanx...
  • 1 more comment
  • Anonymous Dec 10, 2007
    my dryer will not turn on at all. just got it wired to run now wont even turn on
  • Knitter1028 Dec 27, 2007
    Dryer keeps shutting off before the cycle is complete. Any ideas on how to fix this?
  • Big Steveb Aug 19, 2008
    My dryer starts ok, but when you release the dial it goes off. It won't stay on unless I keep the dial in the Start position.
  • 196 Answers
The buzz you are hearing is most likely be caused by the motor. The motor may be stuck from a restriction or it may be faulty.
Shutting off before cycle end ? Check the vent line. It may be partially clogged.
Won't run at all ? Something may still be wrong with the wiring. Check the breakers and make sure you have 220V at the recepticle.
Posted on Jan 12, 2008
Where is the igniter located on a ge profile dryer
You need to take the front off the dryer and it will be alongside the gas tube going inside the combustion chamber. The igniter is one of those curly wand types and has a quick disconnect connector on it and is secured with a couple of screws.
Here are some diagrams that might help you:
GE Gas Dryer Parts Model DPSR513GA
Good luck.
Oct 17, 2014 | GE Profile Prodigy DPSR513GA Dryer
Wirlpool Estate Gas Dryer that does not dry
i think your temperature sensor is defective in the dryer section..
check it out
May 04, 2008 | Dryers
GE profile dryer Pilot lights on but not the whole burner
the pilot your seeing is the ignitor the gas valve coils are probably bad these are mounted on top of the gas supply valve on the burner tube,you need to unplug the unit and remove the top and front cover to access the valve and coils,there are 2 screws securing the gas coil valves onto the gas valve remove these and remove the bracket,unplug the coils and reverse to re assemble the unit
Feb 21, 2013 | GE Profile Prodigy DPSR513GA Dryer
Ge Profile Gas dryer - It takes 2 hour for a load of towels to dry - iis that normal?
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
Nov 15, 2010 | GE Profile Prodigy DPSR513GA Dryer
GE Prodigy dryer makes an electrical buzzing sound when I try to turn it on and it won't turn on.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Sep 03, 2010 | GE Profile Prodigy DPSR513GA Dryer
We have a GE Prodigy clothes dryer that makes a very loud sqeacking noise when it runs
sounds like a rear drum bearing thats gone bad very common with these units, the front bearing and slides should also be checked for wear at the same time,to replace bearing in back drum has to be removed completely. if your handy with tool and have and afternoon to kill its not that bad ,just rember to UNPLUG UNIT BEFORE ANY WORK
Aug 06, 2010 | GE Profile Prodigy DPSR513GA Dryer
Have a Maytag Dependable Care dryer. Model MDG9606AWW. The glow bar comes on, gas lights and stays on about 30 seconds, go off for about 30-60 sec. then comes back on for about 10-18 seconds. Then goes off...
Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Apr 01, 2010 | LG DLG5932W Gas Dryer
Ge prodigy takes way to long to dry an average load. This is a gas dryer and it is heating up.
chances are you have lint in the exhaust vent, exhaust pipe or the area out-of-doors.
Oct 06, 2009 | Dryers
GE Electric Dryer Heats up but does not automatically turn off
Change the sensor in the drum. Theres a sensor that tells it if there is moister in the enclosure.
Feb 12, 2009 | GE DBXR463GB Gas Dryer
Washing Machines Logo
161 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
