Question about Samsung HLR5067WX 50" Rear Projection HDTV
Samsung DLP keeps turning off
Samsung dlp changed bulb. Screen lights up faintly for about 30sec. Then tv shuts down
  • Martin Forsythe May 11, 2010
    Do you hear a buzzing noise from the set when trying to turn it on?
  • 76 Answers
Posted on Jul 16, 2009
Replace the bulb.
Posted on Oct 13, 2009
  • krimi Aug 11, 2011
    It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Power light blinking red..tv won't come on after replacing lamp
DLP TV Repair Tutorial - DLP Bulb Won't Turn On - YouTube
? 14:13
https://www.youtube.com/watch?v=5frOnh58Z6M
Jun 26, 2013 - Uploaded by ShopJimmy.com
DLP TV Won't Turn On Common How to Replace Ballast DeadTV ... solid green power light plus sound ...
• New Lamp Doesn't Turn On? Try This! - Fix Your DLP - FixYourDLP.com
www.fixyourdlp.com/forum/viewtopic.php?t=19
Mar 12, 2009 - 50 posts - ‎36 authors
Mine did the same thing after replacing the lamp. ..... TV won't turn on and Color Wheel is GOOD, Temp sensor is GOOD, Ballast is GOOD, and ... • NEW Bulb- still not working
Jan 14, 2010
• Resetting the Samsung DLP Lamp Counter/Hour Meter
Mar 20, 2009
• Samsung Dead Lamp, Black Screen, or Intermittent
Mar 12, 2009
More results from www.fixyourdlp.com
Samsung DLP: replaced lamp however tv won't turn on - HDTV ...
Dec 09, 2015 | Televison & Video
Samsung 50 inch DLP
Most Dlp sets have a fan for cooling the bulb this should start at switch on if it doesnt bulb will not light.
Check fan is pluged in & that blades can turn freely.
Oct 11, 2007 | Samsung (LTR268W) Television
Shuts off after a few minutes
This is a common problem for samsung DLP tvs and is due to the age of the lamp.
See this article for some solutions to extend the life, but in the end, you need a new tv or a new lamp.
http://www.ehow.com/how_4802985_fix-samsung-dlp-tv.html
Mar 07, 2011 | Samsung HL-S5087W DLP TV
My Samsung DLP model HL-P6163W keeps turning on and off and now lights are flashing. We replaced the color wheel last year and about two years ago the lamp.
could still be the lamp but it could also be the Ballast for the lamp has failed. I've replaced a lot of Ballasts on DLP machines.
Nov 17, 2009 | Samsung 61" Slim-Depth DLP HDTV
My 56 inch Samsung DLP keeps shutting off. I have
Once before I had this same problem and FixYa gave me the solution. When you replace the lamp door, there is a switch inside so be sure the door is put in at an angle so to hold the switch up. It solved my problem after numerous repairmen missed it.
Sep 02, 2009 | Samsung DLP HL-P5663W 56" TV
Have a 42 inch dlp samsung the tv is starting to turn it self off random. after being on for a long period of time
We have had the same problem with our 42" Samsung DLP - only two years old! We searched all over the internet for a list of ways to fix it. I found several things can help, including a switch that pops to the wrong position, cleaning the fan, etc. I put all the information together in a how-to format because it was so frustrating to go all over the internet looking for ideas on how to fix it.
Mar 14, 2009 | Samsung DLP HL-P5663W 56" TV
PROBLEM WITH SAMSUNG DLP TV
Apr 07, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP HL-P5063W
you have the same problem I have. The problem is fixed by changing the new light bulb. The problem appears again after 1500 hours of use. You can keep buying new light bulbs or avoid it by not buying another Samsung TV.
Sep 23, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HLR5067WX 50" Rear Projection HDTV Logo
592 people viewed this question
Jerry Greenberg
Jerry Greenberg
