Question about SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive
My flash drive will not operate when plug into my lap top.
I have a 1.0 GB SanDisk Cruzer flash drive. When checking my hardware it gives a code 10 error. I can use my flash drive on other computers. I do not know how to fix it.
  • John Snow
    John Snow May 11, 2010
    Is there data on the drive that you must have?
    President:
  • 1,623 Answers
Hello kjh87....
1) If you are using a USB cable with your device, check the cable to make sure it matches the speed of the device. Use USB 2.0 cables with USB 2.0 devices and USB 1.1 cables with USB 1.1 devices. Swap cables and check the device, if this does not work, proceed to Step 2.
2) Next, open Device Manager and look under the heading for USB Serial Bus Controllers. If there is a device with a yellow exclamation mark next to it such as USB Mass Storage Device. Double-click on the entry and check the Device Status. If the status shows something like
"This device cannot start. (Code 10)"
proceed to Step 3.
3) The easiest way to solve a USB error code 10 in Windows XP
is to follow the steps below to remove and reinstall all USB controllers.
A. Click on Start
B. Right Click on My Computer, click on Properties
C.Click on the Hardware tab
D. Click the Device Manager button.
E. Expand Universal Serial Bus controllers section.
F. Right-click every device under the Universal Serial Bus controllers node, and then click Uninstall to remove them one at a time.
G. Restart the computer, and allow the computer to reinstall the USB controllers.
H. Plug in the removable USB storage device, and then test to make sure that the issue is resolved.
For more information on Troubleshooting USB device problems, visit the Microsoft Support Article on this subject.
I hope this helps...
Posted on May 28, 2009
  • 3 Answers
Try backing up all ur data if you want then format your flash drive and it should be working perfectly
Hello, I have Sandisk Cruzer blade 4 gb pendrive. But now it shows I/O error while copying data to it. please give a solution.
Copy all the files from it to your 'C:' drive, and burn the files to one DVD-recordable disk.
Then, responsibly recycle the SanDisk, and spend $10 to buy a new flash-drive.
Copy the files from the 'C:' drive, or the DVD disk onto the new flash-drive.
Keep multiple copies of your files, just in case this "new" flash-drive also "fails".
May 23, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Sandisk Cruzer Micro 2GB Usb Flash Drive. Windows was unable to complete format!
Try this:
STEP 1 - Optimize the flash drive for performance
1. Plug in the device to the PC.
2. Double-click My Computer.
3. Right-click on the flash drive, then select Properties.
4. Click the Hardware tab.
5. Select the SanDisk Cruzer USB Device disk drive, then click Properties.
6. Click the Policies tab.
7. Select Optimize for performance, then click OK.
STEP 2 - Format the flash drive
1. Double-click My Computer.
2. Right-click on the flash drive, then select Format.
3. In the File system list, click NTFS.
4. Click Start.
5. Click OK to start formatting.
Jan 13, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
I emptied the cruzer 8Gb by deleting the files.
Reformat the drive. Plug it into the Windows computer, and right click on it in the My Computer folder. Select properties, and you can reformat from there.
Oct 29, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I have a sandisk cruzer, led continuously lights
I"ve seen a couple of these do this and the flash disc is broken and not working. Probably nothing you can do to fix it.
Sep 30, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My copmputer wont let me install a sandisk cruzer
Check you have your chipset drivers installed if not go to manufacture's website and download from there what Operating System do you have?Right click over my computer drop down to properties,click on hardware,click on device manager and make sure there is no yellow explanation points and see that all drivers are installed correctly.Have you plugged the sandisk into another computer to see if it is accessible on another machine?
Aug 08, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Cannot send pics to my sandisk cruzer, the send to tab does not give me that option, also i have no sandisk icon on my desktop. Here is what i have done to this point: Plugged in my Sandisk, decided that i...
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Jun 12, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
SanDisk 2GB Cruzer Micro USB I/O device error
I would recommend plugging your Cruzer into another computer. It's possible that your computer has corrupted or incorrect drivers for the flash drive. This is one cause of the yellow alert in Device Manager. If you move the flash drive to another machine and it works, you can save your data and make a backup copy. If your Cruzer doesn't work in a different computer (I would try at least 2 other working computers), it's possible that the flash drive is faulty.
May 13, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk Cruzer storage
Check the format. Make sure it's compatable with the operating system. Also check the size of your documents folder. If they are compatable, maybe there is something wrong with the flash drive.
Aug 22, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive Logo
785 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
