I just installed 512 additional RAM on my desktop and then tried to boot it up. The keyboard does not work and it won't boot up. Just a black screen with computer info on it. Could I disconnect something when I installed the memory?
Comments:
May 29, 2009
- I took out the newly installed RAM that did not work and went back to original. It worked fine. I then took out the old RAM and installed the new RAM in the same slot and then installed the old RAM in new slot. This seemed to work. Thanks for all the ideas.
It's most likely not seated correctly or it's incompatible with your pc or it may be that it has to be similar in size to previously installed ram ... I suggest removing the ram you put in and rebooting ... if this gets you back up and running, then you may try installing this ram and leaving the other out... let me know how it goes... and if I can help further..
Did you take the memory out and then see if it works with the old memory setup. Most likely either the RAM is not compatible or defective. Thanks and enjoy, Lee
Comments:
May 29, 2009
- Your very welcome glad to hear you got it working.
Thanks, Lee
make sure the ram is fully inserted and the two retainer tabs are locked in place and its in the correct position..hope this helps and thanks for voting!!
Please suggest the best external hard drive 320GB.. Which one should I prefer? Seagate or transcend...
(More)
Please suggest the best external hard drive 320GB.. Which one should I prefer? Seagate or transcend ?
What is the best NAS for about $300 (+, - $100)? I was looking at...
(More)
What is the best NAS for about $300 (+, - $100)? I was looking at http://www.bhphotovideo.com/c/product/629822-REG/Buffalo_LS_XH2_0TL_2TB_LinkStation_Pro_LS_XHL.html,I need 2 TB of space, about 40 MegaBytesPerSecond, bittorrent, dlna , and web (configuration) access.
the ethernet connection does not work, I have my dsl connected with a usb cord and would like to fix...
(More)
the ethernet connection does not work, I have my dsl connected with a usb cord and would like to fix the ethernet connection so I can hook up a wireless router.
My CD-ROM drive doesn't acknowledge DVD-ROM and some CD-ROMs. It plays music and films and most...
(More)
My CD-ROM drive doesn't acknowledge DVD-ROM and some CD-ROMs. It plays music and films and most CD-ROMs still work normally on it.
I checked on Dell and it appears they don't sell new CD/DVD drives for my model (Dimension E521) any more.
I did everything that was on the support pages on Dell, and still nothing works.
All the discs are clean, even one that is brand new (DVD-ROM) doesn't register.
where Ican I find the agp8x motherboard user's guide. I need conect the USB front cables and one DVD...
(More)
where Ican I find the agp8x motherboard user's guide. I need conect the USB front cables and one DVD burner with sata power and signal.
