Question about Dishwashers
Pushbutton control does not work
My Kenmore dishwasher model number 665.15829000 does not work any more. When you push the front panel buttons, sometimes other indicators light up. When you press any wash function, they do not work. The only button that works is the cancel button. I disabled power and I have taken it apart and reseated all connectors on the control board but it still does not work. My assumption is it is the control board in the door. Any comments?
  • 1 more comment
  • acaolsen May 28, 2009
    The lock on is not on. The push buttons behave in a strange way. For example, if I press the Hi Temp Scrub button, the Pots Pans, Quick Rinse and Heating indicator all light dim but the start button does not work. When I press the China Gentle button, the Quick Rinse, Pots Pans buttons light dimmly, the timing indicator reads 68 but the start button does nothing. The only thing that works is Cancel.
    I would have thought the same thing but only one switch works well (the calcel). Sometimes, when I press a switch, it activates LEDs on multiple switches. That is what makes me think it is the Controller board.
  • Jim Goldsmith
    Jim Goldsmith May 11, 2010
    Have you checked the door interlock switch?
    Sergeant:
    Champion:
  • 255 Answers
If you can clean or replace the mini pushbutton switches the better.i have the same hitch.
Posted on May 28, 2009
  • 1,869 Answers
Controler circuitboard
take it out and wash it down with rubbing alcohol then dry and reinstall
Don't worry; you won't hurt it
Why won't my Kenmore dishwasher display work properly?
follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 09, 2013 | Dishwashers
Regency problems
If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board
The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been ruled out, the main control board might need to be replaced.
Jun 14, 2013 | Maytag Dishwashers
No reaction when start button is pushed on Kenmore UltraWash model 665 dishwasher. The clear /drain button works. No water filling
you have a bad water valve or bad user interface that's the long control in the front of the dish washer.
Dec 17, 2010 | Kenmore Dishwashers
Will not stop washing
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%%%%
Apr 14, 2010 | Maytag MDB5100 Dishwasher
No power to the dishwasher
Remove the kick plate, there is a box where the power enters on right, If you have power than its most likely the control board. We have em and will assist you on the phone 704-819-6557
Mar 14, 2009 | Kenmore 24 in. 17032 Built-in Dishwasher
Kenmore dishwasher 665 Lock on light
You may have a stuck button as this will cause flashing of lights, try pushing button and see if it returns if not strike lightly above it with plastic spoon etc.
If this does not work u can buy the control panel from Sears for 190.00 but first go to searspartsdirect.com then type your model no. In required space click on shop parts on appropriate model, then go to troubleshooting then to won't start, then go down to how to replace control panel.
According to instructions you will only need torx screwdriver and less than 30 minutes to replace.
Jul 13, 2017 | Kenmore 16602 / 16604 / 16609 Built-in...
Lock Light Blinking
silly question but did you try holding the control lock button(perhaps its the heated dry button) in for 3 secs???? sonds as if the CONTROL LOCK has benn activated( child lockout)
Jan 14, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
I have a Kenmore Elite, model number 665.17263. The clean button green light is flashing. This happened once before and it was the heating element. The service guy showed me how to put a series of presses...
Push the Heated Dry then the SaniWash buttons. Do this three repeatedly until the whole panel lights up and then close the door. You should be good to go!
Dec 03, 2008 | Dishwashers
Dishwashers Logo
277 people viewed this question
Top Dishwashers Experts
Owen Barnes
