Question about Haier 14.3 lb. Washer/Dryer Combo
Cold drying cycle in my haier
My haier washer dryer does not heat up in drying cycle...is the element burner out and how can I remove and check it
  • 1,889 Answers
This is usally that the spade wire connector has fallen off the heating element remove the top of the machine and, check
Posted on May 28, 2009
I have cleaned out the vents to my dryer. And it still will not dry in one cycle. It takes 3 to 4 cycles before it will dry. It tumbles the air is strong and hot in the back
Hi.
Check if there is heath. If air is completely cold, check the heating element (in case of electric dryer). Heating element is tested removing it from appliance and reading Ohms with a multimeter to ensure it has continuity.
If there is heat, or if air is cold and element is good, test and replace the thermostats, there should be two or three of them placed in heating group and air ducts.
First ensure you have checked filter, vents and duct and removed lint.
If you want to contact an authorized technician call the number listed on the owners manual or on manufacturer website.
Jun 27, 2010 | Dryers
Clothes not heating up and remain wet
ok like i said before haiers can be tricky. if you where to remove the lid 2 screws in back pull forward and remove lid. you will see a silver peice i believe you will also see the fan. That metal peice should have 2 wires on it. that is your heating element. I am going by memory so dont quote me. but if you check with no power to the unit///unplug...check the 2 wires at that silver metal peice you should have continuity there. if not your element is bad. i belive it is located to the right of the unit directly under the lid. there is also a thermistate there as well I know those thermistates are not very good. and the last time i had a haier not drying was the thermistate.I think there might be 2 orange wires going to it. I hope this helps..
Aug 14, 2009 | Haier 14.3 lb. Washer/Dryer Combo
My HWD1000 Haier Washer/Dryer combo error EC4
EC4 is regarding: The temperature of air vent.
Within 30 minutes of dry cycle there is 5 minutes in which the temperature is not increasing.
The dryer heater is not working properly. Call a repair technician.
Alternatively, create a custom wash cycle with no dry cycle and hang dry the laundry if you are past warranty and do not want to pay to repair it.
Jun 11, 2009 | Haier HWD1000
Asko Washer/Dryer (WCAM 1812); Dryer not working.
Update: The dry cycle is now working! Apparently the automatic overload/shut off on the heating element got tripped. We had a technician out this morning. He unplugged the machine, removed the top of the unit, and simply pushed a little red/orange button that was on top of the heating element. When we plugged it back in the heating element worked again. The technician was able to troubleshoot this by checking the amps while running the dry cycle. But the proof was really when we did a load and the machine heated up (just like it used to) during the dry cycle. This was actually a relatively simply fix - though could be dangerous as you have to open up the electrical area. The reset button is rather inconspicuous and located on top of the heating element, which is long (runs front to back in the center part of the top of the machine - which you can get to by removing the lid/top outer housing) and silver - wrapped in insulation. It's pretty obvious. The button is in a little metal fixture on top of the heating element. The technician told us that the rest can get tripped when the unit overheats. (We think this happened when the laundry tub overfilled and the hose was totally submerged - the machine was working overtime to pump out the water.) The technician also warned that this can happen if the machine gets turned off suddenly mid-cycle - especially during the drying cycle. He said that the heating element gets so hot, it needs to have a gentle cool down period, which is marked on the dryer dial for the last 20 minutes of the cycle. I hope this helps others!
Mar 08, 2009 | Asko WCAM1812 Front Load Washer / Dryer
Dryer Problem
EC4 The temperature of air vent
You need to call for repairs. Probably the heating element is faulty.
You can create a custom program without a dry cycle and hang dry your clothing.
Nov 21, 2008 | Haier HWD1000
Haier XQG50-11
I had this same problem. There are two possible solutions. First, you need to look underneath (use 2 people) and see if any hoses are kinked. If that is not the case then the machine is pulling in too much water during the dry cycle. I'm hooked up to a sink so I just turn the faucet down until the water is just a trickle. This works for me. If yours is attached to the wall you need to turn down the cold water tap. Its a pain in the ****, but I discovered no one can fix this machine, not even Haier's recommended service A&E. I always know more than the repairmen, very sad. Hope this helped you.
Oct 31, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Dryer heats slowly
When dryer heats too slow, that means that there is a problem either with the heating element, the thermostat, or the vent.
See the following suggeations from Repairclinic:
Drying is too slow It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Oct 04, 2008 | Whirlpool Dryers
Haier Not Drying
most likly to be thermostat if you remove the lid you should see 2 little round thermostats on top somewhere some stats have a reset button on 1 of the thermostats if there is press it if it clicks try it on a dry to see if it works
Sep 21, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Zanussi WJD1667W not drying at all
I've got this machine, and all washer dryers tend to have two heating elements and it sounds to me that the heating element for the drying side of the machine's functions needs replacing. You could probably find a cheap element for the machine somewhere and get it fitted for a small sum.
Let me know if this rectifies your problem
WD Pro
Apr 24, 2008 | Zanussi WJD1667W Front Load Washer / Dryer
Haier 14.3 lb. Washer/Dryer Combo Logo
263 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
