No Instruction manual
We recently moved into a house with an APAC Sundowner Split System, providing heating and cooling. Neither us or the previous owners know how to program control panel so that it turns on and off automatically. Any advice would be appreciated John from Oakleigh 0425761663 Same story: just moved into new digs with a you-beaut reverse cycle air conditioner but NO manual. It's a Hotpoint HPS-250R.
  • lisa_mulcahy May 28, 2009
    Thank you - I think I need to get more information from the unit itself to finally locate the manual.
  • 2,005 Answers
This is for APAC
corp.carrier.com.au/content.cfm?content=111 -
This is for; Hotpoint
://www.geappliances.com/service_and_support/literature/
Posted on May 28, 2009
How can I set fan speed manually to balance temperature in house?
Basements are supposed to be cooler . after all they are basically a cave .
Oct 17, 2017 | Honeywell Electronic Programmable...
Spoke with independent contractor - he told me how to set the timer
Done thru mate at no charge
Cheers
John
May 28, 2009 | Carrier Heating & Cooling
Mitsubishi 3.5 split systme fault
green light flashing means there was a fault that occurred now it could be power failure which you can try to reset by turning off and on circuit breaker it might reset itself if not there is much bigger problem which need technician
May 10, 2009 | Heating & Cooling
Split system not heating
if its cooling fine the first thing to check would be the 4 way valve maybe its not switching over when you change from heating to cooling you would need an engineer to check this as you would need to check gas pressures
Apr 06, 2009 | Heating & Cooling
Looking for instruction manual on APAC sundowner s0180hr9ak
Go to www.diplodocs.com they will have it as a PDF file there. Please don't forget to give me a Fixya rating.
Feb 23, 2009 | Carrier Heating & Cooling
Thermastat on LG Split system
The star with a face is sleep mode, each time you press it you will see a 1 then 2 then 3 up to 7 appear in the lower right corner of the screen. This means that the unit will operate for 1 or 2 or 3 hours then switch off. The house with key if pressed will give you the actual room temperature assuming the remote control is in the same room. It will return to setpoint temperature in a couple of seconds. The triangle with face is termed "Chaos mode" The unit will stay on a preset temperature probably 18c but the airflow will vary and the louver will go up and down irratically or randomly, as it tries to immitate a natural breeze. The fan only button will put the unit into fan mode (no compressor driven cooling), the fan icon with circle around is for fan speed which goes up each time it is pressed. Hope this helps.
Jan 21, 2009 | LG LSC121PMA Split System Air Conditioner
REMOTE CONTROL SYMBOLS?
Yes my unit shows a snowflake, bucket with squares (my husband thinks it is a fire bucket), fan (which we know about), and a sun. Does the snowflake mean-use in winter, or does the sun mean-heat ? We have a ComfortStar and the only booklet that we got is the technical manual which does not help us.
Jun 13, 2008 | Sanyo 24KS32A Cool Mini Split Air...
Heating & Cooling Logo
402 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
