Question about Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One 8.9
My Acer gives me these new readings...
PXE-E61: Media Test Failure, check cable
PXE-MOF: Exiting PXE ROM.
Error 17
When I go into the set up, there is no reading for the hard drive it reads nothing....
I used to have Linux, but upgraded the memory to 1Gb, and installed Windows Xp...I didn't have a word programs, so I decided to download one, big mistake, after doing that all these new issues came in, making reach for tissues....I am new to these netbook...Can someone honesly help me Please...Thank you for taking time and reading this..
    Novelist:
  • 151 Answers
Http://www.nocrash.com/ncbbs/msgs/3247.shtml click the link directly  also click this link directly http://forums.techguy.org/hardware/104472-solved-pxe-e61-media-test.html
also click this link http://www.daniweb.com/forums/thread18870.html#
Question:Getting media test failure, check cable error when computer boots.
Additional information:This error message also relates to users who are getting the below error message or similar error messages.
PXE-E61: Media test failure, check cable
PXE-061: Media test failure, check cable
PXE-M0F: Exiting Intel PXE ROM
Answer:This issue is often caused by either an incorrect setting in BIOS or a bad boot device, such as a bad hard disk drive. To resolve this issue, we suggest you go through the steps in document CH000229relating to a similar error message.
http://www.computerhope.com/issues/ch000229.htm
thanks.check out all the links 1 by 1.as this problem relates to many reasons.so check out all the links 1 by1.
please do rate the solution.thank you for using fixya.keep updated.
Posted on May 28, 2009
E-E61 media test failure check cable pxe-mof exiting pxe rom. operating system not found. how do i find it
Hard drive lost communications with motherboard. Remove it and reseat it. Check BIOS if it sees the HD.
Disable PXE boot in BIOS or remove from 1st boot option. This is a LAN (network) boot option. It can't find a DHCP server, that's why the media test failure is displayed. It's usually used to load an OS image from network.
Oct 05, 2012 | Acer Aspire 9410z Laptop Computer 17"
PXE-E61 Media test fail, PXE-MOF Exiting Broadcom PXE ROM
Disable PXE in the Boot Sequence in the BIOS setup [F2]
Aug 10, 2012 | Dell Computers & Internet
Went to shut down comp. and screen said, and still is. broadcom undi pxe-2.1 v11.4.1 copyright [c] 2000-2008 broadcom corporation copyright [c] 1997-2000 intel corporation all rights reserved. ...
A "media test failure, check cable" means your hard disk failed. The bios can not locate the boot sector of the hard disk to begin loading the operating system.
"Operating system not found" means windows can't load because the Bios can not find the operating system (because the hard disk failed).
This is pretty much an unrecoverable error in terms of fast fixes. You can take the hard disk to a data recovery service if you need to retrieve important data or files.
Dec 05, 2010 | Acer Aspire 5610-2328 Notebook
Aspire 3682 PXE-E61:Media test failure.check
PXE error means that it is trying to boot from an ethernet / lan connection.
check your boot order options first and set it to boot
1. Hard drive
2. CD rom drive
3. Floppy (or usb if you know how to do this)
4. network(aka PXE)
If it still fails then yes there MAY be an issue with your hard drive.
Check all hard drive connections before running off for a new one.
This can be especially true with SATA type drives most of which dont have any sort of true locking device to hold the connections secure.
Sep 28, 2009 | Acer Computers & Internet
Acer aspire 5315 will not boot up, indicating no bootable device
Sounds like you wiped out the harddrive try reinstalling the os if that does not work you may ned a new harddrive
Mar 16, 2009 | Acer Aspire 5315 Notebook
PXE-E61: Media test failure, check cable Pxe-M0f: Exiting Broadco
PXE-E61: Media test failure, check cable (of the HARD DISK pls)
pls first check the hard disk seated in the bottom left side of ur notebook u have to take out the 7 or 8 screws first and then take take it out by pulling the connector gently and try to re seat or re fit the hard disk so connector can seat firmly in hard disk and then power up ur notebook if Error persists
then sorry to tell u my friend that ur Hard disk has CRASHED and not giving up files for OS loading kindly replace ur HARD DRIVE and restore ur OS thru backup disk u got
Pls take care of ur notebook from bumps and falls and hard impacts during operation and carrying bcoz the disk inside the HDD is very sensitive and gets damaged easily by impacts
pls rate me FIXYA for my diagnosis
Mar 09, 2009 | Acer Aspire 4720 Notebook
Error Message: PXE-E61 Media Test Failure Check Cable
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
Acer Aspire One Netbook 8.9" Notebook Logo
151 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
