Fan wiring ive been told by another tech to wire the cpu fan in a laptop directly to the power surpply as it does not recieve power in its current position and i know that it still works, i need to know where i should rewire it to? need detailed answear
  • fougzki May 11, 2010
    And also if you hook up in that particular usb port have it covered so that it will not be use by another device(additional load, chances of overloading, and damage).
    Ok that seems trying to connect directly with the power jack. But in that setup, the fan would run only when the external power source is connected. If you are not within wall socket your problem is always there. If fan voltage requirements is the same with the external power voltage input.
    In any case this could also make the cpu fan to run until the battery power is dried up.
    But first try to see the voltage requirements of the fan if this is 5Vdc and its amperage requirements. I think you can hook it up on usb port. USB port usually is powered with 5Vdc only the amperage sink of the fan and the amperage it can give does matter. This will look like you connect a laptop cooler on the USB port. On this setup you can actually like having a relay switch within the system just like the fan on its right place. Hope it gives you an idea.
    Novelist:
  • 101 Answers
That is absolutely wrong. You cannot wire the CPU fan to the power supply because you will most likely burn the fan out. The power supply (ac adapter) is most likely feeding 19 volts to the motherboard, which is broken down into lower voltages to run various components. The fan may only be a 1.5 or 3 volt component. Fan speed is controlled by the voltage, so it would spin up much higher than it is designed for.
And even if it did work, the fan would not step down or idle at any time so it would fatigue and burn out from constantly spinning at a high speed.
CPU fan failure would almost certainly lead to a cooked cpu, damaged motherboard or both. You should have the machine serviced to repair the fan circuit unless you are willing to risk the loss of the whole machine. It is too critical a component.
Posted on May 28, 2009
Help -- CPU Fan Failure bypass or pinout?
Yep I have a link below you can order the correct fan from.
http://store.cwc-group.com/y4574.html
I had the same issue here, we have 20 offices all running Dells. These fans seem to be used only on dell systems.
Feb 23, 2012 | Dell Dimension E310 PC Desktop
I broke the heat synch fan connector when replacing the fan. My guess is that I probably will have to replace the motherboard as this connector is on the mb. My laptop is Gateway mx6448. Is there a...
if you only broke the connector for the cpu fan, why do you have to replace the motherboard? just cut the wires and solder them directly to the motherboard , if the pins have broke off, if the pins are still there then just bend them straight and put the fan plug on them
Apr 11, 2011 | Gateway Computers & Internet
Had my motherboard changed by local repair shop. Both fans are now running constantly & it is deafening, also power light no longer comes on and was told it was "no big deal". Have 2 like computers,...
Ok so what fans? the case fans? the cpu fan? The power supply fan should always run. The case fan can be wired to the mother board and do an speed step system (slow to fast) depending on heat, same with cpu fan. As for the power light its just an matter of pluging in the wire from frount panel to the mother board pins for pwrled. Asus has an download for your board to get the pin outs.
http://dlcdnas.asus.com/pub/ASUS/mb/socka/sis741GX/e1766_a7s8x-mx.pdf
Feb 25, 2010 | ASUS A7S8X-MX Motherboard
Dell PC won't start
No beeps are heard, no CPU fan is turning on, only blinking yellow light. This brand usually experiences this problem.
  1. First, check the power supply. Disconnect connectors from the board and make a jumper wire for the green wire to any black wire. If the PS fan does not spin then it's busted, else proceed below.
  2. Reconnect connectors except the one with 4 wires, 2 yellow and 2 black, then switch on. If CPU fan turns on then you have a bad processor.
  3. If the fan is still not turning on then check the USB port pins for short circuit.. disconnect it from the board and switch on.
  4. Do the same with other hardware connected to the board.
PS: The metallic casing of computers must be connected to the common ground of the power utility to protect it from stray currents that result to damage of sensitive components such as processors, memory and hard disks.
Sep 26, 2009 | Dell Dimension E521 PC Desktop
Power switch light is on but no other poweris getting through, changed the power supply but same problem. light comes on power button but power supply fan doesn't even come on.
Sep 26, 2009 | Packard Bell (190169) Power Supply
Electrical cables are all black & I need to find which is live &
ac, aka, alternating current, is the type found in your house. dc, aka, direct current, is the type found found in your car...or any other type of battery. If you have a total of three wires, one green, (ground) and the other two are black, then the two black wires are your alternating current wires. If this is the case, hook up your black wire from the fan and light to one of the black wires, and the whites, or commons, to the other black wire. In alternating current it does not matter which wire goes to where.
If there are 3 black wires, and a ground wire, then you will have to use your volt meter, and check the voltage from the wires, you should take three readings (wire a-b, wire b-c, and wire a-c) two readings will give you 120 volts and the third will give you 240 volts (approx) The two wires that give you 240 are your hot leads, and are probably controlled seperatly by wall switches. Hope this helps.
Jun 22, 2009 | Dryers
Hello, i have a clio 1.6 1999 the cooling fan wont work.. i have replaced the switch. , the fan works when i give it power direct, ive checked the wiring to the relay and its all ok ive traced the wiring...
check the thermostat if the engine is running cold the fan will not come on or radiator may be blocked the radiator will be cold at the bottom
Apr 19, 2009 | 2000 Renault 181
Hampton bay fan with remot problem
You can try the universal receiver. The white, black, and green wires are the house wires. The receiver must match to these on one side. The wires on the other side go to the fan/lights. It is possible that one of these has come loose. If you try the universal, make sure the dip switches are in the same positions on both.
Or,
Take the fan down, and remove the receiver completely, from house wires and fan. (Make sure the breaker is off first!) Then wire the fan directly to the house wires. The blue wire on the fan is for lights. Wire it with the black wire in the same wire nut.
I'm assuming you have a wall switch that powers the wires coming from the ceiling.
By the way, I have never seen anyone control two fans with lights with one receiver. Usually each fan has its on.
Feb 09, 2009 | Hampton Bay 52 In. Ant. Brass Redington...
Fan no longer recieves power.
don't rule out bad motor yet, nor anything with a wire. Many possible problems: 1.) motor badly manufactured with wire ready to disconnect 2.) motor "fused" or has a wire that has melted...this can happen quickly with minimal smell 3.) some other wire inside unit has become disconnected
Jun 04, 2007 | Tower Aloha Breeze Fan
Computers & Internet Logo
901 people viewed this question
David Payne
David Payne
