Home | Canon | PowerShot SD870 IS Digital Camera | Lens Error - Restart Cam...
Canon PowerShot SD870 IS Digital Camera
Problem for Canon PowerShot SD870 IS Digital Camera
Lens Error - Restart Camera : Lens remains in extended position.
By ball_josiah on May 28, 2009
Canon Powershot SD870 IS. I powered the device and got the error message "Lens Error, Restart Camera". I've taken the battery out (its fine), reinserted the battery and powered the camera back on...and I continue to get the same error message. The lens remains in the extended position. Any suggestions? The lens is stuck in the extended position and will not retract. When I power it on it says, "lens error, restart camera" When I power off, then on again nothing happens. Is there a special reset button somewhere, what do I do?
Solution #1
posted on Oct 06, 2009
Somewhat Helpful)
hawkman88
Rank: Apprentice
Rating: 75%, 1 votes
I had the same problem with the same camera. Ended up twisting the lens by hand back and forth while powering the camera on and off till the lens pins finally realined and let it close properly. Took alot of patience and care but has worked since. Usual cause of this problem is powering camera while the lens is blocked from extending, ie in a case, laying on its face etc.
Was this helpful?
Yes
No
Solution #2
posted on Jul 04, 2009
Somewhat Helpful)
t00nz
Rank: Guru  Canon Expert Cameras & Camcorders  Expert
Rating: 91%, 1942 votes
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Was this helpful?
Yes
No
Popular Solutions for Canon PowerShot SD870 IS
Questions and Unsolved Problems for Canon PowerShot SD870 IS
Do you recommend Canon PowerShot SD870 IS Digital Camera?
Answer
Answer
how do we show video that has been recorded already cannon powershot sd870 is. which buttons do... (More)
Answer
when I take a shot close up the image is blurred. It seems to take a few seconds for the shot to be... (More)
Answer
I have a Canon SD870. I am getting replace battery with a fully charged battery. I have tried 2... (More)
Answer
My camera will no longer take a picture when a flash is needed. We can take pictures without flash,... (More)
Answer
Canon 870 when taking pictures outside they look fine in the lcd screen prior to shot then after... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon PowerShot SD870 IS...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
