Sephra Elite Chocolate Fondue Fountain Logo
Posted on May 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need replacement cord FEMALE GE Heat 'N Serve Baby Dish model D-3
Babydish 2 prongs about a half inch apart, a half inch long and a small pole , about a quarter-inch long, in the center (for grounding?) so the cord I'm looking for is female. GE model No. BA2D3 50-60 cycle 115 volts 160 watts - AC only . I would like a white cord if possible. This little appliance is for gently heating baby food so maybe that matters. Thank you so much. M
Anonymous
Level 2:
  • Expert 46 Answers
  • Posted on May 28, 2009
Anonymous
Expert
Level 2:
Answers
46
Questions
Helped
25319
Points
110
May have to buy parts and build your own extension cord! home depot or lowes, or ace should have what you need!
Which cord is the antenna on eclipse cd receiver model 8443
It will be the black cord with a female
connection half inch hole, or there will be
a small half ince hole in the back of unit
where the antenna wire will plug inn
1helpful
I have a Maytag dryer model MED5740TQ0 that won't start. Dryer was recently moved to a new location. House was being remodeled so plug and breaker had to be installed. Plug is a 3 prong and dryer had 4...
If you are only getting 120v to the dryer, you still have a breaker tripped. It should be right next to the single pole 30. It takes 2 breakers to get the 240v you need to run the dryer. Try resetting another breaker expecially the ones marked 30amp. You do need to get a double pole breaker installed even for safety reasons.
2answers
I have a 3 prung male plug, and a 4 prung female plug. Can I switch the 3 male plug to a 4 male plug?
Hi, and yes you can, its done all of the time. You want to change the plug on the wall, not the cord. That is the way it is done. Very simple. Turn off breaker to the 4- prong. Go to any hardware store such as home depot and get the 3 prong 220 volt female plug, both are the same volts, just made for different cords is all. The male is on the cord. On the 4 prong female plug thats on the wall, just loosen all 4 screws. 2- wires are hot, either black in color, a black with a piece of white tape on it is the neutral, and a bare ground which is much smaller. When installing the 3 prong female, you will use all 4 wire to. 2- hot, ! neutral, and a screw for the small bare ground. There will be a drawing on how to connect the wires with the new plug if you are not sure. Normally, there are 3 black wires, 2 hot , 1 neutral. Some times there may be 2 blacks and 1 red. A black and red will be hot.I am sure they will all be black. The plug is marked on it. It will have L-1, L-2, N, and Ground. When you remove the 4 prong female, it will be marked the same. Be sure the power is off! L-1 and L-2 are hot, and the 3rd is N or neutral. Then the small ground. Very, very, simple to change and to know which is which. The terminals on the plug are colored also. The 2 that are copper colored are for the hot wires. The brass or silver is the neutral. And you will see the ground screw. I hope I haven't confused you, it is very easy. Just when removing the wires to the old plug on the wall, which should be a 4-prong female, the 2 wires on the right and left side of the plug are going to be the 2 hot wires. The other large black is the neutral goes to top or bottom, its marked like I said with a N. and a small bare ground. Always change the plug on the wall to fit the dryer from 3 to 4, or 4 to 3. They are both 30 amp plugs, 220 volt. Very easy, you can do this!! Please rate me on my help to you.
Sincerely,
Shastalaker7
2answers
Need extra cord for my 42 cup hamilton beach coffee urn
I just called the company and ordered the lid for 10 dollars and change. they will also send me a manual so I would thing you could get a cord too
I just got a used kenmore model number 110 88752792 stackable washer and dryer. it had a 4 prong cord.I live in a travel trailer, it has a 24 inch wide space for a stackable washer and dryer that the 110...
You will need to get 230v to allow the dryer to work if your service panel has 230 you will need to get a 30 amp two pole breaker and run 3 wire #8 in size. Then get the socket and plug for the dryer. The 110 in the model number simply means made by whirlpool and is a pretty good machine but requires 230 volts to dry with heat.
Jul 28, 2010 • Dryers
4helpful
2answers
2answers
GE Dryer not producing heat
First, replace the door switch. Second, check the wiring of the new cord. It should be as follows:
Dryers come with a wire or metal strap connecting the center "neutral" terminal to the frame of the dryer. When using a four wire power cord, take that wire or strap off the frame. (it can be discarded or better yet, in case this dryer needs to ever be converted back to a three wire cord) connect the frame end of the wire / strap to the center terminal of the power block. Now, Green (ground) wire goes to the dryer frame, White (neutral) goes to the center terminal, and the Red and Black (both "hot") wires go to either outside terminal. (one to each)
Third, if you still have no heat, make sure there is strong air flow out the vent outside the house when the dryer is running. If all that is good, check for 240 volts to dryer. (dryers can run the motor on 120, but need 240 to heat). Comment back (including model number) if you have further questions.
Top Sephra Kitchen Appliances - Others Experts
john h
Are you a Sephra Kitchen Appliances - Other Expert? Answer questions, earn points and help others
