Question about HP LaserJet 4 plus Printer
Pc load letter
My printer is saying pc load letter when the catridge is full of paper MY SAYS PC LOAD A4
  • 105 Answers
Hi there this issue is caused by your driver defaulting to letter and a4 paper being used set your default paper size to a4 in the driver and also set tray to a4 this should cure the problem Regards AL "alstech"
Posted on Jun 07, 2009
  • 390 Answers
Most people use "Letter" as that is the most common size used in the USA. You currently have what is called a paper size mis-match. This printer is not able to sense the actual size of the paper so the printer must be told via it's settings that it has the letter size paper loaded. The computer is already set to letter so as soon as you change the printer's setting it should start printing again! Worst case scenario is you have to cancel the print job on the pc then reboot the printer after changing the settings.
Good Luck!
Rich Lilja
Posted on Aug 02, 2014
Code PC Load A4
This means that the printer is expecting A4 paper rather than letter size or whatever you are trying to use. Check your "Printer Options" on your computer and make sure that the appropriate paper size is selected. A4 is an international standard paper size that is 210 mm (8.27 inches) x 297 mm (11.7 inches) and therefore is just a bit narrower and longer than the American "letter" paper size.
To correct this, cancel the print job currently in the printer's memory, change the computer to the proper paper size, and send the print job again.
Jan 26, 2014 | HP LaserJet 4 plus Printer
Printer says " PC LOAD LETTER" will not print
Change in printer driver to use paper "A4" not "Letter" format
Jan 30, 2011 | HP LaserJet 4 plus Printer
We are having trouble printing on A4 paper. It keeps saying load paper. What are we doing wrong?
that come across as a very silly question! - what printer, pick one out of a thousand...
It may be that your PC is sending the wrong size to the ptr. Outlook typically sends "Letter" size and the printer may expect A4 and you gotta override (in HP ptrs. ) by pressing the GO button...
Jan 21, 2011 | Office Equipment & Supplies
Printer asking me to Load MP Feeder with A4 - the
factory reset should fix it unless the paper size ciruit board and levers have been physically damaged (back left on the printer in paper tray slot)
Feb 01, 2010 | Office Equipment & Supplies
WHAT DOES LOAD CASSETTE PAPER CODE A4 ERROR ON A CANON MF3240 . WHAT DOES THIS MEAN? THANK YOU
I talked to tech support at Canon, and he explained that the document I was trying to print was originally scanned with an A4 paper size, and my printed is set to Letter paper size, thus producing the error code. A simple solution is to "uncheck" the box that says "choose paper source by PDF page size". It worked!!
Jan 18, 2010 | Canon Office Equipment & Supplies
When you try to print from a networked computer the display goes from saying ready to print to load Tray 1 A4. The tray is full of paper
When you loaded the paper in the tray, did you tell it that the paper was A4 - it may be that on the printer or in the queue definition on the computer that the paper size for that tray is set to something else (eg letter) and the print you are sending is A4 so it is looking for paper but only thinks it has other sizes available.
Nov 13, 2009 | Dell 5110cn Laser Printer
Load A4
A4 is for european size, if you are printing on a letter size this is a mismatched.
you need to change your files printer properties to A4 or letter size, or change your printer paper size.
better yet cancel this document and send it again , this time by checking the printer properties was set to your desired paper size
Jul 28, 2009 | HP LaserJet 2840 Printer
Printer won't print says Load Tray 024-964
Make sure that the paper is the same size as requested by the print job.
Ours is setup with A4 paper and if someone tries to print something setup for Letter paper it just flashes
Load Tray
Letter
Nov 19, 2008 | Dell 3100cn Laser Printer
Pc load letter
1-are the guides set correctly?
2-is the sensor flag there? on the bottomof the machine when you take out the tray you should see a piece of plastic hanging and is very loose it is the sensor for the paper, ( although I have seen it work without it !!!!!!)
Aug 21, 2008 | HP LaserJet 4 plus Printer
HP LaserJet 4 plus Printer Logo
841 people viewed this question
Ben Johnson
