Question about Maytag MMV5100A Microwave Oven
Micro wave has come loose from hanger on bottom. Need to know how to reattach microwave to brackets. maytag mmv5100
    Scholar:
  • 91 Answers
MOST OF THEM YOU CAN TAKE THE SCREWS LOOSE FROMTHE TOP OF THE CABINET OVER THE STOVE, YOU NEED TO PPL, REMOVE TOP SCREWS HOLD IT AN TILT IT AN THEN PULL IT AWAY FROM THE WALL, MOST WALLL BRACKETS HAVE A HOOK THAT THE MICRO MOUNTS TOO IT 90%OF THE WEIGHT IS BEEN HELD BY THE WALL. GOOD LUCK LEAVE SOME FEEDBACK.!
Posted on May 28, 2009
My push button to open door broke. how do I get the door to open?
Disconnect microwave from power socket, remove cabinet outer cover,and lift the top or bottom door latch at micro-switch bracket with a screwdriver, the door can then be opened.
Oct 24, 2015 | Maytag Appliances Over-the-Range Microwave...
Where is the reset button located on spacesaver micro wave oven
  • locate the microwave's power supply cord.Remove the power supply cord from the wall outlet.Wait one to two minutes.Re-insert the power supply cord into the wall outlet. The microwave is now reset.
  • Mar 24, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
    My micro wave stop heating food, every thing dislay work fine. when start it make loud sound. Sharp carousel II, model = R-3A54, Manufacture jan,1993
    Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
    Microwave Oven Basic Troubleshooting Tips
    heatman101
    Jul 27, 2011 | Maytag MMC5000 Microwave Oven
    My micro wave is not heating everything esle is working . it was working find yesterday it won't heat water today
    Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
    Basic
    Microwave Oven Troubleshooting Tips
    heatman101
    Oct 11, 2010 | Maytag MMV4205 Microwave Oven
    Need to replace handle on micro wave can not
    I HAVE A GE PROFILE SPACESAVER 2.0 OVER THE RANGE MICRO WAVE, CRACKED HANDLE, WOULD LIKE TO KNOW HOW TO REMOVE HANDLE AND INSTALL NEW ONE.
    Dec 18, 2009 | Jenn-Air M439 Microwave Oven
    Boiling waer under micro wave lots of steam into micro wave, turn on micro wave ,pop noise like glass miro wave comes on louder hum than normal no heat
    Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
    A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
     Q - My microwave is running and sounds like it is working but will not heat up anything.
    A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
    Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
    A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
    Mar 03, 2009 | Amana Radarange Microwave Oven
    Wiring diagram Problem - Maytag MMV5207A 1100 Watts Microwave Oven
    This doesn't have the diagram hidden away somewhere inside? Check at the bottom edge of the control panel, transformer brack, or rear of the oven. Otherwise, you can find wiring diagrams of earlier models that may be close enough. Just enter your model number here: http://tinyurl.com/gv383
    Sep 04, 2007 | Maytag MMV5207A Microwave Oven
    Maytag MMV5100A Microwave Oven Logo
    114 people viewed this question
    Top Maytag Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
