Question about Cuisinart CPT-60 Custom Control Total Touch 2-Slice Toaster
When i push the lever down to make toast, it does not stay
I have a cuisinart cpt 60 custom control electronic toaster- 2 slice.
when i push the lever down to make toast, it does not stay
is there anything i can do to fix it?
is there a place to send it for repair, if not?
thanks, margo
  • Anonymous Mar 27, 2014
    cuisinart classic style electronic 4, the toast latch does not stay down therefore I have to hold it down if I want my toast to toast. I tried to take it apart to clean it but could not figure out how to open it after I had unscrewed to 4 base screws.
No solution, problem, my lever (sometimes) will stay down, sometimes not, but it makes a loud "ractething" noise many times when the lever is pushed down>
best, randy
Posted on Dec 12, 2007
    Problem Solver:
  • 11 Answers
This is a problem, our old toaster had this problem, and it would only work if we jammed the handle down, but don't try this, only because ours broke after we tried this, but if you can send it to the manufacturure, they should be able to fix this. If you don't what to do this, please phone me at 505 9181, but please call me from 8:00-10:00, 2:30-8:00.
Posted on Dec 06, 2007
The thing you push down to activate toasting will not stay down
Check to insure the surge protector has not popped out. Reset and try again. Make sure its plugged in or it will not stay down.
Feb 01, 2016 | Cuisinart CPT-160 Metal Classic 2-Slice...
My Cuisinart Toaster's left side lights up
I repaired a problem with one of the sides of my CPT-180 toaster that was fixed by replacing C1. This may be the same component that Stan was referring to, as the C1 capacitor on the circuit board I was having problems with was bulging. I've attached some photos showing C1 bulged out compared to C1 on the good board.
C1 is the main power supply capacitor and if it goes bad, the circuit board power supply won't function correctly. This can lead to a broad spectrum of problems like the lever not staying down or the toasting control/timing circuits malfunctioning. If you replace the capacitor, it is best in most cases to replace with the same value as the orginal (220uf on my toaster)---you can usually get a replacement capacitor at Fry's Electronics. Replacing with a higher capacitance may be acceptable, but you should understand the impact to the rest of the circuit before you substitute a higher capacitance value. The voltage rating and temperature rating of the replacement capacitor should be the same or greater or the capacitor will fail quickly. Note the max temperature rating of capacitor C1 is +105C---toasters get hot (duh!) and the temperature around the circuit board of this model gets quite warm, so the temperature rating of the capacitor is critical. Finally, make sure the substitute capacitor fits when installed (requires soldering) and does not interfere with surrounding circuitry or other toaster mechanics when the circuit board is put back in place.
Pictures:
C1_location (next to screw)
Comparing_good_C1_with_bad_C1--note bulge on bottom of right C1
Right_orginal_C1_and_left_replacement_C1
Bad_C1 showing capacitance, voltage and max temperature ratings
5487aa4b-7e7d-4e6f-9542-cf9ff618008c.jpg2d853c87-48b6-4735-99f4-fdd5dbc60ffe.jpge1a82299-a243-46e1-b11b-4c20e0d9b304.jpg5543b7e5-8108-4b1d-bed3-90eee4600722.jpg
May 14, 2013 | Cuisinart CPT-180 Metal Classic 4-Slice...
Lever will not stay down
There is a catch thatvis not free to move in place when pushed down. It may be jammed.
Feb 12, 2013 | Cuisinart CPT-70 Classic Style 2-Slice...
Toaster latch does not stay down on Cusinart CPT-120 compact two slice toaster
for Cuisinart cpt160: If the latch will not stay down it is because the electromagnet at the base of the toaster, which is supposed to activate when you push the handle down, is burnt out. I pulled my toaster apart and did a test of that mechanism and found that the solenoid was fried (open circuit). There are no replacement parts.
Jan 09, 2011 | Cuisinart CPT-160 Metal Classic 2-Slice...
I'm looking for an instruction manual for CPT-60. Do I have to hit "2 slice" if just toasting bread or just put it in?
You can download the instruction manual in PDF format by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this helps. Thanks for using FixYa.
Jul 24, 2010 | Cuisinart CPT-60 Custom Control Total...
Lever to start the toaster will not engage consistently and makes a horrible sounding noise. After several tries with different pressure, it will engage. The question is "how long before it will no...
mcdevito75 here, If the lever mechanism is worn it could give out at anytime, the sound you hear is like gears grinding, make sure the setting for Darker / Lighter toast is not set too low, set it for Darker toast and then see if it"s better.
Jun 22, 2010 | Cuisinart CPT-60 Custom Control Total...
When I depress the carriage control levers they do
my toaster did this once, i suggest that you get a new toaster from a different company, because if you've only had the toaster a month
and its doing this already that's a crappy toaster
Apr 20, 2010 | Cuisinart CPT-180 Metal Classic 4-Slice...
Toaster won't stay in down position in order to toast - Cuisinart CPT-160 - although it will toast if I hold the lever down as it toasts
We opened up our toaster and scraped some baked-on crumbs off the top of the electromagnet that controls the carriage catch. When we closed it back up, it worked again.
Dec 22, 2009 | Cuisinart CPT-160 Metal Classic 2-Slice...
My cuisinart cpt 160 toaster won't start
Do any of the lights come on ?
If not then have you checked the plug top fuse
If the lights come on and then when you press the lever down it does not latch a solenoid has gone open circuit
Good toasters can be fixed
Cheap ones go in the trash bin
May 29, 2009 | Cuisinart CPT-160 Metal Classic 2-Slice...
4 slice toaster
open the unit. look for disconnected wires from sloppy factory
May 20, 2007 | Cuisinart CPT-140 Cool Touch 4-Slice...
Cuisinart CPT-60 Custom Control Total Touch 2-Slice Toaster Logo
1,595 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
