Maytag Washer A510 Will not agitate but spin out.
Our Washer will not agitate but will spin out.
The belt only slips.. I changed the belt but it still just slips .. When i tighten it  while agitating the motor just pulles down and stops like it, (The agitater is tight.)  I can turn it by hand some.    Does the motor turn one way when it spins and the other way when it agitates?    or how does it change from spin to agitate.?   How do I take the agitater off?
Thanks for your help.
Sanford
3 Suggested Answers
watugot
  • 290 Answers
SOURCE: Washer will not agitate but will spin
You are correct that motor turns one direction for agitate and the other for spin. The problem you describe sounds serious but there is a chance it is not. First, try to turn the transmission by hand. If it wont turn by hand, remove the agitator and see if something has gotten under it and has it locked to the basket. To remove the agitator, pop off the top cap and look down inside. You will see the bolt that holds the agitator on. After you take it loose the agitator will slide off.
If there is nothing there, the transmission will need to be replaced. If the washer is less than 5 years old, the transmission may still be covered by warranty. Check your owners manual for warranty details. Post back to let me know what you find out.
Posted on Oct 21, 2007
  • 6 Answers
You have a bad transmission
Posted on Jun 24, 2008
What would cause my maytag front load washer not to spin? It is a Maytag front load washer and it will not spin. The water drains out no problem just doesn't spin. Also the drum looks lower than it no
No agitation or spin? try these:
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Jan 06, 2015 | Maytag Washing Machines
My maytag bravos will not spin
Oct 10, 2014 | Maytag Washing Machines
Washers empties water but wont ring out clothes
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design. Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Sep 28, 2014 | Maytag Neptune Washing Machines
My maytag washer model pav2300aww will not spin even though it agitates and drain but when it comes to the spin cycle it just kind of hums I looked at the bottom of the washer while it was in spin cycle...
Possible the revolution takes place on the top end of the pulley and belt but the centre stem of the agitator is not moving or it is slipping. It can be due to friction in the stem of the agitator due to clogging of dirt and the best option is to remove and clean the agitator.
Dec 11, 2012 | Washing Machines
Belt slipping during agitation
Bearings are damaged or drum spider damaged .
Oct 04, 2017 | Maytag SAV5910 Top Load Washer
My washer will not spin and make a noise
Possible that the belt is slipping, the motor is jammed, the agitator bearings are worn
click this link for tips to change the belt : belt replacement
Jul 05, 2012 | Maytag Washing Machines
Maytag Top Load washer will spin but won't agitate
sounds like the coupler between the transmission and tub is broken or slipping
Aug 28, 2009 | Maytag LAT2600A Top Load Washer
Squeal that sounds like belt spippage
The motor slides back and forth so there is know way to tighten the belt.The new  belt is needed if your old one shows any ware or if has shiny look to it which would mean its been getting hot and slipping.
May 16, 2008 | Maytag Legacy Series Top Load Washer
It sounds like the plastic inside the agitator cog are worn. The smell is the plastic cog turning but the agitator not turning.
Take off the top of the agitator. If any screw are available remove them. If not grab the agitator from the bottom and yank off. Unscrew the agitator drive cog and inspect underside of agitator. Go to an appliance repair shop and reorder a new one. Between $15-30.
Mar 05, 2008 | Frigidaire GSTF1670A Front Load Washer
Oct 21, 2007 | Maytag Atlantis MAV6260AWW Top Load Washer
Washing Machines Logo
371 people viewed this question
Top Washing Machines Experts
