Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca d52w19 no power
Theres no power light or no power at all I have the same problem. Where exactly is the fuse and where can I purchase a new one?
  • 145 more comments
  • volcomschonk May 28, 2009
    ok I see it. So I can just use the insulation or braid from a coaxial wire? Where can I get that fuse at for the future?
    When you say braid are you talking about the copper or the silver stuff that goes around it?
    ok ima try radioshack.
    Change the fuse to 5a 125v and still no power.
  • volcomschonk May 29, 2009
    Heres some pics
    http://img41.imageshack.us/my.php?image=...
    http://img38.imageshack.us/my.php?image=...
    http://img39.imageshack.us/my.php?image=...
    http://img37.imageshack.us/my.php?image=...
    Sorry about that..
    What should I put the dial to on this meter? Im guessing either DCA(250m or 50u(250mV)) or DCV(125 or 500&1k)? Also not sure where to put the - and + wires on the meter.Not sure if you can read it but it says:
    Output DC1000V
    Not Sure what that is.
    500V DC /
    1000V AC /
    250mA DC /
    Max /
    -COM +V-(?)-A
    Last post didnt come out good.
    ......Output...............DC1000V
    .................................Not Sure what that symbol is.
    ................500V DC...................../
    ........____1000V AC_____........../
    ........[........250mA DC......]......./
    ........[..........Max..............]...../
    ...-COM.........................+V-(?)-A
    This is what I get on the meter for DCV 500&1k.
    How do i read it?
    When reading I connected it to the yellow and pink points.
    Also what would be the best way to drain out the power?
    If reading it correctly would that mean its 350v?
  • volcomschonk May 30, 2009
    Just to make sure I have 3 different prongs to plug connectors into. But I can only find one wire(brown and blue). Do I connect that from one set of 3 prongs to the set of 2 prongs?
    I tryed with the tuner GND plugged in and still same results.
    I meant to say only 2 wires. The tuner gnd(single) and the blue and brown.
    appreciating the help.
  • volcomschonk May 31, 2009
    We reconnecting everything do I plug the blue and brown wire from one terminal to the other. Thanks
    Here is some closer pics..
    Not where that wire plugs into the tv at.
    Dont know where this wire end plugs to.
    Well not sure where it goes...
    Well heres the inside of the tv. I dont know where the cord plugs to so I can test.
    Ok,found out where it goes....
    I have those. Its 2 blue and brown wires that go from the boardin the previous picture to this board up top.
    When pluging in I get a spark.
    .pics
    [URLhttp://img268.imageshack.us/my.php?image...][IMGhttp://img268.imageshack.us/img268/5098/...[/IMG][/URL]
    [URLhttp://img193.imageshack.us/my.php?image...][IMGhttp://img193.imageshack.us/img193/3835/...[/IMG][/URL]
    [URLhttp://img193.imageshack.us/my.php?image...][IMGhttp://img193.imageshack.us/img193/7682/...[/IMG][/URL]
    [URLhttp://img132.imageshack.us/my.php?image...][IMGhttp://img132.imageshack.us/img132/8615/...[/IMG][/URL]
  • volcomschonk Jun 01, 2009
    Dont see anything with those numbers.
    Ok I see, So what am I looking for?
  • volcomschonk Jun 02, 2009
    GAH451
    First pic:
    TDA8177F
    8CN435Z
    ??? Sing
    Second pic:
    looking
    Not sure about the second pic the metal thing is blocking it.
  • volcomschonk Jun 03, 2009
    So just keep searching the heat sinks for part numbers? Also what do u mean by the top most portion of the capacitor being different from the right side? Thanks for the help.
    Checking more heatsinks:
    IRF63OFF
    BYW29FP200
    VIPer20
    CZ014 V3
    CC0X??
    Toshiba
    C5588
    is that it?
    BY(I or T)08
    PI1000
    DTV1500MFP
    GKOR1 VU
    yes the top bulges a little and is brown.
    The capacitor reads 16v 2200uf
    also should I remove c5588 transistor?
    I removed the capacitor is it ok?
    I got 0 when testing but not sure how to adjust ohms.
    when I turned the ohms adjust all the way to the left I get 15 and when I turned the ohms adjust to the right I get 0.
    This is my first time testing continuity.
    ok well I guess thats it. Im going to try and order now.
    Do u know where I can buy these parts?
    I live in USA, FL
    Can I use this to replace the capacitor? http://www.parts-express.com/pe/showdetl...
  • volcomschonk Jun 04, 2009
    I still cant find the regulator. Here is a pic of my actual board with all the heat sink clips off.
    http://img5.imageshack.us/img5/6421/2305...
    Just wondering but is it the flyback transformer?
    I found a website that has all rca parts. Its in Canada so I want to order everything at once if its ok.
  • volcomschonk Jun 05, 2009
    I want to order parts by parts. The transistor circled in green reads 17N80C3/ GAH451. The white one reads 100 (omega) J 1OW NS 0434. Here is a pic of the horizontal transistors terminal holes..
    Front:http://img188.imageshack.us/img188/7336/...
    Back: http://img34.imageshack.us/img34/2338/23...
    When testing for continuity, which way do I turn my ohms dial?
    pic:http://img15.imageshack.us/img15/8779/me...
    Would I put it on rx1 rx10 or rx1k?
    what about the ohms adjuster dial?
    Heres c5588 with the red dial to the left at R x 10 http://img200.imageshack.us/img200/871/0...
    Here is the white one. http://img29.imageshack.us/img29/4474/01...
    17N80C3 has 3 terminals
    With red in the middle and black on the other I get.. http://img198.imageshack.us/img198/871/0...
    With black in the middle and red on the other it doesnt move.
    p.s. how do I know which one is 1 and which one is 3?
    http://img8.imageshack.us/img8/8162/0447...
  • volcomschonk Jun 07, 2009
    So I should set it so it reads zero when shorted and retest everything?
    Readings:
    17N80C3
    normal- 8 on the scale
    reversed- starts at 0 and slowly drops to 2k
    White one circled in yellow
    normal- 0
    reversed- 0
    c5588
    normal- 0
    reversed- 0
  • volcomschonk Jun 08, 2009
    About 30 mins to radio shack but they didnt have it.
  • volcomschonk Jun 09, 2009
    I have 2200uf 35v. Heres a pic. http://img44.imageshack.us/i/192106.jpg/
    I also tested the 2SC5588 board points and I got 5 on normal and 65 on reversed.
  • volcomschonk Jun 10, 2009
    Have capacitor connected.
    Link to gallery:http://img3.imageshack.us/gal.php?g=0428...
    The store I get my parts from. http://www.radioshack.com/search/index.j...
    Should be at local store.
    I noticed a terminal missing solder.
    pics:
    joint- http://img41.imageshack.us/img41/1785/17...
    component- http://img191.imageshack.us/img191/5954/...
    board- http://img23.imageshack.us/img23/9030/17...
    How do I follow point b path?
  • volcomschonk Jun 11, 2009
    Never traced before but point a seems to go to pin 1 on flyback. there's a burnt pin missing within that path. posted pic post above.
    p.s. I might have spare monitor for parts.
    ok. The terminal missing solder is labeled .0087 UF 2000 volts. I assume its a capacitor. It reads 10 ohms and reversed 100 ohms.
    I extracted 1 side and the multimeter doesnt move.
    When the ohms reads 0 its good but if it doesnt move(2k) it is bad(no connection)?
    Ok. Where is the regulator out?
    Yes, reading from point a to point 1 on flyback is zero.
    A to 1,5 and 6 all read zero. The rest read 5+. I was able to trace a connection to those 3 points but what exactly am I looking for along the way?
    Checking with the multitester there is no continuity from the flyback to that point. Should I reconnect everthing?
  • volcomschonk Jun 12, 2009
    Is this right(pic). http://img193.imageshack.us/i/230553.jpg...
    The red is the horizontal output transistor regulator.
    The yellow is Flyback.
    The green is a regulator that im tracing to flyback to find regulator ic?
  • volcomschonk Jun 15, 2009
    I think I found the ic regulator. It is marked LM393N and has 8 terminals. Also when tracing am I supposed to be checking for shorts?
    I was able to follow a trace all the way to that transistor. here is a diagram.... http://img8.imageshack.us/img8/2135/boar...
    http://img10.imageshack.us/img10/9331/04...
    part #: BYT08 PI1000 MAR 446
    http://img26.imageshack.us/i/042842.jpg/
    Not sure if green is a capicitor. It reads 220kFEC 18402. the transistor in blue rectangle part connects to flyback. the grey capacitor in blue rectangle circle reads 40-100 ohms to flyback.
    http://img7.imageshack.us/i/055236.jpg/
    Just to make sure. Extract the "capacitor" or the component up against the heat sink?
    I extracted both. The "capacitor" read 0 ohms. The component attached to heat sink read 5 ohms with red on pin 1 and it read 2k with red on pin 2.
  • volcomschonk Jun 16, 2009
    20 ohms with red in the middle and 65 with black in the middle.
    Yes it is a coil. The part number is (220K FEC/ 18402). The part number of the one closes to the heat sink is (25808 970/ 18411101k FEC).
  • volcomschonk Jun 19, 2009
    http://img19.imageshack.us/i/000741.jpg/
  • volcomschonk Jun 20, 2009
    Hi, the capacitor is 200v 220uf.
    Pic:http://yfrog.com/3o012616j
    coil 1:http://yfrog.com/08012502j
    coil 2:http://yfrog.com/08012721j
    Camera isnt good.
  • volcomschonk Jun 21, 2009
    Yes.
    also I found clear pic.
    http://img8.imageshack.us/i/boardbhr.jpg...
    that is
    BYT 08PI-1000
    5 0hms with red on 1. appreciating the help.
    stays at 2k.
  • volcomschonk Jun 22, 2009
    ok, rx10 deflects and rx1 doesnt. monitor is ready.
    black on middle I get 100 0hms and red on middle get 6 0hms.
    No horizontal in old monitor reads: "black on middle I get 100 0hms and red on middle get 6 0hms". Extracting it now.
    PIC
    black on left pin and red on middle it reads 8 0hms. With red on left and black on middle it stays at 2k.
    pic
    C5584
    with red on left pin diode reads 5 0hms. Reversed it doesn't move(2k). C5588 reads 0 normal and reversed. C5584 reads 8 0hms with black on left and red in middle. It stays at 2k reversed.
    recheck C5588, black on left pin red on right pin 0
    reading on reversed 0
    black on left pin red on center pin 0
    black on right pin, red on center pin 0
  • volcomschonk Jun 23, 2009
    Connected everything but I didnt have the red wire to the flyback in all the way and I turned the tv and smoke came out of that. I put wire all the way in and turn tv on and the green light flashed 3 times and bade beeping noise. I tried again and nothing happened.
    Yes it now reads all 0's
    How would I go about measuring it? Thanks
    022 tip42c
    Shows no reading with set plugged in.
    350v
    No voltage. Just to be sure, I removed the horizontal output transistor. Put back in?
  • volcomschonk Jun 24, 2009
    20 0hms and 100 0hms
    It reads 100 normal and reversed.
    When I turn the tv on it reaches 150 - 200 for about 5 seconds then shuts down and drops.
    Yes it reads 0
    ok im going to order one now online.
  • volcomschonk Jun 27, 2009
    No.
    I received the h.o.t and I.C. regulator(just in case). They didnt have my ic model(TDA8179F) but I got STV9379instead.
    ok. The cap that holds the red wire secure to the flyback broke when first removing it. I tried pushing it in harder but still makes a sizzling sound and smell smoke.
  • volcomschonk Jun 28, 2009
    yes it is shorted but I bought 2.
    I secured the red wire. The T.v. turns on/off three times and flyback makes fizz. The h.o.t was not shorted.
    Hi, the voltage reads 170.
  • volcomschonk Jun 29, 2009
    yes its capacitor.
    When turning on the center bulb emits a little light on the base.
  • volcomschonk Jun 30, 2009
    Hi, I have 5 pack of 100 0hms 1/2 watt and 5 pack 220 0hms 1/2 watt.
    I removed the resistor burnt connected to rx10 and replaced with 2 100 1/2 0hms.
    http://yfrog.com/17153722j
  • volcomschonk Jul 03, 2009
    Hey, I bought a flyback and multimeter. Multimeter will arrive tomorrow.
    Are you refering to the chassis or the multimeter?
    Should I install the new flyback? Can return.
  • volcomschonk Jul 09, 2009
    I installed flyback. When I power on it turns on/off 3 times. Here is a video.
    I have a new multimeter. Will test tomorrow.
  • volcomschonk Jul 13, 2009
    CXXXX terminal reads:
    19.00 with black in middle and red on right at 20k
    60.4 with red on middle and black at right at 200k
    The capictor maxed at 160 but was at 135 the most.
    Are you refering to CXXXX about the driver? Thanks
    cxxxx reads 0. How do I check the read the collector?
  • volcomschonk Jul 16, 2009
    I connected red wire to the center pin and grounded the black wire and it read 4.9 volts while plugged in.
  • volcomschonk Jul 22, 2009
    I did what you suggested and its reading 0. I even touched it but no shock.
  • volcomschonk Jul 23, 2009
    at 2000 it reads 2 and at 2k it reads 0.
  • volcomschonk Jul 24, 2009
    pluged in: 00.2
    turned on: 158
    turning off: 155 - 00.3
    Hi, where is the emitter? thanks
  • volcomschonk Jul 25, 2009
    The ribbons are secure. It read .2 pluged, 156 on and .2 off. I turns on off 3 times by it self and the middle lamp emits a blue light.
  • volcomschonk Jul 27, 2009
    Hi. There is 3 connections to the middle lamp and do not know which one is the CRT. Also, im confused on how to rotate the flyback transformer. Appreciating the help.
    Old and new fly backs are 259296. The new flyback seems a little diffrent but not sure how to adjust screen control. My camera is broke and im getting a new one in a couple days.
  • volcomschonk Jul 30, 2009
    http://img24.imageshack.us/img24/6880/00... http://img31.imageshack.us/img31/4062/00...
    Hi. Im not sure how to adjust the screen control. Heres a pic of it apart.http://img398.imageshack.us/i/flyback002... and http://img389.imageshack.us/i/flyback001...
    Heres a pic of the crt removed.
    http://img387.imageshack.us/i/0000004e.j...
  • volcomschonk Jul 31, 2009
    The bottom nob is labeled screen but you cant turn it.
    Turned it on. The middle crt makes a hissing noise and flashes like its turning on.
    Flashes white. Not blue.
    inside
    inside
    when you say tube are you referring to the glass base or the metal in the glass? Also the hot went bad so ordering more.
    Ok. I threw out the old monitor. I'm posting a clearer pic of the resistors.
    http://img375.imageshack.us/i/resistors0...
    http://img338.imageshack.us/i/resistors0...
    http://img385.imageshack.us/i/resistors0...
    reads control and focus http://img397.imageshack.us/i/resistors0...
    I already did.
Slinteriors
  • 8617 Answers
SOURCE: rca d52w19 fix fuse name
thats not a fuse issue, its a defective flyback. You can get a replacement flyback at the following link with free installation instructions so you can easially install it yourself. You need flyback number 259296 here is the link.
http://servicemanuals.vstore.ca/
Posted on Aug 25, 2008
ladywinn
  • 5138 Answers
SOURCE: rca D52W19 will not come on
CK capacitors cp114,cp120 cp150 they are on the Deflection Board.
Posted on Feb 14, 2009
Slinteriors
  • 8617 Answers
SOURCE: model d52w19 rca projection tv,will not turn
Thats the eroor for the flyback and CP150 needing replacement you can get the flyback # 259296 and the CP150 at the following link and they give free step by step instructions on how to do the repair.
Posted on Mar 06, 2009
SOURCE: RCA MODEL D52W19 I PRESS THAT POWER BUTTON GREEN LIGHT FLICKS FOR
try unplugging the tv for a few hours. then plug it in and push the power button on the front of the tv.
it has something to do with this processor issue inside the tv....its pretty much a stupid thing.
should have been a recall because everyone has the same problem on here.
this is pretty much just a band-aid over cancer, but i've been having to do this for about a month now, and it works.
Posted on Apr 18, 2009
Slinteriors
  • 8617 Answers
SOURCE: BIG SCREEN rca d53w19, where are the fuses????
There is one fuse if you look in the rear of the set on the left side follow the power cord as the cord plugs into the Main filter board which has the fuse. Its located right next to the power cord on the right side of that board
Posted on May 27, 2009
I have a RCA D52W19 52 in. Rear Projection Television. When I turn it on, the green power button light comes on and the tv sounds like it's coming on, then it sort of blinks...goes on and off a few times,...
The capacitors known as CP150 CP120 and CP114 often fail which causes that symptom. You can get the RCA repair kit by that same name from www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.
Dec 30, 2009 | RCA D52W19 52" Rear Projection Television
RCA D52W19
3 times means a convergence problem on many tv set, I will check exact codes on your RCA.
Jul 13, 2008 | Televison & Video
May 27, 2009 | RCA D52W19 52" Rear Projection Television
Rca d52w19 no power
the fuse is most likely blown Its on the filter board which is the small narrow board that the power cord attaches too on the right side
Mar 25, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca D52W19 will not come on
Jan 28, 2009 | RCA D52W19 52" Rear Projection Television
52" RCA Rear Projction TV 1995
check cp 150 2200uf 16v, if bad there is 2 more caps in same circuit 220uf 35v.cp111 cp114
Dec 05, 2008 | RCA D52W19 52" Rear Projection Television
D52W19 blowing fuses????
Anytime they blow the AC fuse you have other part/parts shorted,ck fuse resistors big white resistors on same board and hori output or any shorted diodes.
Nov 30, 2008 | RCA D52W19 52" Rear Projection Television
My rca d52w19 has a cracked screen,
is the inner screen damaged? or just the outside. the outside is called the super sheild. this can be purchased at union electronics
Oct 07, 2008 | RCA D52W19 52" Rear Projection Television
Rca d52w19 fix fuse name
Aug 22, 2008 | RCA D52W19 52" Rear Projection Television
Rca d52w19 convergence hell
Did you replace the convergence board or the convergence power supply board? usually one color will be a problem with the convergence board and more than one color means the convergence power supply is the problem. Ebay isnt a good place for boards as you never know if the board is good. You can get the convergence or the convergence power supply boards at the following link along with free shipping and tech support.
Jun 25, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
3,704 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
