Question about Tools & Hardware - Others
One piece roof coming apart
The laminate coating is cracking and pealing off
    Problem Solver:
  • 13 Answers
Spray with a heat proof spray enamel. good as new.
Posted on Oct 27, 2010
Laminator wont feed
If the motor is running, then the cog that drives the roller system may have failed. Laminators built today are made with plastic (nylon) roller drive cogwheels that crack. Especially if the fed media is too thick. Put the machine into run mode and feed a single piece of card (a playing card will do) into the feed slot. Lightly hold the card and see if you can feel the card moving. To check if the motor is in reverse, feed the card into the output slot.
If you are handy with a screwdriver, then with it disconnected, remove the lid (about six screws underneath) and check the rollers for old lamination sheets that could be stuck to one of them. This would limit the feed gap between the rollers, preventing you from putting your media in.
Nov 23, 2013 | Fellowes Saturn 2 A3 Laminator Laminators
I have a fellowes laminitor and it will not feed
What are printed circuit boards made out of?
Most modern printed circuit boards are made from a laminate material and coated with copper on both sides. They are also typically made out of glass-epoxy because they are easy to work with and don't break or splinter when cut.
Sep 02, 2013 | Electronics - Others
What is a laminator?
A laminator is a tool used to plastic coat documents to protect them. Your social security card may have a laminate coating.
Jan 28, 2013 | Office Equipment & Supplies
Dashboard rubbery coatings on Silverado pick up is pealing off is there any product out there to fix it??
Gorilla glue. Slap that stuff on all over the places its peeling and it should take care of it.
Oct 05, 2012 | 2004 Chevrolet Silverado 1500 Crew Cab
Hi I have the Gas Patio Caddie. The coating that is in the inside of the cover is bubbling up and starting to peal off. Can that be resprayed with something or do I need a new cover? If so where can I...
It can be repainted, using spray on, High Heat Grill Paint. Which, you can find at any home center or hardware store, in the paint department. Krylon makes one, as does Duron. I personally like Krylon, as it seems to cover better.
You will need to thoroughly clean the surface of any grease, rust, loose paint, etc. Then wipe the the area to be painted with denatured alcohol and then wipe off any remaining residue before spray painting it. Several light coats is much. much better than two heavy coats. Allow each coat to thoroughly dry, before applying the next coat.
Do not use the grill for 48 hours, after the final coat of paint has been applied.
Hope this helped you and Happy Grilling!!
Jun 12, 2011 | Char-Broil Patio Caddie Grill
I own a 5 year old 40" sony bravia lcd tv, When
This sounds like what I managed to do to my screen, even though I knew better. Is there any chance you layed the screen face down at some time?
Even though you can still watch it OK, you probably have hairline fractures in the screen face (NOT the screen itself- be thankful for that- the cracks are in the screen coating). LCD screens are a very thin glass laminate with a thin protective glass-like coating. When they are laid flat (like I did to connect cables) if the screen bears any weight, microcracks develop on the front of the screen.
I am sorry to say that the effect is permanent.
Feb 24, 2011 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
On the inside of the lid the paint or enamel coating is pealing off on to the food. Weber rep. said they don't paint the inside of the lid, and is probaly residue from cooking. But I used the word (paint)...
Most of the time what appears to be paint pealing, on the inside of your grill lid, is actually soot from your LP gas and bad combustion. May need someone to provide a thorough clean of your burners and check that your orifice sizes are correct and clean(holes on back of valves).   If you can, convert your grill to NG.. that will almost always solve a sooting issue(it burns much cleaner than LP)!  Hope this gives you some answers?
Mar 28, 2009 | Weber Genesis Silver B Grill
Pealing clear coat on 93 cougar
I had that problem. I was told I had to repaint the car.
Jun 01, 2008 | 1993 Mercury Cougar
Plscti/ teflon coating inside the microwave
Is it plastic or paint? I would be surprised if it were plastic, as that would probably not withstand the microwave energy.
If it needs to be repainted, that can be done if it is cleaned and dried.
High temperature appliance paint is available from stores like Wal-Mart or Lowe's.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 09, 2007 | Daewoo KOC-925T Microwave Oven
Tools & Hardware - Others Logo
120 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
